Author Topic: Problems drilling a socket  (Read 9839 times)
Offline Chuck in E. TN
  • USAF Retired
« on: July 15, 2013, 12:45:10 PM »
 I’m in the process of making a Drawbar wrench/Hammer combination tool from a deep socket, a brass plug for a hammer face and an aluminum handle. I parted off the square drive end of the socket to reveal a round center. I soldered in a brass head and faced it square and turned it to match the diameter of the socket. Then I put the socket /head in my mill vice, found center and started drilling for the handle. I used a center drill first and started step drilling to the tap dia. for ½-13 thread for the handle. The first step drill went fine; the second just squealed and did nothing.
I have since tried to use an end mill and various other drills to get through the socket wall. Nothing will now touch it! What happened? Did I work harden the socket? Is this salvageable?
Chuck
Chuck in E. TN
Re: Problems drilling a socket
« Reply #1 on: July 15, 2013, 01:29:36 PM »
Chuck
Probably and locally to the hole I imagine and yes....
you could try a carbide cutter or else a die grinder to cut through the hardened bit... :dremel:
Mebbe someone else will chime in with a better solution if it isnt scrap... :scratch:
  • USAF Retired
« Reply #2 on: July 15, 2013, 01:55:22 PM »
I chucked the bugger up in the 4 jaw independant chuck, centered on the started hole and am slowly boring the socket big enough to thread the brass and have a sholder for the handle. I think I'm winning!
Chuck
Chuck in E. TN
« Reply #3 on: July 15, 2013, 02:30:34 PM »
Great news then Chuck?  :clap:
Offline tekfab
« Reply #4 on: July 15, 2013, 02:50:10 PM »
Chuck by name, Chuck by nature  ?
