Author Topic: Shop press  (Read 14763 times)
Shop press
« on: June 08, 2013, 12:53:18 PM »
Afternoon Lads
I was using my press today ,had the camera out so thought I would take a few snaps . The press is home shop build from salvaged parts .
Its about 4 1/2 ft tall and 25 tonne .
The hydraulic pack is make from a railway crossing barrier motor/pump , this is 440v so I added a cap so it will run on single phase , the motor only runs when the lever is operated , I made the tank , the valve block is from a forklift truck , it was a 5 slice valve block that  I stripped and made it into a single .
Every  1000 psi is 5 tonne , the hose are fitted with quick connects so I can use it to power other things like my shop made rivet closer .
Basically a 6.3 tonne C clamp  :lol:  that I was using to close 3/8 and 1/2 rivets
« Last Edit: June 09, 2013, 04:29:43 AM by RobWilson »
Re: Shop press
« Reply #1 on: June 08, 2013, 02:31:57 PM »
Strewth !!! You don't half like grunty tackle ...  :)
Not done so well with the fag packet though has it ???   :lol:
Or are they 6.4 tonne tabs ???
Dave BC
Re: Shop press
« Reply #2 on: June 08, 2013, 03:19:53 PM »
I remember the day Rob pressed a crank shaft together for me  :lol: :lol: :lol: :lol: :lol:
This press is the dogs watsits
I have never seen the rivet closer working but I have seen the results  :bow: :bow: :bow:
Re: Shop press
« Reply #3 on: June 09, 2013, 03:31:50 AM »
 :lol: :lol: :lol: Dave , I do like big lumps of steel  :palm:
A couple of shots of my ruff and ready bender .
Just made from three bits of angle welded to a bit plate to form the vee , bends 1/2" x 6" wide plate a treat , one day i will get round to making a more elegant version .
I also have a couple of hydraulic motors  ready for when I decided to make a set of rolls  :proj:
Re: Shop press
« Reply #4 on: June 09, 2013, 06:11:11 AM »
I'm feeling all inadequate. Again!  :palm:
Nice kit. Rob......  :thumbup:
Re: Shop press
« Reply #5 on: June 09, 2013, 04:33:29 PM »
see it is a tardis when you think you have seen all his tooling out pops sumthing new
Re: Shop press
« Reply #6 on: June 09, 2013, 05:22:41 PM »
Hi Rob , that press is top notch, one of my items I hope to build in a future project...........how did you come across a railway barrier motor  :scratch: ................. or am I better off not knowing lol.
  Cheers Mick.
Re: Shop press
« Reply #7 on: June 09, 2013, 07:59:04 PM »
Makes my Atlas screw press look a bit anemic. Actually even a car jack does that to it!
Quite a shop, Rob!
 :thumbup: :clap:
Offline Kjelle
Re: Shop press
« Reply #8 on: June 10, 2013, 09:34:40 AM »
Everytime Rob shows off some of his work, I get a bad case of tool and skill envy....
Kjelle
Offline NeoTech
    • Roughedge Hobbyworks
Re: Shop press
« Reply #9 on: June 10, 2013, 09:57:07 AM »
Isnt the trick to take that energy creating the envy and create a tool..? ;)
Re: Shop press
« Reply #10 on: June 12, 2013, 02:13:01 AM »
Hi Rob,
                     Nice bit of Horological kit you got there, ideal for fitting wheels to arbors.
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
Re: Shop press
« Reply #11 on: June 14, 2013, 03:40:56 AM »
That is one mean nutcracker setup!
If it works, take it apart and find out why!
Re: Shop press
« Reply #12 on: June 16, 2013, 04:36:26 AM »
Hi Rob , how did you come across a railway barrier motor  :scratch: ................. or am I better off not knowing lol.
  Cheers Mick.
Hi Mick
When leaving the village on my way too work one morning I noticed some lads changing the railway barriers , with my eagle eyes   and the fact that they had the covers off the barriers I noticed that they had hydraulic units in them , so pulled my van over ,had a bit crack with the lads and asked if i could have one , they said sure they are getting scrapped  any way so out comes my spanners from the van and five minutes later i was on my way with one of the pump units  :) shy bairns get nowt .
Offline Mayhem
  • purveyor of mischief
Re: Shop press
« Reply #13 on: June 16, 2013, 06:00:07 AM »
Now you have spoiled it for me Rob - here I was picturing some poor sod stuck at the level crossing for three days waiting for the barrier to lift up!
