Author Topic: Steam Turbine Car  (Read 30808 times)
Offline prallplatte
Steam Turbine Car
« on: April 26, 2013, 04:37:00 PM »
Well, itīs going on:
My TedRobot inspecting the new enterprise:
Overview:
Sketch:
The turbine:
....will be continued
Regards - Kurt
...watch my channel:
http://www.youtube.com/user/prallplatte
Offline prallplatte
Re: Steam Turbine Car
« Reply #1 on: May 01, 2013, 01:01:01 PM »
Oh Hilde, Labour Day: Continuing with my cars:
Turbine with flywheel:
Tank clutch:
Regards - Kurt
Offline slowcoach
« Reply #2 on: May 01, 2013, 04:40:48 PM »
Looking good  :thumbup: can't wait to see and hear it run  :headbang:
Rob :thumbup:
Offline prallplatte
« Reply #3 on: May 03, 2013, 04:09:15 PM »
Thank you!!
So, tonight i was feeling generous at times, test run the turbines: Half ceramic vers. full ceramic bearings. Half ceramic wins!
I guess that it was the plastic cover of the full ceramic. Which are apparently heat sensitive. The turbine slowed down after 20 sec steam. So tentatively extended. Were naturally bonded with Loctite 648th
The result?
Remember: 60 EUR! (= 6 boxes Radeberger bear!) later:
Tomorrow i make the next test run. If it should not have been the ceramics, i melt the whole project!
Regards - Kurt
« Reply #4 on: May 03, 2013, 05:28:58 PM »
Hi Kurt.
That is looking good! A project easily recognised as "Yours".  :thumbup:
Hope tomorrow's test goes ok. With no disaster!
Looking forward to another one of your, adventure videos.........  :D
Offline prallplatte
« Reply #5 on: May 05, 2013, 03:22:26 PM »
Tank you!
And now: some noise:
(Edited youtube link. David D)
« Last Edit: May 05, 2013, 03:49:08 PM by Stilldrillin »
Regards - Kurt
« Reply #6 on: May 05, 2013, 04:23:24 PM »
Looks like it passed the test today. I didn't see any pieces flying. Any idea of what RPM you were able to reach?  :D :D
Offline slowcoach
« Reply #7 on: May 05, 2013, 04:46:56 PM »
Wow it really screams. Awesome stuff  :clap: boiler does its job really well keeping that turbine running  :bugeye:
Rob  :thumbup:
« Reply #8 on: May 06, 2013, 03:37:43 PM »
well dun brill :thumbup:
« Reply #9 on: May 06, 2013, 03:57:18 PM »
Nice work  :thumbup: , I can't wait to see it runing  :drool:
 Cheers Mick.
Offline prallplatte
« Reply #10 on: May 07, 2013, 05:34:27 PM »
Thank you all!
Looks like it passed the test today. Any idea of what RPM you were able to reach?
Yes, big relief for all.  :thumbup:
RPM Turbine is 11.000, and 2.500 at the output, at last 1.200 on the wheels.
Best regards
Kurt
Regards - Kurt
« Reply #11 on: May 07, 2013, 05:43:24 PM »
Very nice
Great sounds
I have had a bit play with gas turbines
The sound is addictive
Offline prallplatte
« Reply #12 on: May 08, 2013, 01:53:50 PM »
Well, that was something! Just had a test run. With reinforced spring in the clutch. And new gear reduction 1:4. And 1 kg of lead weight for the lacking aluskin.
First the good news:
- The clutch works!
- The racing car - and it's really one - sprints with about 8 km / h as devil. Even uphill! Madness!
Now the other side:
- Turbines also appear to be sensitive to water hammer. The steam dome - if one can even speak of it, is more of a tiny dome - and is backwards. When starting up there is water in the pipe, and indeed not even a little. Since I have still no superheater, the water comes in as 1:1 into the turbine. Now I have an ugly noise in that part, metal on metal. The revision will show. Pray with me ...
- The RC and the receiver are going to be melted. Denial of service. But i have enough spare spot.
- The butane tank temperature is a minor problem. But not a real one.
What remains to be done:
- Installing a superheater and hope that the turbine / bearing withstands the temperature. Furthermore, that the present performance remains despite then superheated steam (= less kinetic energy).
- Installing a three gear clutch. I have to extend one of their axes. Toi toi toi!
Regards - Kurt
Offline prallplatte
« Reply #13 on: May 09, 2013, 03:46:45 PM »
Instead of drinking for Father's Day today in Germany I have built the superheater, model immersion heater - cozy after the melting of the FB. Test follows.
Regards - Kurt
lordedmond
« Reply #14 on: May 10, 2013, 02:36:31 AM »
 Keep your eye on the copper super heater they burn out real quick
a better solution is stainless steel tube use for hypodermic needles ( vetenary ) that what I use for my loco's
for info I use 8 elements bent up like a trombone of 5/32 dis. this can be bent to a .5 inch rad with tube bender
good work on the cars I do like the Audi
I am interested in your forum name translated its baffle plate , maybe its got lost in translation from German
Stuart
« Reply #15 on: May 10, 2013, 03:42:24 AM »
....I am interested in your forum name translated its baffle plate , maybe its got lost in translation from German
Stuart
I checkked that handle as well first time I saw it here, and whereas it seems to have very many translations and google does not help much  :lol: I reasoned that most likely possibility could be louvre panel, specially the one at front of the car?
PekkaNF
O.T enjoyed very much YT links, they show some serious multi talent straits.
Offline prallplatte
« Reply #16 on: May 10, 2013, 07:07:10 AM »
Thank you,
i will change the copper if it works and use stainless steal.
Forum name: in my case, it means impact plate and was developped in the end of 2006 (go to 3:05)
 :zap:
Regards - Kurt
Offline prallplatte
« Reply #17 on: May 10, 2013, 11:11:16 AM »
The idea of uncontrolled overheating was actually not effective, unfortunately. New ball bearings are already on the way, and once I have a buyer for my gardeners kidneys, i buy also a new turbine. Since the whole desaster is still quite hot, i will only be able to report in a few hours from the full extent of the damage. After all, the house is still standing. And nobody hurt, apart from the psychological damage.
Water hammer is still working excellent. Thanks to the 1-meter superheater line right now like a flash. Probably acts as a cannon: the longer the pipe, the greater the V zero.
In all the ruins i also found some consolation: because of advice i now have a copper wire in the water level glas: no more bubbles, display works perfect.
And now? Steam dome increase / relocate or build steam collecting drum i cant. I do not need drainage at the beginning, since then nothing is compressed. A half full boiler in the beginning stays as a little result.
Or melt down. Speaking of melting: I previously preferred way less elegant methods: (here 1:45 min.)
Regards - Kurt
Offline prallplatte
« Reply #18 on: May 18, 2013, 02:31:55 PM »
My anti-water hammer bypass almost naked:
and attracted ...:
Works fine!
btw: I can now also extend waves:
Regards - Kurt
Offline prallplatte
« Reply #19 on: May 20, 2013, 02:42:56 PM »
Hilde on Alu (Kiellegung):
The mystery picture??
Regards - Kurt
Offline prallplatte
« Reply #20 on: June 02, 2013, 05:31:34 PM »
... some hours later:
Its now 2 meters long. Stay tuned...
btw: why did i call the projekt "The Needle" ?
Well:
Regards - Kurt
Offline prallplatte
« Reply #21 on: June 14, 2013, 07:58:35 PM »
3 km of harness: I'm going crazy. But nothing helps: pure he must, even if we both cry ...:
Regards - Kurt
« Reply #22 on: June 15, 2013, 02:01:47 AM »
A large, beautiful project Kurt.  :clap: :clap:
Keep up the good work!  :thumbup:
Offline Bangkok Mick
« Reply #23 on: June 15, 2013, 08:00:25 AM »
great looking project
Offline Kjelle
« Reply #24 on: June 15, 2013, 05:25:16 PM »
 :bow: :clap: :drool:
Kjelle
