Author Topic: Sawed off cupola  (Read 188559 times)
Re: Sawed off cupola
« Reply #75 on: June 05, 2013, 02:15:03 PM »
The bracket and bolt welded in place.
« Last Edit: January 06, 2018, 04:58:53 PM by vtsteam »
« Reply #76 on: June 05, 2013, 02:17:37 PM »
Cupola with lid swung out of the way, and showing the lever extension. Might be a little long, but depending on how hot that furnace and lid is, might seem a little short!
We have rain predicted for the next three days, so that should slow things down a bit.
« Last Edit: January 06, 2018, 04:59:31 PM by vtsteam »
« Reply #77 on: June 06, 2013, 11:48:31 AM »
Looks like your getting close to the finishing line Steve
I like the lid lift arrangement   :clap: :clap: :clap:
« Reply #78 on: June 06, 2013, 04:35:37 PM »
Thanks Rob!
Luckily the rain held off today, and I was able to work on the belt clamp.
First I cut up another piece of that pallet to make brackets:
« Last Edit: January 06, 2018, 05:00:15 PM by vtsteam »
« Reply #79 on: June 06, 2013, 04:40:24 PM »
Then welded two of the brackets to the furnace base:
« Last Edit: January 06, 2018, 05:00:57 PM by vtsteam »
« Reply #80 on: June 06, 2013, 04:45:35 PM »
Then I bent a strap out of 1/8" x 2" and welded the other two brackets to that:
« Last Edit: January 06, 2018, 05:01:38 PM by vtsteam »
« Reply #81 on: June 06, 2013, 04:49:51 PM »
The strap and base before adding the barrel:
« Last Edit: January 06, 2018, 05:02:47 PM by vtsteam »
« Reply #82 on: June 06, 2013, 04:53:49 PM »
And the barrel bolted in place:
« Last Edit: January 06, 2018, 05:03:29 PM by vtsteam »
« Reply #83 on: June 06, 2013, 05:00:31 PM »
The furnace mostly finished:
« Last Edit: January 06, 2018, 05:04:14 PM by vtsteam »
« Reply #84 on: June 06, 2013, 05:12:03 PM »
Because the welding was finished, I moved the cupola up to where it will be tried out. I live on steep ground, so I wanted to get it up there before it started to rain because even the tractor won't make it in mud. We have heavy rains predicted for 2 days. It is supposed to clear up Sunday.
The next job is filling the lid with refractory. I found some lightweight fire brick given to me many years ago by a friend who was rebuilding a kiln. The lid will be quite heavy, since it's 4" thick, so I thought I'd break these up into chunks and plaster them into the mix to lighten it up.
I'll leave a 1" thick layer of pure fireclay and sand as a hot face, since these brick aren't rated at as high a temperature, I believe.
« Last Edit: January 06, 2018, 05:05:02 PM by vtsteam »
« Reply #85 on: June 06, 2013, 05:21:48 PM »
I had a 1/4 bag of fireclay that was in a storage area that was recently flooded with an inch of water. The clay was probably a perfect consistency for making pottery, but poor for mixing with sand to make refractory!
I spent about an hour kneading in sand by hand, then switched to the riddle and put it through that twice using a firebrick as a muller. That was a lot of work!
Finally it seemed to be mixed and stick together reasonably well. I covered it and put it aside, even though I really wanted to ram up the lid. But with rains imminent, I knew that firing it wouldn't protect it, since I couldn't cover a hot lid with plastic sheet, and I could imagine trying to save the whole thing at night in the rain. Bad idea. So, uncharacteristic patience for me -- I put the furnace aside until Sunday.
« Last Edit: January 06, 2018, 05:07:36 PM by vtsteam »
« Reply #86 on: June 09, 2013, 05:46:18 PM »
It's Sunday finally, our one day of sun predicted before we return to rains until Wednesday. Couldn't get much done because of a retirement party for a friend and neighbor this afternoon, but did work on the lid.
Here is the bare metal ring and some scrap reinforcing:
« Last Edit: January 06, 2018, 05:08:32 PM by vtsteam »
« Reply #87 on: June 09, 2013, 05:48:41 PM »
Cutting up soft firebrick with an old pruning saw (never worked well on wood). Cuts quite easily. The bottom of the lid was rammed up first with about 2 inches of refractory before adding the brick:
« Last Edit: January 06, 2018, 05:09:31 PM by vtsteam »
« Reply #88 on: June 09, 2013, 05:50:03 PM »
Checking the brick for fit. The spray can is there to provide a form for the exhaust hole.
« Last Edit: January 06, 2018, 05:10:10 PM by vtsteam »
« Reply #89 on: June 09, 2013, 05:55:37 PM »
The fire brick was mortared in place with premixed "refractory cement" mixed with Perlite. I had both left over for a few years from other projects. Neither is a super high temp product, but I hope that the 2" of fireclay and sand refractory below will keep the upper portion of the lid within a reasonable temperature range.
I hoped that the refractory cement would provide a better bond to the brick and steel. It contains sodium silicate and fireclay and some kind of non-asbestos fiber. Sticky stuff.
I hoped the perlite would help lighten the lid (as would the insulating firebrick).
Guess we'll find out.
[/URL]
« Last Edit: January 06, 2018, 05:10:48 PM by vtsteam »
« Reply #90 on: June 09, 2013, 05:58:05 PM »
Cooking the lid:
[/URL]
« Last Edit: January 06, 2018, 05:11:19 PM by vtsteam »
« Reply #91 on: June 10, 2013, 11:55:26 AM »
Nice work Steve  :thumbup:
You must be dam close to a test run  :headbang:
« Reply #92 on: June 10, 2013, 01:01:12 PM »
Not too close yet Rob. I need proper tuyere attachment, patching lining (it's taken a beating with all the metal work and moving), make pouring shank, need to mix iron molding sand, make ingot molds, make blower /motor assembly, test fan output, make skimmer, line ladle, make more charcoal, break up and clean iron pieces, get weights for flasks, figure out a ladle heater. Seems like there's a never ending list ! And it will be raining through Wednesday. I'm going to guess a week 'til I get a nice hot ladle full of slag!!
 :lol: :lol: :lol: :lol:
« Reply #93 on: June 10, 2013, 08:47:31 PM »
Decided as long as it was raining today I'd take an hour drive down to a town in Massachusetts that has a pottery supply business, and buy some silica sand. It's getting hard to find, and expensive for the real stuff because of health concerns.
They had the pure stuff in #60 mesh. I had read a recommendation for #70 from Stewart Marshall, but 60 was all they had. So I bought 200 lbs of it and trucked it back. Brought plastic bins with me to keep it dry.
I'm going to use Ironman's mix of 85% sand, 7.5% Bentonite, 3.5% coal dust (I might have found a source for some coal I can pulverize -- but can I substitute charcoal dust?), and 4% water.
Ironman's video:
(Ironman, if you read this, is this greensand composition by weight or volume. I'm assuming weight. Thanks!)
« Last Edit: January 06, 2018, 05:14:05 PM by vtsteam »
Offline Swarfing
« Reply #94 on: June 11, 2013, 03:04:47 PM »
Vsteam not sure about your side of the pond? but a good source for silica sand is the stuff they use for brushing in between block paving. Here it is qute fine and i use it with good results
Once in hole stop digging.
Offline ironman
« Reply #95 on: June 11, 2013, 08:38:51 PM »
vtssteam It is by weight. The coal dust burns and slightly lifts the metal of the sand to give it a smooth surface. Coal dust may be hard to find so you could use other things that burn ie. sawdust or wheat flour.
« Reply #96 on: June 11, 2013, 09:23:54 PM »
Thank you Swarfing, I will look into that for silica sand.
Ironman, would powdered charcoal work? That would be easy to get/make. I'd prefer not to use other things like flour and sawdust that can decompose.
I could carbonize sawdust -- I have quite a bit of that from my homemade sawmill.
« Reply #97 on: June 12, 2013, 03:46:53 AM »
Recalling something I read in one of my early foundry books, I think the coal is added to stop 'blistering' where the sand fuses to the cast. If I remember correctly the coal dust breaks down forming a gas layer that cushions the sand from the metal. Also improves surface finish.
If the above is correct powdered charcoal wouldn't work as the gases have already been driven off.
« Reply #98 on: June 12, 2013, 07:45:56 AM »
Thanks awemawson, I think the gas involved is CO2 or CO so any of the above might work.
« Reply #99 on: June 12, 2013, 09:48:40 AM »
Google "why is coal added to foundry sand" There are many references to the coal partially burning and off gassing organic compounds - here is one on wikipedia
http://en.wikipedia.org/wiki/Molding_sand
My feeling is charcoal won't work as the majority of the organic stuff has been driven off in the making process.
