Author Topic: Taper Turning  (Read 13498 times)
Taper Turning
« on: June 10, 2013, 07:12:38 AM »
lordedmond
Re: Taper Turning
« Reply #1 on: June 10, 2013, 10:57:57 AM »
Good vid as usual there John
must admit it did look a bit hairy with the TS offset that much glad I have made a taper turning attachment for the Myford
keep em coming I always lean something not only some new words  :)
Stuart
Offline mechman48
Re: Taper Turning
« Reply #2 on: June 10, 2013, 02:04:28 PM »
Nice one John.. :clap:   :clap:   :clap:  It's nice to actually see I'm not the only one that has mishaps or drops the proverbial b*****k.. with the appropriate comments   :lol:  :lol:  super vids all the way  :thumbup:
George
George.
Re: Taper Turning
« Reply #3 on: June 10, 2013, 04:20:05 PM »
Keep them coming its the NE accent combined with the clanger that does it.
Offline Henning
  • Country: no
  • All the kit and no clue!
Re: Taper Turning
« Reply #4 on: June 11, 2013, 02:32:34 AM »
I learned a couple tricks here, not least the ball center thing! (And a few choice words with a great accent  :) )
I have to work on that accent, though.
Looking forward to the next one!
Henning
Offline S. Heslop
Re: Taper Turning
« Reply #5 on: June 11, 2013, 07:03:23 AM »
I was pleased to see those ball centres. I'd heard about offsetting the tailstock to turn tapers but must've missed the part about using ball centres, so I couldn't get my head around how it was supposed to work using regular ones.
Great video as always.
Re: Taper Turning
« Reply #6 on: June 11, 2013, 12:35:25 PM »
Another great production John.
How are you using the threading dial on an imperial lathe to cut a 2mm thread?
Re: Taper Turning
« Reply #7 on: June 11, 2013, 12:52:31 PM »
I normally reverse the lathe for metric
But for some reason 2 and 4 mill pitch work fine with the thread dial indicator
Offline paulmo101
Re: Taper Turning
« Reply #8 on: June 11, 2013, 01:56:34 PM »
Hi John
Thanks for another great video.
Keep em coming.
Paul
Re: Taper Turning
« Reply #9 on: June 11, 2013, 03:03:17 PM »
as per brill
Offline Pete49
Re: Taper Turning
« Reply #10 on: June 12, 2013, 12:26:30 AM »
John as usual I learnt more stuff.  :nrocks: It seems though that your workshop sound system has the same recordings as mine and if I could find it I would change the record. Seriously though I like the straight forward way you do things and react the same as most when it goes skew whiff. Probably why I learn a lot from you....thanks heaps
Offline garym
  • Manchester, England
Re: Taper Turning
« Reply #11 on: June 12, 2013, 06:15:12 PM »
Another informative video John. It is so much more helpful for beginners like me to actually see someone doing a particular job instead of reading it in a book.
Gary
Re: Taper Turning
« Reply #12 on: June 13, 2013, 06:27:43 PM »
Great video! Really enjoyed that one -- particularly using the ball bearings, making a polishing taper from scratch, using a zip tie as a lace, and really good reminder to keep checking the pressure on the tailstock! I'd like to make a polisher, too, so this one is right on the mark for me. Thanks again for your videos, John.  :thumbup:
Re: Taper Turning
« Reply #13 on: June 17, 2013, 12:49:42 PM »
Offline paulmo101
Re: Taper Turning
« Reply #14 on: June 17, 2013, 02:59:58 PM »
Thanks John - another great video.
Paul
