Author Topic: How to wind a coil spring on a lathe  (Read 15020 times)
Offline DaveH
  • Kempton Park, South Africa
« on: June 25, 2013, 07:27:54 PM »
Hi,
If you have ever wondered how to a wind a coil spring here is a link that will show you how to.
http://www.metalworkingfun.com/showthread.php?tid=1441
Never know it could be useful.  :) I thought it was worth sharing.
Offline paulmo101
Re: How to wind a coil spring on a lathe
« Reply #1 on: June 26, 2013, 01:28:46 PM »
Hi Dave
Great video
Thanks
Offline Jonny
« Reply #2 on: June 26, 2013, 02:30:57 PM »
Nice find Dave but must point out that's only using spring or music wire ready hardened and tempered.
Same principle using proper steels then hardening after for more demanding applications.
To create a compression spring with known pitch just set power feed or screwcut pitch to suit, hopefully the pitch may stay the same.
« Reply #3 on: July 03, 2013, 03:29:15 AM »
Hi Dave,
            Thanks for showing the video, I have made springs on a lathe before, but only using hand power. The use of the vee tool, and using screw cutting feeds is very interesting and will try this method when I next need a spring.
