Author Topic: Miniature Tool Collection  (Read 135766 times)
Offline flyingtractors1
Re: Miniature Tool Collection
« Reply #225 on: May 16, 2014, 09:00:05 PM »
Hi vtsteam.  What a coincidence, really.  I have a small collection of such table vices and like them plenty, so I decided to build a miniature model and document the procedures required to build one.  The lengthy pictorial and video are posted further up this string.  It was quite an exercise with many and complicated operations which tested me thoroughly.  I sure am glad to have it my collection.   Ralph
« Reply #226 on: May 25, 2014, 03:22:45 PM »
And now there are Two.   Ralph
« Reply #227 on: June 17, 2014, 09:10:12 PM »
I have been pondering the idea to build a miniature model of an old timey car / wagon jack and have looked for a full scale model or suitable pictures for quite some time but have not yet found one like the one I remember from days gone by.  As I remember, it did ratchet up mechanically, and a small click lever held it up while the handle was lowered to ratchet up another stroke.  It worked similarly in the lowering mode.  But I have been unable to visualize the the relative components and mechanical interaction of that jack and decided to build a model of one that I could visualize and whose picture I found on the net.
I did not photo document the build process since its design is very straight forward as evidenced by the finished model.  And yet its operation is quite sophisticated in that the effort and resistance arms are configured on different planes and anchored on an elbowed fulcrum point allowing it to lock-over at the completion of the stroke.  I didn't invent this mechanical marvel - only learned to appreciate it more as I attempted to create a miniature version.
Since this model was built entirely from bar stock (brass), and no cast parts were used, it is noteworthy that it required some complicated and delicate silver soldering operations.  On various parts, several soldering operations were performed in sequence employing different solder hardness under carefully regulated temperatures so that one soldering operation would not cause prior joints to overheat and fall apart.  Several times I messed up and had to start over.
This was a challenging project that helped me better appreciate mechanical relationships and learn torch temperature control.
Comparative scale:
Online tom osselton
« Reply #228 on: June 18, 2014, 04:26:58 PM »
Nice job I always look forward to see what you will undertake as a build.
Offline ieezitin
« Reply #229 on: June 18, 2014, 05:23:48 PM »
Ralph...
As always i enjoy your posts. This one is a knockout. :clap:
I can appreciate the the challenge in making this small wonder, i thoroughly understand your view about its mechanical action, very attractive.
Thank you for spreading your work on the net for all to see.
Anthony.
« Reply #230 on: June 18, 2014, 11:02:15 PM »
Thanks, Gents.  This model is so deceivingly simplistic that a picture of it can hardly reveal its true complexity and the fabrication challenge that it posed - especially at this scale.  I appreciate your observations.   Ralph
The action video is now up on Yoytube:
« Last Edit: June 19, 2014, 01:14:58 AM by dsquire »
Offline greenie
« Reply #232 on: June 19, 2014, 10:36:25 AM »
greenie, I am sorry that you lack the experience and wisdom to appreciate the difference.  Ralph
« Reply #233 on: June 19, 2014, 02:33:32 PM »
Hi Ralph
                   An interesting little project, it is nice to to make something like this, which has a historical background. The video and commentary explained the lifting principles very well.
        Cheers  David
Offline ieezitin
« Reply #234 on: June 19, 2014, 05:45:59 PM »
Great video.
I got a railroad jack as you know once you have maxed out the lever a ratchet pings into place then the next push on the lever indexes it up one more run, this must of come after that design your portraying..
nice to learn about the history of it.
Thank you
Anthony.
« Reply #235 on: June 19, 2014, 06:14:45 PM »
Thanks Anthony.  As I wrote above, the jack that you describe is the type that I was originally looking to build but have not found a model to pattern after.  Would it be possible for you to post pictures showing the operating mechanisms of the one you just described.  As I remember, some had a small removable plate on one side that hid the internal mechanisms.  I would need a picture  of the mechanisms in there.   Ralph
Offline ieezitin
« Reply #236 on: June 19, 2014, 07:38:06 PM »
Absolutely..
you will have pictures by Sunday this weekend.. i will take them and show you scale..
glad i can help.
Anthony
« Reply #237 on: June 24, 2014, 03:55:23 AM »
you may be interested in Bill Robertson's new forum dedicated to fine miniatures:
www.fineminiaturesforum.com/
« Reply #238 on: June 25, 2014, 04:07:36 PM »
Thanks for the word, Bill.  It seems to have promise of being a nice forum.   Ralph
« Reply #239 on: July 07, 2014, 09:47:44 AM »
I have a good start on the next project, a compound mechanical lever lifting jack.
Parts and pieces are cut from flat brass flat stock.   Ralph
Offline ieezitin
« Reply #240 on: July 07, 2014, 06:20:01 PM »
Ralph..
Looks like your off to a good start… That jogged my memory.
I apologize to you for not taking Photographs of my railroad jack like I promised, I am on the road right now, and far from home I will stick you in my To-Do-List on my tablet now which will remind me this weekend to do that for you.
Anthony.
« Reply #241 on: July 13, 2014, 04:22:34 PM »
Progress.  Ralph
Silver soldering can be a trick when several operations are conducted on a piece requiring careful heat regulation so as not to undo a joint with subsequent operations.
Doing everything by hand is tough and tedious.  A mill sure would have come in handy for this project, but I am well acquainted with jewelers saws and files.
« Reply #242 on: July 26, 2014, 11:16:51 AM »
Some progress.   Ralph
« Reply #243 on: July 26, 2014, 12:22:11 PM »
Hi Ralph
                  The Jack is coming on nicely, keep up the good work.
« Reply #244 on: July 26, 2014, 05:06:43 PM »
That's looking really good, Ralph!  :thumbup: :clap: :clap:
« Reply #245 on: July 28, 2014, 03:07:07 PM »
Thanks, Gents.  When building miniatures, sometimes the small "smaller" parts can be most challenging.   Ralph
« Reply #246 on: July 30, 2014, 11:03:23 AM »
The compound mechanical lever jack is about finished - may need some tweeking and polishing.   Ralph
A comparative scale
See the action video on Youtube:
« Last Edit: July 30, 2014, 10:15:25 PM by dsquire »
« Reply #247 on: July 30, 2014, 11:25:03 AM »
Very nice  :bow:
I was using a very similar one to remove the wheel of my tractor a couple of days ago, but that was rated at 10 tons !
« Reply #248 on: July 30, 2014, 07:43:54 PM »
Looks great!  :clap: :clap:
« Reply #249 on: July 30, 2014, 10:27:34 PM »
Ralph
You continue to impress me with your ability to work with such precision at such small size's. Thanks for sharing with us.  :D :D
