Author Topic: Fixing up an old milling vice  (Read 70167 times)
« on: April 15, 2013, 07:50:31 PM »
I was given this mill vice with the second hand mill/drill I bought a couple years ago. Scraped some of the crud off and read "Victor Boston" There was no handle, and no jaws.
Some divots, too.
« Last Edit: January 07, 2018, 04:51:41 PM by vtsteam »
Re: Fixing up an old milling vice
« Reply #1 on: April 15, 2013, 07:58:56 PM »
I read Darren's thread about electrolytic rust removal, so I figured I'd give it a shot. Bought some Arm and Hammer washing soda (sodium carbonate) and put a half cup of it in some water.
Used a piece of 1/2" rebar as a positive electrode, and wrapped a piece of steel wire around the vice to attach to the negative electrode.
« Last Edit: January 07, 2018, 04:52:31 PM by vtsteam »
« Reply #2 on: April 15, 2013, 08:03:44 PM »
Connected my auto battery charger and watched the bubbles start to form. Best position for the positive electrode seemed to be parallel with the vice and directly over it. The action does seem to be somewhat directional.
« Last Edit: January 07, 2018, 04:53:08 PM by vtsteam »
« Reply #3 on: April 15, 2013, 08:15:28 PM »
I checked back in a couple of hours. I couldn't see anything in the brown water, so I just pulled it out and hosed it off.
Here's what it looked like!  :ddb:
« Last Edit: January 07, 2018, 04:54:09 PM by vtsteam »
Offline Sid_Vicious
« Reply #4 on: April 15, 2013, 09:13:40 PM »
That came out nicely, looking forward to see the final outcome.
« Reply #5 on: April 15, 2013, 09:33:28 PM »
Wow, that's quite the difference!  I need to try that some time.
« Reply #6 on: April 16, 2013, 02:10:41 AM »
Hi vt,
                That's an easy way to clean up an item, much better than a wire brush, and no dust!
                                             C
« Reply #7 on: April 16, 2013, 03:13:22 AM »
Leaving in citric acid solution overnight will give the same result without all the wires. I used to use the electrolytic method which works very well but is dangerous indoors as it liberates hydrogen and oxygen in an exactly explosive ratio. Since I discovered the effectiveness of citric acid I've gone over to using that.
« Reply #8 on: April 16, 2013, 04:04:35 AM »
WOW!  :bugeye:
That came out looking good. Apart from the obvious modifications........  :palm:
Good luck with the rest of the fix!  :thumbup:
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #9 on: April 16, 2013, 04:24:47 AM »
Brazing some brass to the ways and mill it flat again will prob. take care of the modifications though.. and it tends to hold up well (seen it been done only) and well depending on your mill you can tighten upp the wise to the point that you get no play out of it. =)
« Reply #10 on: April 16, 2013, 08:44:16 AM »
In what form do you find the citric acid, and form where?
« Reply #11 on: April 16, 2013, 08:52:08 AM »
I buy it by the 5kg bag of powder on eBay - not expensive and it goes a long way. Dilution not critical - say about 100 grammes in a 2 gallon bucket. Better slightly warm but it just speeds things up rather than being essential.
« Reply #12 on: April 16, 2013, 10:06:47 AM »
Lots of ways to skin a cat -- I like the washing soda electrolytic method having just tried it. I've also seen sodium bicarbonate (baking soda) used, though it's more expensive, it's even more widely available and still cheap enough.
What I used, was sodium carbonate -- available everywhere at supermarkets --used for clothes washing, and the cost was 15 cents for this tub full of solution -- which can be re-used. In fact I have a big old dividing head that needs to be restored, and that will be next in the tub, plus a bunch of other rusted odds and ends. But chemical methods like citric acid seem good, too, if you have it. Whatever works!
re. explosive gasses and safety -- Charging an auto battery (with the same charger) also liberates oxygen and hydrogen, and in this case I was drawing less than an amp, so the gas evolution (charge) rate was low compared to an open lead acid cell.
I kept the shed door open, and the tub in the open doorway itself, so essentially it was outdoors. (the shed used is unfortunately "ventilated" in the extreme, even when closed!) I also didn't leave it unattended or over night. I checked it periodically, had it on a 2 hour timer on the charger, and that's how long it took to clean up. I always turn off a charger before removing battery clamps from a battery -- learned that one when I was 19 the hard way -- and I did the same for this.
Just including the above in case someone else decides to try it as well.
« Reply #13 on: April 16, 2013, 10:10:28 AM »
btw. I remember there used to be an old rumor that Coca Cola would clean the rust off of tools. Never tried it. But I wonder now if it was the citric acid in the soft drink that was the "active" ingredient!
« Reply #14 on: April 16, 2013, 11:41:38 AM »
I've been using vinegar recently. Light rust appears almost immediately.......  :palm:
Just ordered one of these.....    http://www.ebay.co.uk/itm/270958120373?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Hope it's the right stuff!   :scratch:
« Reply #15 on: April 16, 2013, 11:45:04 AM »
No - Coke has phosphoric acid in it that also acts as a rust converter rather than remover - The iron phosphate formed is attached to the base metal.
Battery charging : I once lost a pair of spectacles and got a face full of sulphuric acid when I took a battery off charge, and the spark ignited the H & O2 in one cell, blowing the top clean off all over my face. Not pleasant so I'm a bit sensitive about explosive gas mixtures !!!!!!
« Reply #16 on: April 16, 2013, 12:25:14 PM »
Same thing happened to my step-brother. he removed the charger clips without turning off the charger and the top blew off the battery.
« Reply #17 on: April 16, 2013, 12:25:32 PM »
"learned that one when I was 19 the hard way" <---- ahem, same here -- luckily I was near a sink in the garage I was working in. It was on the other side of a jeep, which I apparently leaped over entirely to get to water, according to spectators. That was a commercial charger running at 40 amps.
Important to turn a charger off before removing battery clamps. A wait doesn't hurt either. Even outdoors.
« Reply #18 on: April 16, 2013, 03:44:57 PM »
I decided to fill the divots with metal filled epoxy putty -- JB Stick. I've had good luck with it on cast iron in the past. It cures very fast -- about 2 minutes working time after kneading it together. I use rubber gloves and it's important to wet them with water, or this stuff will pull them off. Also you can't easily putty knife it. Best bet is just press it in place.
« Last Edit: January 07, 2018, 04:55:04 PM by vtsteam »
« Reply #19 on: April 16, 2013, 03:49:01 PM »
After it had cured for a half hour, I filed the epoxy down with a coarse file. Then I hit the ways with some petroleum jelly, and a few other areas I wanted to mask as well. The drill divots on the ways looked pretty good after filling with epoxy and oiling. The bare epoxy can be seen in some cuts on top of the vice slide.
« Last Edit: January 07, 2018, 04:55:56 PM by vtsteam »
« Reply #20 on: April 16, 2013, 03:53:43 PM »
We have predictions for rain for the next few days so I was anxious to get a coat of paint on before then. In fact there were a few drops while I was painting, so I quickly moved it to the porch while still wet. Good to have it protected now that it has been stripped!
« Last Edit: January 07, 2018, 04:56:36 PM by vtsteam »
« Reply #21 on: April 16, 2013, 04:01:39 PM »
well dun  :thumbup:
« Reply #22 on: April 18, 2013, 05:34:58 AM »
Hi vt,
         Looks well now it's got a coat of paint. Do you have to make a new jaw for it?
                                      Cheers   avid
« Reply #23 on: April 18, 2013, 11:35:27 AM »
Yes avid I have to make 2 jaws and a handle for it, and also probably clean up the working surfaces on the mill.
Got a little sidetracked -- got my steam engine conversion running yesterday, and now have a cold. But should be back on it shortly. I need the vise to slit saw my QC tool holders. Seems like all projects are coming together at once.  :dremel:
« Reply #24 on: April 18, 2013, 05:10:18 PM »
Made some jaws this afternoon and trued them up on the mill. Handle left to do.....
« Last Edit: January 07, 2018, 04:57:22 PM by vtsteam »
