Author Topic: PeterE's New Pin Vice  (Read 10580 times)
Offline PeterE
  • Gothenburg
« on: June 30, 2013, 09:18:44 AM »
Bored half to I don't know what, as I am currently recovering from a dislocated shoulder requiring operation (re-attach one of the ligaments among other things) I wanted to do at least something  :drool:
I decided that I needed a slightly larger pin vice than the small ones I have. So starting with a piece of 15x15 BMS I set it up for a long thin hole ...
http://i577.photobucket.com/albums/ss219/H0n3/Tooling/PinVices/PinViceTyp1-01.jpgPeterE's New Pin Vice
A lot of peck-drilling later the hole was 95 mm deep (at 3mm dia), which I the opened to 4 mm.
http://i577.photobucket.com/albums/ss219/H0n3/Tooling/PinVices/PinViceTyp1-02.jpgPeterE's New Pin Vice
The hole is the one through the handle which then was the next task. Removing the squareness and down to 12 mm dia there was a bit of knurling as well. After that I took the dia further down to 10 mm to fit my instrument vice and gave the bit some general clean-up.
Next on to the mill to make the jaws. A 12 mm dia slot drill made this short work started by a 10 mm through-hole. The "head" or jaws was also made rectanglurar by removing 3 mm down to 12 for better proportions. some more clean-up and it looked as follows.
http://i577.photobucket.com/albums/ss219/H0n3/Tooling/PinVices/PinViceTyp1-07.jpgPeterE's New Pin Vice
To finalize I added a screw with a wing-nut and slitted the top into jaws.
http://i577.photobucket.com/albums/ss219/H0n3/Tooling/PinVices/PinViceTyp1-08.jpgPeterE's New Pin Vice
Turned out fairly OK in spite of being done basically one-handed using the machines. Then test-fitted it in the vice.
http://i577.photobucket.com/albums/ss219/H0n3/Tooling/PinVices/PinViceTyp1-09.jpgPeterE's New Pin Vice
It will be a usefull addition to the tooling set I think.
BR
/Peter.
Re: PeterE's New Pin Vice
« Reply #1 on: June 30, 2013, 09:40:43 AM »
Hi Pete
Sorry to here of your bust shoulder , Very nice bit of one handed engineering  :clap: :clap: :clap:  very handy shop addition indeed  :thumbup:
Will you be drilling a hole in the screw so long work will pass through ?
Offline tekfab
« Reply #2 on: June 30, 2013, 09:51:33 AM »
Hi Pete
LOL !  Is that a new euphemism  . . . .  :D   :D   :)
Offline PeterE
  • Gothenburg
« Reply #3 on: June 30, 2013, 11:01:21 AM »
Thanks Rob, and yes, the screw will get a 2 mm cross-hole to let thin rods through.
BR
/Peter
<edit> Unfortunately your comment pass me by tekfab, this since my mother tongue is Swedish not English, and I am most certainly unaware of many dual meanings in English.
Sorry for that.
/Peter</edit>
« Last Edit: June 30, 2013, 05:02:26 PM by PeterE »
Offline Alan Haisley
« Reply #4 on: June 30, 2013, 11:59:24 PM »
Really nice piece of work, Peter. Is that instrument vise also your product?
Alan
Offline PeterE
  • Gothenburg
« Reply #5 on: July 01, 2013, 01:48:18 AM »
Hi Alan,
Thank you for kind comments.
Yes, I also made the instrument vice. It is based on a casting bought from College Engineering Supplies in UK and some bits from the box of useful stuff.
BR
/Peter
