Author Topic: Mill bearings  (Read 18026 times)
Offline kayz1
Mill bearings
« on: September 17, 2013, 04:40:57 PM »
Evening all, has anyone pulled a Chester Champion 16v mill to bits please? my spindle bearings have chucked  their hand in today so i am looking for tips on replacing them.
 Ta!  Lyn.
Offline mechman48
Re: Mill bearings
« Reply #1 on: September 18, 2013, 10:55:06 AM »
Hi Lyn
May I suggest you look at the MEW website & forums for further help as I recall seeing something mentioned re Chester Mill repairs etc. although I'm sure this forum will come up with answers.
George
George.
Re: Mill bearings
« Reply #2 on: September 18, 2013, 11:20:54 AM »
I've changed them on a Conquest.........
Swapped out the ball raced units for taper rollers...much better!
Offline kayz1
Re: Mill bearings
« Reply #3 on: September 18, 2013, 02:55:44 PM »
Thanks chaps, i did nip up the bottom taper bearing this morning much better but still cannot hear myself think..Whats's the Chester 626 like?
Christmas is on it's way, i could keep the noisy 16v just as a drill press. SWMBO said just get it....if only i had more space.
  Lyn.
Offline JohnC
Re: Mill bearings
« Reply #4 on: September 18, 2013, 03:37:38 PM »
Hi Kayz,
I have the Chester 626 - I think it is OK.  There's lots of info on the 626 Yahoo group.  I put a 3 phase motor and VFD on mine and that has made the world of difference.
Rgds,
John C
York, UK
Offline kayz1
Re: Mill bearings
« Reply #5 on: September 18, 2013, 03:50:58 PM »
Thanks for that John,,,will run the ruler over the floor to check if i will be able to my bikes in the shed also..
Ow! whilst i'm on, has anyone any info on the Lux machines, size looks about do-able for my avaiable space.
Re: Mill bearings
« Reply #6 on: September 18, 2013, 03:57:40 PM »
I also have the Eagle 30 from Chester.....but converted to 3 ph with an inverter.....
Love it to bits....
Re: Mill bearings
« Reply #7 on: September 18, 2013, 04:14:52 PM »
Hi Kayz,
Rgds,
kayz1,
Are you sure the spindle bearings are your problem? At work, one department bought a mill/drill (Warco Major I think) and the noise was unbearable - it turned out to be the crap Taiwanese motor. The vibration from the motor even prevented you from getting a decent finish. It wasn't down to balance or poor bearings in the motor because when you cut the power and let the machine freewheel to a stop it was very quiet.
I guess that before today that the noise was acceptable - in which case the motor probably isn't to blame but it's worth running the motor with the belt off to check.
Offline kayz1
Re: Mill bearings
« Reply #8 on: September 18, 2013, 07:57:05 PM »
Hi Phil, i did run the motor off the head and all was silky smooth..
Lyn.
Offline kayz1
Re: Mill bearings
« Reply #9 on: September 20, 2013, 04:35:17 AM »
Now then i have a problem, the boss ( Pat ) says i can have a new mill as i spend most of my time in the shed :clap: so is it 626 or superLux from Chester and do i go MT3 or R8 many thanks.
Lyn.
lordedmond
Re: Mill bearings
« Reply #10 on: September 20, 2013, 09:21:10 AM »
 Depends on how much tooling you have in MT3  if none go R8
but both will do the job , I was forced into going the MT3 route because I have a large amount of MT3 tooling
Stuart
Offline porker
Re: Mill bearings
« Reply #11 on: September 20, 2013, 09:45:29 AM »
+1 if you already have the tooling then get the same otherwise you will spend s lot retooling. If I had to choose though I would go R8 - loads of tooling available and taper releases easier.
Offline unc1esteve
Re: Mill bearings
« Reply #12 on: September 20, 2013, 10:30:41 AM »
Repair the old mill, give the rest of the money to the Boss.
You will be much happier.
Offline kayz1
Re: Mill bearings
« Reply #13 on: September 20, 2013, 01:44:07 PM »
To late the deed is done  :thumbup: paid half as deposit today for 626 with power feed and DRO...
 Lyn.    PS: tis only money  :clap:
Offline unc1esteve
Re: Mill bearings
« Reply #14 on: September 20, 2013, 02:20:40 PM »
Are you located near Shreveport?  I will take the old mill.
Offline kayz1
Re: Mill bearings
« Reply #15 on: September 20, 2013, 02:47:36 PM »
Sorry North Wales UK...
Lyn.
Offline kayz1
Re: Mill bearings
« Reply #16 on: September 20, 2013, 02:52:27 PM »
I picked Metric with R8, i do have a start as i have a bunch of R8 collets for the grinder never been used. Plus i ordered collet chuck for my 25's any thing else will come in time..as i said above i just have to make some room in the shed or sell a bike or two.. :>(
Re: Mill bearings
« Reply #17 on: September 20, 2013, 06:52:43 PM »
...i just have to make some room in the shed or sell a bike or two.. :>(
ugh....
but congrats on the new mill!  :thumbup:
Re: Mill bearings
« Reply #18 on: September 21, 2013, 05:00:34 AM »
...... sell a bike or two.....
Then, since ypu've now you've got the kit, you can follow Tom's example and build a new bike!  :proj:
Offline kayz1
Re: Mill bearings
« Reply #19 on: September 21, 2013, 03:22:10 PM »
I have been following the thread, if only i had  1% of that mans skills i would be very happy...i only play.
In saying play i had another play with the 16v today and when i adjusted the tapper bearing in the bottom
it runs very nice once again...must learn how to use my grinder as i have a bucket full of blunt cutters :doh:
Re: Mill bearings
« Reply #20 on: September 21, 2013, 06:46:15 PM »
Noise can be vibration on what its sitting on, been there done it.
Worst railway sleepers followed by 4x2", quietist 30x30x5 angle uprights bolted to back wall.
Regarding the Lux's only use decent branded bearings which are available off the shelf.
Pain with the top oil seal.
