Author Topic: Expanding mandrels  (Read 36596 times)
Offline NeoTech
    • Roughedge Hobbyworks
Expanding mandrels
« on: March 12, 2013, 04:51:59 PM »
So i need to make a small tool to holding a small aluminium part in my lathe.
And well never done this before..  Could i get some input on this idea.
Re: Expanding mandrels
« Reply #1 on: March 12, 2013, 06:25:46 PM »
It needn't be that elaborate especially for a single setup. If you set your compound and turn a tapered slug, then just chuck up some ally in the 3-jaw, bore it through, turn the taper for the slug, turn the OD for a close fit to your part with a back-shoulder, cut the slots, de-burr then mount the part up and tap in the slug. It won't move.
To release, tap the slug out from behind with a long knock-out bar through the spindle.
Offline NeoTech
« Reply #2 on: March 12, 2013, 06:30:44 PM »
Oh its not for a single setup im gonna do 24 identical parts and the "lip" that i can clamp to its only 20mm wide, 2mm deep on the inside and isnt going through the part.
Would your solution still work? *sounds alot easier* =)
« Reply #3 on: March 12, 2013, 09:32:24 PM »
Another very simple option I've used, though maybe not as applicable to production, but possibly of interest to others doing a few parts is to turn up a close sliding fit on a stub mandrel, leaving a shoulder and then mill off a flat slightly deeper than a dowel pin you insert in the gap. Twist the part on the arbor to lock it in the turning direction, then twist it the opposite way to unlock.
Oh- it's not going to work on a blind hole -- I'm just adding it here in case someone else checks this thread and needs a quick solution.
Pictures are better than words:
http://i786.photobucket.com/albums/yy150/vtsr/arbor2.jpgExpanding mandrels
Above are the arbor quickly turned up and the dowel pin and a couple of steel blanks -- one has been turned on the arbor
http://i786.photobucket.com/albums/yy150/vtsr/Arbor.jpgExpanding mandrels
This is what the arbor (and work) looks like when set up on the lathe. The pin locks the work when you give workpiece a twist one way, and unlocks it when you twist it the other way.
« Reply #4 on: March 13, 2013, 04:34:00 AM »
Turn up a stub with suitable shoulder to seat the item. Axially drill and tap only using a 'second' tap not a bottoming one. Saw the end of the stub radially with two cuts so the end on view looks like a cross. Screw in a grub screw. As it reaches the incomplete female threads it will tighten and expand the stub gripping your part. Obviously the grub screw needs to be of suitable dimensions that the wall of the stub can flex.
Offline ozzie46
« Reply #5 on: March 13, 2013, 06:50:01 AM »
  Now That is an amazing idea!!!
So simple yet I can't believe I never thought of it. :Doh: :Doh: Oh yes I can. I'm not as smart as I wish I were. :doh: :doh:
 Ron
« Reply #6 on: March 13, 2013, 08:17:06 AM »
Well I certainly didn't think of it either. Just passing it on!  :beer:
« Reply #7 on: March 13, 2013, 08:27:15 AM »
Another quick way to make an expanding arbor is to tap the end for a pipe plug, and then slit it.
Put the workpiece on the arbor and then thread in the pipe plug. It has tapered threads and it will expand the arbor fingers.
That one is from David Gingery.
« Reply #8 on: March 13, 2013, 08:52:14 AM »
I have used concrete anchor bolt to expand slit mandrel. Saves me from makin tapers. This type:
http://www.confast.com/images2/products/main/drop-in-anchor.jpg
Haven't tried this one:
http://www.confast.com/images2/products/main/sleeve-anchor-hex.jpg
I should mention that I had about 50% success rate...for some reason does not work allways very accurately. Looks like good idea to tighten and loosen just only eneough...no extra 1/4 turn "just in case".
« Reply #9 on: March 13, 2013, 12:11:36 PM »
Offline fixerup
« Reply #10 on: March 13, 2013, 01:00:08 PM »
Neotech
I think your diagram looks like the right idea. The tricky part is, 2mm is not much to grab onto depending on what machining you intend to do to it.
I found this tubing expanding mandrel. I wish we could see a breakdown of parts to give us a better idea how to make one.
http://www.ryanairconspares.com/refrigeration-tools-copper-tube-pipe-expanders-c-9_22.html
Vt steam, thanks for sharing that one.
Cheers !
Offline NeoTech
« Reply #11 on: March 13, 2013, 01:57:08 PM »
fixerup, well that what the little "lip" in the end was for i thought. But i may need to give it some clearance and make it a bit sharper so it can bite into the material better from the inside.
the parts need to be outside faced and a radius is gonna be on it.. its a 15mmx30mm piece with a 20mm hole that is 2mm deep. the radius is wanted to be 12mm. so its basicly a knob more or less.
the recess will have a 4kg neodymium magnet pressed into it.. and the set is three "knobs" and a block with three magnets fitted. they will make up a corner. So that plastic can be wedged in between them for spraying cabinets. (i make these for a friend that had this idea of a portable spraying cabinette)
« Reply #12 on: March 13, 2013, 02:34:54 PM »
NeoTech,
I think I can picture the item you are trying to make.
Why not tap a blind hole in the part and screw it to a spigot (the end of which is a good fit for the recess) which can be clamped in a 3-jaw or a collet. The hole would be hidden by the magnet.
I think there could be a potential problem with your design in that, if the wedge is more than 2mm down the tapered hole, there would be little clamping force on your part. A ring (thick washer) around the stepped diameter at the inner end of the mandrel would help.
Also I think the tapered hole in the fixed part is unnecessary. The wedge as shown is too big to go in. The screw you show would need to be a very good fit in its hole to retain concentricity.
Offline PeterE
  • Gothenburg
« Reply #13 on: March 13, 2013, 04:49:27 PM »
... and yet another idea that I have seen in use somewhere ...
I have no pictures so I have to try to describer it  :bugeye:
The idea is much the same as an ordinary collet that one puts material into and it contracts around the material when pulled into an arbor (= lathe headstock) but working opposite...
Instead of having a tube with the cone on the inside fitted to the headstock as mandrel, the cone should be on the outside. Then a "collet" with an outside look of a step drill (but larger) having an "inside" cone matching the one on the mandrel. So when pulled toghether the "step drill part" being pulled over the outside cone will expand (if it have been properly slitted of course) and open up instead of contracting. That will become the grip end for a recess and can be used to hold an item in the lathe for turning for example.
I hope you understand how I mean, if not I will have to try to draw it quickly.
Just as a thought ....
BR
/Peter
Offline fixerup
« Reply #14 on: March 14, 2013, 10:23:43 AM »
I missed that lip details, Yes that would definitely work.
Offline NeoTech
« Reply #15 on: March 14, 2013, 03:19:23 PM »
PeterE, i do think a picture is needed.  :scratch:
« Reply #16 on: March 14, 2013, 04:25:55 PM »
This is essentially the same as awemawson's idea :
1, saw a long slot in a piece of HRS
2, Drill & tap half way through
3, fix in chuck
4, turn & face to size (by doing this at this stage it will be absolutely concentric and square to the axis)
5, insert screw & tighten to fix piece
Offline PeterE
  • Gothenburg
« Reply #17 on: March 14, 2013, 05:47:15 PM »
OK, here is a quickly scribbled down sketch which I hope will reveal my thoughts.
http://i577.photobucket.com/albums/ss219/H0n3/expandingcollet.jpgExpanding mandrels
The stepped collet is of course slitted lengthwise like any other collet and then pulled onto the conical end of the mandrel which will make the collet open up.
I guess it is a more elaborae version of PekkaNF´s idea with the expanding masonry bolt.
BR
/Peter
Offline NeoTech
« Reply #18 on: March 15, 2013, 10:11:23 AM »
PeterE, so if i get this right, the cones are matching, the stepped cone part is turned to ID, and then "pushed" into the work. When pulled over the mandrell cone it will seat and expand to its exact dimension and there for put X amount of pressure on it. Doesnt this mean it needs to be slightly oversizes so it would need to be compressed slightly to fit into the work. I guess this would make a really proper concentric fit though.
GraphiteCad - is better than nothing. =)
Offline PeterE
  • Gothenburg
« Reply #19 on: March 15, 2013, 01:18:25 PM »
Well, I managed to make the size difference between the two parts a little too small.
The mandrel cone shall have a larger diameter than the "collet", then the collet will automatically expand when pulled into the mandrel (towards the right in the picture).
The idea is to get an internal collet that provides an equal pressured on the inside of a recess like holding a pipe on its inner diameter.
The "stem" of the collet above of course goes through the lathe spindle and is pulled like a normal MT-collet.
Hope this completed the picture.
BR
/Peter
(Shall see if I can make a better sketch using "GraphiteCAD" or even an electronic tool  :bugeye:  )
Offline NeoTech
« Reply #20 on: March 15, 2013, 01:39:33 PM »
I managed to figure out that a size difference is needed and came up with this. =)
« Reply #21 on: March 15, 2013, 04:25:26 PM »
Neotech,
I very much doubt this design would work at all. If you are gripping inside a 2mm deep recess there would be very little clamping force available that far away from the taper (which, in my opinion, is too shallow even if you were trying to clamp the part near to the taper).
Offline NeoTech
« Reply #22 on: March 15, 2013, 04:37:15 PM »
I have my doubts as well.. But its interesting so i will try to make several of em this weekend and test them. =)
Offline PeterE
  • Gothenburg
« Reply #23 on: March 15, 2013, 04:56:11 PM »
NeoTech,
You have understood the idea, but you need a cone angle that resembles an ER or 5C collet, or somewhere between 10 and 20 degrees to get enough expansion force. I would also suspect that the fit between the stepped end of the "collet" and the workpiece to be quite close from start. That way you do not need to open the collet very much.
I must also add that I have only seen this thingy described but never in use IRL so how well it works is anybodys guess I think.
What is the depth and diameter of the recess you want to grip?
BR
/Peter
Offline fixerup
« Reply #24 on: March 15, 2013, 05:29:41 PM »
NeoTech,
I believe your first design would work, I would make the cone almost flush with the edge or even have it protruding a little(.005"), so that when you draw the cone in it would put the clamping force right were you want it.
