Author Topic: Which vice?  (Read 13717 times)
Offline The Steamer
Which vice?
« on: September 09, 2013, 08:28:52 AM »
So after window shopping for the past hour I'm still no the wiser as to which vice to buy!
Everything I see seems to be swivel base this rotate it around the sun 4 times kind of vice!
I'm after a half decent plain vice probably about 4" or so, unless you guys recommend otherwise
For the x2 mill.
Offline colin563
Re: Which vice?
« Reply #1 on: September 09, 2013, 09:07:26 AM »
I've got one similar to the 1st picture
Been using it a couple of years no problems
http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
Colin
Re: Which vice?
« Reply #2 on: September 09, 2013, 11:03:18 AM »
I have the 80mm second from the bottom , the top half comes off the base and can be used with no modification , milled a groove in mine and fitted a piece in a tight fit in the T slots , the jaws and the bottom all clocked up level and square .
Offline Arbalist
Re: Which vice?
« Reply #3 on: September 10, 2013, 05:30:47 AM »
Offline ParCan
Re: Which vice?
« Reply #4 on: September 10, 2013, 01:30:43 PM »
I also use the 2nd from the bottom.
80mm Radial Milling Vice.
Had to remake the strips under the slide. Not a big job.
As Chipinter says, just take the base off.
Some people put Dowels in the underside the same dia as the width of your table slots.
The Handle is also not the strongest, now use a spanner / wrench.
Re: Which vice?
« Reply #5 on: September 10, 2013, 01:45:33 PM »
Offline AussieJimG
Re: Which vice?
« Reply #6 on: September 15, 2013, 01:12:02 AM »
I have a collection of vices of various types but the ones I use most often are a couple of rail vices that I made myself.
They set up in seconds with a simple square and clock to less than 0.03mm across the width of the jaws consistently.
If I need more accuracy, I can tap them with a soft faced hammer or fit soft jaws in the holes I tapped in the jaws and then run the cutter over them.
Perhaps I should do a build thread on them and put up the drawings.
Jim
Re: Which vice?
« Reply #7 on: September 15, 2013, 02:02:42 AM »
Hmm, Build log and drawings, Yes please Jim. Yours look much like the small one that came with my lathe milling attachment (for my 7x12 clone before I got my X2 mill). I find this a tad on the small side in the mill and would like to make or get something more substancial for bigger jobs. I guess I could copy and scale up from my exisitng one BUT. If you already have drawings? :coffee: Plus I am sure others would benefit.
Thanks,
Re: Which vice?
« Reply #8 on: September 15, 2013, 04:42:11 AM »
..... rail vices that I made myself.
Jim
Some details please. :clap:
1) How do you prevent jaw lift? I see that the jaw is pretty swallow to start with and the screw is relatively high. That does the trick?
2) Do you have bearing ball between moving jaw and the screw?
3) How did you machine slots on  top of rails and keys on the bottom (if any) of the rails parallel?
Very interesting.
Offline Jonny
Re: Which vice?
« Reply #9 on: September 17, 2013, 03:45:27 PM »
Theres an element of anti jaw lift with these rebadged Vertex ones http://www.ebay.co.uk/itm/VERTEX-VA5-MILLING-MACHINE-VICE-5-130MM/350831281025?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1357459160492080341%26pid%3D100011%26prg%3D1005%26rk%3D5%26rkt%3D5%26sd%3D350831283820%26#ht_681wt_1170
Paid £75 same size from JLS on a sell off after breaking the other types above. Poor mans Kurt.
Two cheap bearings £4 delivered, recently put on the lead screw to casting has transformed it.
Offline AussieJimG
Re: Which vice?
« Reply #10 on: September 18, 2013, 05:04:14 PM »
Ok, I have done it! I have posted my first thread.
Video and drawings for my milling vice are at: http://madmodder.net/index.php/topic,9057.0.html
Jim
Re: Which vice?
« Reply #11 on: September 18, 2013, 10:54:48 PM »
Jim
The first step is the biggest and the hardest. There'll be no stoping you now.  :thumbup: :clap:
I had a look at it Jim and it looks like it will do the job it is intended to do.  :D
Offline AussieJimG
Re: Which vice?
« Reply #12 on: September 20, 2013, 01:40:58 AM »
Thanks Don, you are right: the first time is the hardest
Jim
