Author Topic: Beeston Myford Rear Tool-Post (Dickson QCTP Style) Model 30/145.  (Read 9897 times)
Hi there, all,
Please has anyone got one of these?
The version I'm interested in is the 30/145 for the ML7 & S7, not to be confused with the one for the ML10 (30/148), the 254+ (30/149) or for the 254S/R (30/151).
If you do have one, please could you measure the distance from the upper surface of the cross-slide to the underside of the Dickson mounting block?
(And post it in your reply!!)   :doh:
Sorry about the poor picture quality - scanned from the fifth generation photocopy of the sixth carbon!!
Thanks.
lordedmond
Re: Beeston Myford Rear Tool-Post (Dickson QCTP Style) Model 30/145.
« Reply #1 on: March 22, 2013, 01:13:32 PM »
1.688 inches
Yes mine is a local Myford one as I live not 5 miles from the proper Myford Works
Stuart
« Reply #2 on: March 22, 2013, 01:37:31 PM »
Stuart,
Thank you - you're a star!!    :nrocks:   :nrocks:   :nrocks:   :nrocks:
I took my pix from a Beeston Myford leaflet that says there were several options for tool-holder - which do you have and do you find the tool-post a useful asset?
I made an impulse buy, a model 30/149 for the 254+ and I want to make an additional base for it to make it compatible with my ML7.
Thanks again.   :D   :D   :D   :D   :D   :D   :D
lordedmond
« Reply #3 on: March 22, 2013, 02:19:41 PM »
yes its very useful
I use an iscar parting blade for steel  along with the other two holders  one with zero rake and a 1/16 parting blade for brass the other one for ali
Stuart
« Reply #4 on: March 26, 2013, 06:17:14 PM »
handy bit of kit
« Reply #5 on: February 18, 2015, 12:52:19 PM »
Hi there, all,
 :update:   :update:   :update:   :update:   :update:   :update:
I started this post (quite a long time ago!!) because I had bought a Beeston Myford Dickson-Pattern rear tool-post, part number 30/149.  That version is for the Myford 254 lathe which is considerably larger than my ML7.
As bought, the tool-post looked like this:
Obviously, to use this tool-post on the ML7, its height would have to be reduced.  Thanks to Stuart, I knew that the lower block for the corresponding ML7 item, part number 30/145, is 1.688 inches or 42.88 mm.
I didn't want to modify the lower block from the 30/149 so I cast about (pun intended) for a suitable piece of cast iron from which to machine a 30/145 lower block clone.
With this intention, I purchased a length of cast iron bar from College Engineering.  They advise, quite reasonably, to allow for the material being as much as 5 mm under nominal size.
The finished size of my block would be that 42.88 mm high, plus a bit for the locating tongues that fit in the cross-slide Tee-slots, by 78 mm long and 48 mm wide. So, having allowed what seemed enough machining allowance, I placed my order.  What arrived looked like this:
It transpired that my piece of material was actually a bit OVER nominal size, it measures 61 mm by 61 mm by 90 mm (I did up the length ordered by 10 mm).
That was going to need a lot of cast iron converting to swarf, taking a lot of time and making a lot of mess!   :doh:   :doh:   :doh:
So I thought long and hard, trying to think of a good approach.  I could have fitted the block into the four-jaw chuck and machined it to size - NO, too much swarf and too much time!   :bang:   :bang:   :bang:
I could hack-saw off most of the excess material, just leaving a mm or so to machine off - NO, too much physical exertion for an 'oldie' like me and I couldn't guarantee the required accuracy of cut!   :bang:   :bang:   :bang:
I enquired of the makers whether the Rage Evolution saw would cut cast iron and was told that it would not!   :bang:   :bang:   :bang:
I wondered whether anyone I knew had a metal cutting band-saw or a donkey saw and might make it available to me - I didn't know anyone!   :bang:   :bang:   :bang:
So, I got on with other jobs and this one receded even further back than the back burner!!    :scratch:   :scratch:   :scratch:   :scratch:   :scratch:   :scratch:
And there it stayed until ten days ago!
« Reply #6 on: February 18, 2015, 01:06:38 PM »
Hi there, all, again,
Well, to cut a long story short (not something I do very often!) I spotted an item on eBay that looked suspiciously like the lower block of a 30/145.  I put a bid on it and spent the next week on tenterhooks.
But, imagine my delight when the auction ended and mine was the only bid!    :D   :D   :D   :D   :D   :D
The seller got the item into the Post very promptly and I received the item the following day.  It looks like this:
or like this:
and, married up to the upper block, like this:
Here is a comparison of the two lower blocks:
I shall need to make a securing bolt of suitable length but otherwise I have a result!!   :ddb:   :ddb:   :ddb:   :ddb:   :ddb:   :ddb:
Share my joy!!   :D   :)   :D   :)   :D   :)
(Oh, by the way, when I bought the 30/149 it was a complete kit, with a parting blade and mounting bolts & nuts.)
Offline dawesy
« Reply #7 on: February 18, 2015, 03:35:44 PM »
Excellent result. It's nice when things just work :)
And you now have a lump of cast for another project :)
Lee.
