Author Topic: Junk yard project ,media blasting , pressure pot  (Read 35043 times)
« on: May 05, 2013, 11:44:41 AM »
Afternoon Lads
Woke up yesterday with an itch I needed to blast  and now that my welding shop is sort of usable I thought I would do a bit fab work and make a pressure pot for blasting , there is no way I would pay close too £200 quid for one , mine will cost me about £2 quid and thats for electricity ,cos I cant make that LOL
Mine will be made from free junk parts , scrounged and given , John donated the tank from an old compressor  :thumbup:
Cleaned up the tank , cut off all brackets.
Cut down a 3" BSP lump of SS pipe for the filler and threaded up a short length of 1/2 pipe .
Cut a hole in one end of the tank for the filler .
and welded the filler neck in ,using dissimilar welding rods .
Then made up a trolley from an old sack barra and welded that to the tank , with all the welding to the tank done I gave it a hydraulic test .
Full of water .
Hand pump
Tested to 220 PSI , I will be running the tank at about 90 PSI
All being well it was given  a bit of a paint job
Still needs another coat of paint ,then I can get the pipe work fitted .
Re: Junk yard project ,media blasting , pressure pot
« Reply #1 on: May 05, 2013, 11:49:21 AM »
Nice job Rob,  :clap: :bow:
but yer welding looks like pigeon ****.....(not!!!)
What blast media you going to use?
I use garnet ( free from work) or chilled cast iron ( again from work) or ally oxide...
Ideally a tungsten tip is best, I found the ceramic ones dont last... :scratch:
« Reply #2 on: May 05, 2013, 11:54:28 AM »
 :lol: :lol: Thanks John
Garnet ,,,,,,,,,cos I can get it free  :med:
Thinking about making my own nozzles and gun , as I can seam to fine any local .
« Reply #3 on: May 06, 2013, 05:23:04 AM »
Rob,
Where is the blast media exiting the tank? :scratch:
I dont see a tee at the bottom...
Are you going to use a water trap/filter on the inlet?
What size compressor you going use? (let me guess, you got a second hand 90cfm diesel compressor from work for free... :lol: )
Waiting to see what creations you come up with for a gun/nozzles
« Reply #4 on: May 06, 2013, 08:35:13 AM »
Hi John
From the bottom mate were I had the high  pressure hydraulic line fitted for testing the tank .
I have a water trap fitted to my shop air pipe work , but I am still thinking of fitting one to the pot when I fined one , thought I had found one the other day ,
Pile of junk ,,,,,,,,,,,,cant resist ,,,,,,,,FREE STUFF
wanders over  :ddb:
Nice water trap/reg and oilier
Shame its 1/4 BSP no good for this project ,but  it will do nicely for a power draw bar on the CNC mill ,also got a bunch of other useful tackle from the pile  :med:
 I have a 15 Cfm compressor works fine with my siphon blast cab , ist not like i am blasting for hours at a time ,I do have a spare 15 pump and motor unit I could add to the system if necessary  .
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #5 on: May 06, 2013, 08:48:45 AM »
One mans crap pile another mans treasure.. that didnt come out right did it...  :scratch:
« Reply #6 on: May 06, 2013, 08:53:56 AM »
 :lol: :lol: :lol: close enough  :lol: :lol: :lol:
« Reply #7 on: May 06, 2013, 11:02:36 AM »
i can not resist having a rumige  well dun rob  :thumbup:
« Reply #8 on: May 06, 2013, 01:37:13 PM »
Cheers Bob  :beer:
Well got the pluming done today and not much else well apart from inspecting and building sand castles  :lol:
The tee is plugged were the blasting hose will go as I was testing the pipe work  for leaks . Jobs a goodin suppose I better think about making a gun . Think I will make a bigger better blasting cabinet too  :dremel:
« Reply #9 on: May 06, 2013, 02:30:40 PM »
Great looking job Mate
Is that the floor of your welding shop I can see  :lol: :lol: :lol: :lol: :lol: :lol: :lol:
« Reply #10 on: May 06, 2013, 03:08:28 PM »
Looks like a crackin good job mate. You should pop that gague off and give it to Bob. I bet he could make it look like new in short order. Thanks for sharing it with us.  :D :D
  • Country: za
« Reply #11 on: May 06, 2013, 03:08:36 PM »
Very nice  :clap: :thumbup:
« Reply #12 on: May 06, 2013, 03:47:05 PM »
that wood look beter in blue well dun do you need a flow meter for a mig welder
« Reply #13 on: May 06, 2013, 04:20:59 PM »
Hi Rob , that looks double smart lad  :thumbup: :bow: :clap: , you got that project done super quick too. It also looks like it wont take much space up , always a bonus !
 Cheers Mick.
Offline Mayhem
  • purveyor of mischief
« Reply #14 on: May 08, 2013, 09:28:38 AM »
I've go to stop looking at your projects Rob, as they give me ideas and feelings of indiquicy  :bow:
Top job and looking forward to seeing this progress (unlike the cupola and the CNC refit but I won't mention those  :poke:).
What is the reason for welding the filler to the neck with dissimilar rods?
« Reply #15 on: May 08, 2013, 11:50:17 AM »
Here's my set up....
A few piccies of my pot, compressor, I've just finished doing some coz the valve has hole worn by the media and you can see the nozzle has a slot cut up its side.....
« Reply #16 on: May 17, 2013, 03:37:40 PM »
Thanks for the comments  Lads  :beer: and  apologies  for the slow reply ,,,,,,,,,,,,,,,,LIFE GETS IN THE WAY SOMETIMES  :Doh:
LOL  thanks Mayhem ,,,,,,,,,,,,, I used dissimilar rods as the tank is carbon steel and the filler neck is stainless steel  :zap:
Hi John ,, I like the look of your blasting gun , I am shure I could knock one of those up to morrow , I got a couple of sample 25kg bags of media today , may give the setup a try out tomorrow
Thanks Rob
« Reply #17 on: May 17, 2013, 04:15:09 PM »
hi rob don't no if this is any good but i have been geting bags of sand from work its not bilding sand its sand that they put in the oven at work for drying the pant i have being puting it on me drive to fill in the gaps and im gowing to see wat tis like with a bit of cement mixt in to it it seem to have a uiniform grane sise you can cum and pic sum up if you wont
« Reply #18 on: May 17, 2013, 04:24:40 PM »
Hi Bob ,thanks for the offer but,
If ist silica sand  then its not safe for sand blasting , just so the lads  should be aware Silica sands , beach , building sands are not safe for blasting , when blasting they break up and release free silica partials , which when inhaled will cause a horrible lung disease called Silicosis .RIP.
« Reply #19 on: May 17, 2013, 04:41:08 PM »
If it's silica sand  then its not safe for sand blasting , just so the lads  should be aware Silica sands , beach , building sands are not safe for blasting , when blasting they break up and release free silica particles , which when inhaled will cause a horrible lung disease called Silicosis .RIP.
Err its also illegal to use sand for blasting if the Council get to know about it...
I have it on good authority,You could be prosecuted...
« Reply #20 on: May 17, 2013, 04:51:07 PM »
i don't think its silica sand i will av a reed on the bags thay have at work its rathe expensiv stuff its over £10 a bag its bin kleend and washt then oven dryed  well you no me if its bin thrown out i will av it if i have a yous for it
« Reply #21 on: May 17, 2013, 04:58:08 PM »
Never new it was illegal John ,,,,,,,,,,,,shame they dont make smoking illegal
Bob ,,,,,,,,,, sounds like the sand may be just the job for core making  :thumbup:, save is a bag mate  :poke:
« Reply #22 on: May 17, 2013, 05:50:45 PM »
will do
