Author Topic: I thought I'd try a Japanese joint!  (Read 43605 times)
Offline RossJarvis
« on: October 14, 2013, 02:20:08 PM »
Now that I’ve made my own toolbox I must be a craftsman, innit!  So as I’ve been threatening, it’s time to get crafty.  I have read a number of books on sawdust and shaving manufacturing including these;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3271.jpgI thought I'd try a Japanese joint!
The one on the left is good on history and stuff, with some interesting bits on restoring an old temple, the one in the middle is a bit superfluous but has some nice photographs, The one on the right is very good on a lot of carpentry and joinery and includes lots of very scary joints.
So I thunked “let’s make a splicing joint, with that old oak in the outhouse” I was thinking of a “lapped gooseneck splicing joint” (Koshikake Kama Tsugi?!?), but then decided that might be a step too far, even for yours truly and the “apprentice”.  So I decided on a lapped dovetail.  I’ve done a couple or three of these before and almost got them right, so where’s the problem.  This is called the “Koshikake Ari Tsugi”, not quite sure what the words mean but I presume it’s some relation to ‘Ari Secombe.  There’s two versions of this for a splicing joint, one wot is a fair bit simpler than the other;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/Joint1.jpegI thought I'd try a Japanese joint!
The top one is a simple lapped dovetail and the one underneath has a sort of mortice n’ tenony thing in the bottom, so I’m sort of thinking of doing that one.  Hennyway, out to the outhouse and find me some wood;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3260.jpgI thought I'd try a Japanese joint!
…here’s a couple of bits of oak wot I got fresh cut and green at Cressington Temple, for a couple of quid about four or five years ago, for some unknown reason they were left-overs;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3261.jpgI thought I'd try a Japanese joint!
Could have something to do with the pithy bits (pith?) in them and the odd size.  Anyway I took the pith and stuck it in the outhouse till I could thunk of summat to do with ‘em.  That time has now arrived.  Firstly I thought I might need something a little bit better than the garden staging to plane this on.  Now as luck would have it I noticed a bit of 2x6 that had been hanging around in the porch, hidden behind a Big Austrian and a Little Israeli, dragged it round the back and started to plane an end stop for it;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3262.jpgI thought I'd try a Japanese joint!
once again, I resorted to hi-tech bench dogs to hold the planed bit;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3263.jpgI thought I'd try a Japanese joint!
Once the stop was square and straight(ish), I thought the planing bench could do with a bit of planing too;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3264.jpgI thought I'd try a Japanese joint!
Bish, Bash, Ouch, Bosh, one planing bench with stop;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3265.jpgI thought I'd try a Japanese joint!
Nextly I cut a bit of oak off the end of the oak and bunged the rest of the oak back in the outhouse;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3266.jpgI thought I'd try a Japanese joint!
I wasn’t 100% sure how the ryoba saw would deal with this wood and it was a bit tricky to start, once I’d stopped using the “rip” side to crosscut and turned it round, it went fine.  It was a little bit slower than cutting pine, but not by much and left a lovely finish.  Next I thought that I’d better get the proper support services in place, as I’d not utilised these well last week;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3267.jpgI thought I'd try a Japanese joint!
…just need to keep an eye out for the apprentice to stop him scoffing the lot!    Nextly I started bashing the oak with the plane, having remembered to re-sharpen the iron (and deliberately avoided dropping the sharpening stones on the tiles this time).  It took a fair bit of pushing in comparison to planing pine and there was very little between having the blade below the mouth and skating across the surface and “Oh my good groovy, that’s resisting a bit”.  And the shavings were fairly different too;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3269.jpgI thought I'd try a Japanese joint!
…generally quite wrinkly and harder to see through than pine!  I couldn’t find any candles to rub on the plane bottom and couldn’t be ar…bothered to sharpen the no 4 or 4 ½.  It’s some considerable time since I’ve planed oak, so I’m not sure if this is to be expected or not.  Anyway, the surface came out reasonably smooth and almost shiny and with a good stroke of luck I got the edges square;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3268.jpgI thought I'd try a Japanese joint!
…and after a few cups of tea, inter-sperced with grunting and iron tweaking we ended up with;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/_DSC3270.jpgI thought I'd try a Japanese joint!
…a lump of oak.  So far it’s looking pretty good, nice flat surfaces, square edges (in a rectangular fashion if you get my drift) and the thin edges are parallel, but the fat ones aint.  The Hampshire monsoon started again so I came back inside to gabble on to you.  Next I want to get the faces parallel, cut the block in half, mark out both joints, throw a saw and some chisels at it and be done, however the BBC says it’ll be sunny all day tomorrow, so I’m digging out my Sou’Wester, but if they’re actually right for once I might be able to get this job done in a day (famous words of the last variety).
Procrastination; now is that an art or a craft skill?
Offline AussieJimG
Re: I thought I'd try a Japanese joint!
« Reply #1 on: October 14, 2013, 05:12:17 PM »
I'm not much into working with the brown stuff but I love the photos and the commentary so I'll watch for the amusement.
Keep it up and thanks for the entertainment.
Jim
Offline RossJarvis
« Reply #2 on: October 15, 2013, 02:05:39 PM »
Well, once again I over-estimated my abilities or under-estimated time or something, so even though it was sunny(ish), I didn’t finish.  However I did start!  Yesterday I’d nearly got a lump of wood into shape.  Today I managed to get it nearer to shape and cut it in half.  The wood was slightly ramp shaped, so I marked where to plane to;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3284.jpgI thought I'd try a Japanese joint!
This was the thick end, and planed, planed, planed.  As I’d now sharpened the blade on the Record No 4 (see my post in the tools section where I’d fixed the broken whetstone), I tried that to see if it was any easier.  The back-iron-chip-breaker-spare-bit-of-metal-thingy was set further from the sharp edge on this as well to see if that made anything easier.  No it wasn’t, so back to the 5 ½ and I got the job done (or so I thought).  Here’s the shavings, if anyone who knows what they’re doing can comment, it would help, is this wot oak should plane like?;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3286.jpgI thought I'd try a Japanese joint!
Generally I was very pleased with the finish.  It was smooth, flat and iridescent on the non-holey bits of the grain;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3289.jpgI thought I'd try a Japanese joint!
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3290.jpgI thought I'd try a Japanese joint!
The grain changed direction on one side and even that came up fine;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3285.jpgI thought I'd try a Japanese joint!
This is what it looked like before planing;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3291.jpgI thought I'd try a Japanese joint!
…and this shows how many shavings have been removed, side view;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3288.jpgI thought I'd try a Japanese joint!
…top view;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3287.jpgI thought I'd try a Japanese joint!
Once I was happy with it, I marked centre lines down all faces and marked the top (it could have been the bottom, but what’s a top or bottom between friends?;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3292.jpgI thought I'd try a Japanese joint!
Then “BONSAI” I attacked it with the saw and cut it in half (why do the Japanese rush into battle shouting ’small trees’?);
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3293.jpgI thought I'd try a Japanese joint!
By now the “apprentice” was nagging me for some more Hobnobs, so we took a walk to the garage, where I bought some baccy instead.  Whilst he was in a huff we had a scout round for some more hazelnuts, only to realise that the squirrels and field mice have cottoned on to my free food supply, and they’ve scoffed the b****y lot.  After this I had a look through my Japanese Joinery book to check on the dimensions for this joint, found out it didn’t tell me, so I made them up;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3295.jpgI thought I'd try a Japanese joint!
If you look closely you can see a bit of a miscockulation!  I generally use an edge for reference when marking out, but apparently the traditional way is to use the centre-line for this sort of thing, so maybe that threw me.  Back out to the “workshop” and time for a bit of ripping;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3296.jpgI thought I'd try a Japanese joint!
…the book often suggests a particular order to do this in, but I couldn’t make head nor tail of this so tried an order which seemed logical.  I find it best to not saw off your lines before you need them.  The first cut was the half way up line.  The ryoba cut through the oak very easily and pretty fast (mine is a Bakuma 250 from Dieter Schmidt’s Fine Tools).  Then I cut down the sides of the dovetail;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3297.jpgI thought I'd try a Japanese joint!
…here I’m not quite following the line, but at least I was cutting into the bit I didn’t want.  I read somewhere the suggestion that on the male pieces you want to cut down the outside of your marked line and on female pieces on the inside of the line.  This should leave you a lines-width bit of wood to play around with when it comes to fitting.  If I’ve got that wrong, then I’ve got a lines-width bit of air to play with.  Then I cross-cut the waste off to leave;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3299.jpgI thought I'd try a Japanese joint!
…some bits of wood of various shapes.  There are two square recesses at the bottom on each side, for these I cut diagonals across all the lines, corner to corner and had a bit of waste I could remove fully;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3300.jpgI thought I'd try a Japanese joint!
…which left a couple of triangles to get out with a chisel.  At this point I was worried as I hadn’t any broken whetstones left, so for the second time today I got ‘em off the top of the fridge-freezer and sharpened a medium chisel.  This I bashed into the corners, first one way;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3302.jpgI thought I'd try a Japanese joint!
…then t’other;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3303.jpgI thought I'd try a Japanese joint!
There may be an easier or better way of doing this and if anyone knows please tell me before tomorrow!  After a bit of bashing, paring and swearing I sort of nearly finished one side of the joint;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset1/_DSC3304.jpgI thought I'd try a Japanese joint!
Then it started to look like it was going to get dark and it was getting a bit nippy so I bailed out for the day and came in, to see the beloved munching off with the last of the Hobnobs!  The BBC says there’s heavy rain forecast for tomorrow, so I’m getting my flip-flops and shorts out.  If they’re actually correct you may not hear from me for a day or two.
TTFN
« Reply #3 on: October 15, 2013, 02:27:15 PM »
This reminds me of my school carpentry lessons where all we did was joints. I'd swear the the workshop teacher would deliberately give us bits with nasty knots in 'exactly' where he wanted a dovetail. He was an evil little welshman with a chip on his shoulder bigger than a trunk of English Oak !
What he didn't know was we'd take his nasty bits of knotty wood into the metalwork shop and cut the dovetails on the band saw, then clean them up with a chisel so he couldn't tell  :ddb:
« Reply #4 on: October 15, 2013, 02:41:23 PM »
Bash the chisel vertically on the line then split the end grain the amount you have cut down with the chisel , and repeat the corner of the chisel works best start on the outside and work in about an eighth at a time , forget the Japanese joints hears some British ones http://www.greenoakcarpentry.co.uk/wp-content/uploads/greenoakcarpentry-joints-presentation-lowres-for-web.pdf .
« Reply #5 on: October 15, 2013, 04:01:48 PM »
Jim
Ross.
It all looks rather complicated to me.........  :scratch:
But, I'm enjoying every post. Same as Jim!  :thumbup:
Offline RossJarvis
« Reply #6 on: October 15, 2013, 04:18:36 PM »
Thanks Chipenter :thumbup:
Strangely enough, Andrew holloway and Green Oak Carpentry is about 4 or 5 miles down the road from me.  I've done some English joints, so thought I'd have a go at some others.
Offline RossJarvis
« Reply #7 on: October 15, 2013, 04:21:16 PM »
He didn't teach maths as well did he?  reminds me of a teacher I had.  When at college, we were given a chair project to do, I pinched all the non-knotty wood first, leaving the knots to everyone else!
« Reply #8 on: October 15, 2013, 04:30:22 PM »
I suppose were I to feel charitable towards him I'd say he did it so we would learn to overcome problems  :clap:
Offline RossJarvis
« Reply #9 on: October 16, 2013, 12:36:47 AM »
Hmmm, I teach "metal work" to apprentices and the like.  There are more than enough problems for them to overcome, without giving them more to do.  He may just have been over-worked :bang: or not quite suited to the job :( (teaching can be harder than you think) or maybe he was just a short-a***d **** b*****d  :loco:?
Offline RossJarvis
« Reply #10 on: October 16, 2013, 07:39:26 AM »
I've had a bit more time to dig into that pdf, you've now got me wanting a copy of Cecil Hewit's book.  There are some British joints the equal of Japanese fiendishness in there.  I may be coming back to some of them soon.  Looks like a lot of b****y hard chiselling involved though.  Need to find the belly brace to clear out some waste with, now is that in tool-box 1, 2, 3, 4, 5 or six, or is it on a shelf, or behind a doo-dah?  I was thinking of a stepped-wedged scarf next, which seem virtually identical, whether British or from Nippon.   Then the "top-splayed and tabled scarf, with sallied and under-squinted abutments" looks interesting, even the name gives me the shivers :bugeye:.
« Reply #11 on: October 16, 2013, 08:43:52 AM »
Green Oak is so much easer as it dries Oak gets harder until after a hundred years you wouldn't get a screw in it .
Offline RossJarvis
« Reply #12 on: October 16, 2013, 12:43:23 PM »
Well, the BBC were right and wrong.  The Hampshire Monsoon resumed, then it stopped and then it got sunny.  I had to take the “apprentice” to his doctor (he goes private, we’re NHS, must have a look at that contract!), but managed to get an hour of butchery in.  I checked the uncut bit of wood to the cut bit, noticed a couple of miscockulations and attempted to uncockulate them, must take more time marking out.  I put an extra couple of lines in to carry a joint around an end, then I ripped down some lines;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3305.jpgI thought I'd try a Japanese joint!
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3306.jpgI thought I'd try a Japanese joint!
…cross-cut another and cut what I could for the dovetail housing-holey bit;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3307.jpgI thought I'd try a Japanese joint!
…then some bashing and paring with the chisels;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3308.jpgI thought I'd try a Japanese joint!
….which I’m occasionally getting the hang of.  And it looks like the female part is coming together;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3309.jpgI thought I'd try a Japanese joint!
Nextly, I carefully matched the two sides up and carefully, gently pared at the tight bits………and then got a bit too carried away;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3313.jpgI thought I'd try a Japanese joint!
….leaving some gaps you could park a Routemaster in, to be specific, I think you could get an RML lengthways in some of ‘em.  It was getting late and I was obviously over-tired so I stopped.  The sockety-holey-dovetail bit wasn’t finished, leaving the top proud;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3311.jpgI thought I'd try a Japanese joint!
..and I was having issues clearing the corners;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset2/_DSC3310.jpgI thought I'd try a Japanese joint!
…so I’m thinking of “Mullering” up a couple of smaller chisels to make a pair of skew-wotsits.  I’m sure they’ll come in handy.
TTFN
Offline RossJarvis
« Reply #13 on: October 16, 2013, 12:47:26 PM »
Tell me about it.  I did a green oak course a few years back, and I've had ice cream tougher to cut into.  Even further back I was making a replacement sill for a window out of 200 yr old oak, with a blunt plane, I shan't tell you how long that took :bang:, nor the naughty words I was using :palm:.
Offline RossJarvis
« Reply #14 on: October 17, 2013, 08:47:04 AM »
I think I’ll call it a day on this, any more effort and I’ll bollix it up more.  First thing I did was hunt around for a couple of old Stanley chisels I’ve got to make skew-wotsits.  I eventually found this;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset3/_DSC3315.jpgI thought I'd try a Japanese joint!
….which seems to show no improvement and possibly some regression in the past 5 years.  Stanley seemed to have taken his chisels back, so I ground out a couple of my smaller Bahco chisels;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset3/_DSC3314.jpgI thought I'd try a Japanese joint!
…looking at the rust on them, and the edges, it looked like I’d never used them, which probably means I’ll definitely need these with square sharp bits any minute now.  Bish bash Ouch (oh, you're supposed to keep the other hand behind the sharp bit are you?) Bosh and I’d done as much b*****ing stuff up as seemed wise.  The joint was flush(ish) and tight(ish), but if you look carefully into the gaps you may see some headlights in the gaps from a bus or two;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset3/_DSC3316.jpgI thought I'd try a Japanese joint!
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset3/_DSC3317.jpgI thought I'd try a Japanese joint!
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset3/_DSC3318.jpgI thought I'd try a Japanese joint!
… it definitely looks better from this angle;
http://i617.photobucket.com/albums/tt252/RossJarvis/Japanese%20Joint%201/subset3/_DSC3319.jpgI thought I'd try a Japanese joint!
Lessons learnt; don’t make Japanese joints out of seasoned oak; I need to make up a square “paring block”; I need lots more practice; I need to take more care marking out; pare and compare, pare and compare, not pare, pare, pare, pare, compare “oh b****r”.
Hope you found this one interesting.  I’m going out for a walk with t’ “apprentice” and he’s carrying the chestnuts back.
TTFN
Offline AussieJimG
« Reply #15 on: October 17, 2013, 04:05:11 PM »
Brilliant! Bring on the next episode.
Jim
Offline RossJarvis
« Reply #16 on: October 18, 2013, 04:38:21 AM »
Jim
Cheers Jim :thumbup:
I'm chuffed you enjoyed it and kept watching.
« Reply #17 on: October 18, 2013, 01:28:25 PM »
Definetly a tough splice to make looks like a few lines could be thicker for adjustment reasons.
Offline NormanV
  • United Kingdom
« Reply #18 on: October 18, 2013, 02:02:45 PM »
Bit of glue and sawdust and it will be fine!
Offline AussieJimG
« Reply #19 on: November 16, 2013, 08:19:30 PM »
Here you go Ross, some more Japanese woodwork for you to try your hand at:
Jim
« Last Edit: November 16, 2013, 10:13:06 PM by dsquire »
« Reply #20 on: November 17, 2013, 05:14:24 AM »
Looks like you are getting a hang on the pull saw. Looks like a veritable progress to me.
Offline RossJarvis
« Reply #21 on: November 17, 2013, 08:17:58 AM »
Aussie Jim, that was brilliant, I think I'll leave doing that till I've got a bit more time to spare.
Pekka, I'm still feeling I need a 7 year apprenticeship to really get the hang of pull saws.
« Reply #22 on: November 17, 2013, 12:23:45 PM »
Pull saw really is a different animal. My father is very good with western tools. Once my 3-4 year old daughter show how to cut 5*5 cm pine no problem. My father tried the same and broke sweat and was having hard not to swear too much.
I found out that I really had to think it over. Good but firm grip. Like a golf club or bo or bow. Then align elbow and hand on line with the saw and pull with one continuous movement. Now I don't think of it much. But at the begining it was really hard. Specially to start. Firs pull is most important. A little wrong and then if you try to fix it it goes even more wrong. A little too much wrong practice and the saw gets jinxed. Throw it as far as you can and start over :lol:
Pekka, saw is fairly easy but those chisels are work of devil himself. And do I even dare to star about the plane? Shudder.
