Author Topic: Oh Blimey I bought a CNC Lathe !!!!  (Read 524958 times)
« Reply #175 on: May 10, 2013, 09:55:39 AM »
And this is the complexities of the 'opposing spindle' ie the one facing the main spindle. It has again a hydraulic clamp / un-clamp set up, with a host of proximity sensors:
Offline tekfab
« Reply #176 on: May 10, 2013, 04:51:17 PM »
You know i really really admire your dogedness in pursuing this BUT if ever there was another reason needed NOT to go down the CNC route then this thread is it !
GOOD LUCK !  and may the fruition of your toils be soon.   :coffee:
« Reply #177 on: May 10, 2013, 05:15:45 PM »
Ah - but is it the end result or the journey that I 'enjoy' - I'll leave you to draw your own conclusion!
« Reply #178 on: May 11, 2013, 06:24:56 AM »
Late yesterday brought an email with a large pdf file attached - yes at last the correct (hopefully) circuit has arrived. Printed out all 169 pages on my A4 laser printer, but I decided that now I have it as a pdf  I would print out the relay side of things at A3 (old eyes you see - or rather don't  :(  ).
So this morning back into the fray: The relay in the following pictures had been giving me particular problems, and was causing other relays to chatter due to poor contacts. I can buy them still but firstly they are about £50 each, and secondly the contacts bear different numbers which will lead to future confusion, so - it has to come out and be cleaned.
First - remove all the (unlabeled) wires, and label them, putting a 'boot lace ferule' on each
« Reply #179 on: May 11, 2013, 06:26:45 AM »
Then remove the relay, and take into the operating theatre:
« Reply #180 on: May 11, 2013, 06:27:39 AM »
Separate the coil from the contact pack
« Reply #181 on: May 11, 2013, 06:29:47 AM »
Open up the contact pack and carefully clean each contact with a scalpel. You could get special contact cleaning slightly abrasive pads for this job, but I've not seen any for years!
Test operation before replacing !
« Reply #182 on: May 11, 2013, 06:30:52 AM »
Then pop it back in. Whole operation took just over an hour - now there are a further how many relays  :bang:
However glad to say it's cured the chattering so a bit of progress  :clap:
lordedmond
« Reply #183 on: May 11, 2013, 07:30:28 AM »
another step forwards on the journey
congrats on getting the drawing with the same date as the machine it will help i am sure
Stuart
« Reply #184 on: May 11, 2013, 11:03:58 AM »
Glad the relay is functioning again, awmawson! :thumbup:
I still use the old writing paper trick -- slid between contacts held closed for cleaning carbon from breaker points on my old tractors, and I have a point file or two in case of spikes and pits. I think you can still buy point files here at automotive supply stores.
Offline Fred Bloggs
« Reply #185 on: May 11, 2013, 11:10:01 AM »
Glad to see some progress, I have got into a habit of check madmodders daily for progress, like a family member expecting good news at any moment :mmr:
keep at it we are all rooting for you :D
Fred
« Reply #186 on: May 11, 2013, 11:32:27 AM »
Thanks Gents!
Sadly the contacts on these relays are recessed so the paper trick doesn't fit :(  The contact surfaces are rare metal plated so I don't want to be too harsh with them - there seems to be a powdery deposit on some of them. Possibly oxide but I don't think so. I did another relay dismantle this afternoon, this time one with an auxiliary contact set added on the top. Doing the relay was just like the last one, but I could find no way of getting at the auxiliary contacts short of busting the  plastic moulding. The contacts were bad, which is why I pulled it out, but I had in the end to try and flood the inside with contact cleaner / de-oxidiser and even getting that 'inside' was flaky - obviously essentially sealed. However working it by hand with the switch cleaner floating around in the end gave a good contact, but not a satisfactory solution really.
Meanwhile if anyone knows a source of Siemens relays at a sensible price:
Main relay 3TH 2031-0BB4 (3 N/O & 1 N/C 24v DC coil)
Aux Block 3TX442-2A (2 N/O & 2 N/C)
please let me know. They need really to have the same numbering scheme as the following pictures - the are a few around marked up L1 L2 L3 but I feel that is just going to lead to confusion in the future
« Reply #187 on: May 11, 2013, 12:23:09 PM »
awemawson
I tried looking for the part numbers that you listed and I think I may have found something. Here is the link to it.
http://www.ebay.fr/sch/sis.html?_nkw=Siemens+3TH2031+0BB4+Schutz+mit+Hilfsschutz+3TX4422+2A+&_itemId=110846361606
I will continue to keep looking to see if anything else shows up at a reasonable price.
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« Reply #189 on: May 13, 2013, 06:12:11 PM »
Hi,
Had a bit of a look arround the normal suppliers and found these
http://uk.rs-online.com/web/p/contactors/7352787/  relay only
http://uk.rs-online.com/web/p/contactors/4111700/  with aux contacts push in
Abraham
« Reply #190 on: May 14, 2013, 09:32:24 AM »
Thanks Abraham and others. Problem with the RS ones is at £39 plus 20% VAT you are at the circa £50 level which is why I was casting around looking for good used ones. The various one not in the UK seem quite reasonable until you calculate the shipping, which brings them up to 2/3rds new price. As there are so many of the darn things it get pricey very quickly :(
Not much activity recently on the machine - I've been called away to sort other things. We've got some large scale building works going on here, and the builder (who I've employed for over a year now) has gone to pieces over the potential loss of his mum who is having heart troubles. This gives scheduling issues so for instance I have to get 1100 tons of earth shifted tomorrow!
Lucky I'm not using a shovel and barrow:
« Reply #191 on: May 15, 2013, 06:53:58 PM »
If only you had some kind of large capacity CNC lathe machine, you'd be able to turn out loads of shovel shafts and wheelbarrow parts....  :whip:
 :lol:
« Reply #192 on: May 16, 2013, 05:28:04 AM »
I made good use of my enforced imprisonment in the farm office to go through all 160 plus pages of the circuit diagrams pulling out all references to inputs and outputs to and from the NC controller as I was sure something was missing. I put them all in a spreadsheet, which has allowed me to sort them by i/o address and also by terminal number. Sure enough I've found five inputs that are not documented and contacting Traub, they also don't know what they do  :bang: So next job is to put the cable tracer on them and plot them out.
If you are having a really boring day have a read of the spreadsheet:
« Reply #193 on: May 16, 2013, 05:30:58 AM »
And to keep Adev happy - yes the earth moved for me! It took four of us from 07:00 to 22:00 non stop.  My shovel and barrow are in the second picture!  Just need to let the place it was dry a bit then harrow and re-seed.
« Reply #194 on: May 16, 2013, 07:51:48 AM »
Yep, that's what I call a spade & a wheelbarrow :) If only I had the room for such toys....
Loving the gate BTW.
Offline millwright
  • Leeds West Yorshire
« Reply #195 on: May 16, 2013, 03:32:26 PM »
I enjoy this thread and admire your patience. was pleased to see the gate was shut to keep the livestock in. :clap:
« Reply #196 on: May 16, 2013, 04:29:16 PM »
We call that 'The Gate to Nowhere' - it used to be the access to a smallish paddock, but we took the stock fencing down to let the dumpers better access when we dug out the ditches and stream a couple of years ago. The paddock will be reinstated soon, with a double stock fence with hedging between.
Anyway - back on topic: Tonight I've been buzzing out those elusive input output lines. It turns out it's down to two manufacturing errors  :bang: all be it slight ones. Firstly two of the termination blocks on my machine were incorrectly labeled, and secondly the 'survey' printed in the circuit diagram showing physical locations also has an error. In the attached picture the upper terminal block, which is 'X206' is labelled 'X103', and the block below it is actually 'X103' but wasn't labelled.  :bang:
Makes a lot more sense now.
« Last Edit: May 16, 2013, 05:07:38 PM by awemawson »
Offline Henning
  • All the kit and no clue!
« Reply #197 on: June 04, 2013, 05:04:02 AM »
The suspense is killing me! How is this going?
Henning
« Reply #198 on: June 04, 2013, 08:03:31 AM »
It's not, thats the problem.  :(
« Reply #199 on: June 04, 2013, 02:14:46 PM »
I think I alluded to this is a previous posting, but we are coming to the end of a major refurbishment here involving rebuilding the farm house, renovating two cottages and some substantial landscaping, and the poor old 'main contractor' has had a bit of a breakdown, meaning I've had to take on his role. Fortunately I've been able to use his sub-contractors (some of which are his sons) but it takes up all my play time :(
However there has been some progress on the machine. Firstly I think I've solved the relay issue. I now have the correct circuit as far as I can tell, and have sourced some identical relays from German eBay:
