Author Topic: We'll Call it Metisse........  (Read 42361 times)
Re: We'll Call it Metisse........
« Reply #25 on: August 20, 2013, 04:49:10 PM »
Final assembly.....
I decided to re install the twin ball races, but with a 3mm wide spacer between.
This will give a wider bearing in each frame, and a boss, to position the outer wheels.........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030755_zps96453892.jpgWe'll Call it Metisse........
Fired up. Away she went, for 30 secs. Then ground to a halt! This happened several times.......
I finally realised, the crankshaft was insisting on migrating to the left, until it was too far out of alignment!  :bang:
So, I faced a spacer to give a .01" x 5mm dia step. (Inner race diameter). So, no rubbing during contact/ crank positioning.
This worked, sort of!  :scratch:
Nowt else for it. Bossed spacers, each side of the bearings!
Two, at 2mm wide, either side of the crank throws. Also the flywheel and disc spacers.
"Nil" end float now........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030758_zps99690493.jpgWe'll Call it Metisse........
The now unused, Maiwald burner fitted ok, after shortening the wick tube........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030757_zps4b95d5de.jpgWe'll Call it Metisse........
The hole for the threaded crankpin is tapped at an angle. I could have drilled, plugged, and re tapped. But!
Once in position, I bent the screw. Aligning it with, "Engineer's Eye". It works well........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030759_zps82b95800.jpgWe'll Call it Metisse........
All done........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030760_zpsca41045c.jpgWe'll Call it Metisse........
The video........
Not a valid youtube URL
That's another one sorted!
Thanks for watching........
« Last Edit: April 07, 2018, 05:22:59 PM by Stilldrillin »
« Reply #26 on: August 20, 2013, 05:16:09 PM »
Hi Dave
Nice little engine that one ... sweet ....
Another abandoned waif up and running    :thumbup:   What a hero ....   :med: :med:
How many is that now ???
Dave BC
« Reply #27 on: August 20, 2013, 05:30:04 PM »
Hi Dave
Dave BC
Hi Dave.
Thanks for that! It's had about an hour's running now. Faster and sweeter........  :thumbup:
How many? Sheesh!  :bugeye:
A quick run through my bookmarks gives around six, actual orphans, rehabilitated........
Also, several improvements to runners.
Just two, built from scratch. Plus two multi cylinder Mamods.
Possibly, seven inmates still waiting........
Hope I live long enough!  :palm:
« Reply #28 on: August 20, 2013, 07:29:14 PM »
It's good to see it running good well done!
« Reply #29 on: August 21, 2013, 02:00:34 AM »
The job is certainly a good un  :thumbup:
another one sorted  :ddb:
Well done Dave
« Reply #30 on: August 24, 2013, 09:49:20 PM »
Wonderful, David!  :thumbup:  :clap:  :clap: :clap: :clap: :clap: :clap:  (--- Sorry I've been away for holiday for a week -- or I would have applauded earlier)   It looks and runs great!
ps. I am curious -- do you think it was the leak from the loose cylinder, or the need for a smaller power cylinder that was the main problem?
« Reply #31 on: August 25, 2013, 02:30:28 AM »
Tom, Stew.
Thank you!  :beer:
VT.
Thanks! (I guessed you were away, due to the unusual silence).
There was no real leak, from the power cylinder, until I tried graphite lube. Then, there was no oil film, to seal the clearance........  :palm:
The ratio between cylinders was the problem. Anything less than 2/1 needs a lot of heat, for very little power output.  :smart:
Regarding reconstituted orphans, I think this is my best one yet...... Three hours on the clock, and the revs have climbed to a blurr, with no mechanical noise at all.
Really satisfying......  :thumbup:
Thanks, everyone, for your thoughts, and support.   :beer:
