Author Topic: Valve seat cutter  (Read 21524 times)
Valve seat cutter
« on: February 25, 2013, 03:35:37 PM »
I need to make a valve seat cutter but have come across a slight problem.......... :doh:
My original intent was to make the cutter from Silver Steel, profiled and hardened to suit...
I started making a mock up from some EN1a 1" diameter bar but found it was a tad too small...The SS needs to be ideally in the region of 1-1/4" but I cant source any.......
Back to drawing board.... :dremel:
EN1a is in plentiful supply but I'm not sure it can be hardened to perform as a cutter..
So, what else can I use along with the EN1a bar to make a cutter?  was thinking along the lines of some sort of carbide insert...but not sure how to go about this....?
Just to add the diameter of the valves are around the 7/8" mark...if this helps? and its for a small Villiers engine I'm renovating...
Re: Valve seat cutter
« Reply #1 on: February 25, 2013, 04:09:27 PM »
Silver Steel is equivalent to O1 tool steel or gauge plate. O1 is readily obtainable in most sizes.
EN1A can be case hardened but isn't suitable for a cutting tool.
Cheers.
« Reply #2 on: February 25, 2013, 05:05:19 PM »
13" lengths are here. Download the supplies catalogue link.
Page 9.
http://www.livesteammodels.co.uk/suppliescat.html
Better to sit down first though ....£30 +vat ish .... not what you might call 'freeware'  :(
Dave BC
« Reply #3 on: February 25, 2013, 05:11:49 PM »
If you're cutting the seat in something soft like ally or brass you will get away with case hardening.
« Reply #4 on: February 25, 2013, 05:32:43 PM »
Make a suitable EN1A cutter, but cut a pocket in it for an indexable insert
« Reply #5 on: February 25, 2013, 08:51:41 PM »
I think a fairly thick old automobile leaf spring under my shed might wake up in the morning to find a bit of its length missing in such a circumstance.  :dremel:
« Reply #6 on: February 26, 2013, 06:53:02 AM »
This is the alternative I'm considering after seeing a countersinking cutter on a Chinese tool website..... :dremel:
Thanks for the ideas guys... :thumbup:
« Reply #7 on: February 26, 2013, 08:26:08 AM »
You may probably already have considered this but there's one more thing to bear in mind - If you are going to use the tool either hand driven or via a power tool rather than in a milling or drilling machine you need to set a stop (possibly on the shaft which goes through the valve guide) so that it not only limits the depth of cut but, particularly when using a single insert cutter, to prevent you ending up with a spiral valve seat with a step where the cutter stops.
Cheers.
Offline Jo
« Reply #8 on: February 26, 2013, 09:17:07 AM »
Case hardened MS worked very well on my Cast Iron  R&B gas engine head.  :thumbup:
Jo
« Reply #9 on: February 26, 2013, 10:46:53 AM »
Jo
Jo do you have any fabrication details  on your cutter please?
Saves 're-inventing the wheel' .....a couple of photos wouldl be great too if you have any ..
cheers
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #10 on: March 02, 2013, 11:37:51 AM »
Offline rotorhead
« Reply #11 on: March 02, 2013, 06:42:16 PM »
Hi John,
A very good supply can be found here.----- http://www.lawson-his.co.uk/stubs-r080a-silver-steel-imperial-1-1-4-x-p44342
That's just for 1-1/4" @ £18
Sunny Scunny,
North Lincolnshire.
Offline OKTomT
« Reply #12 on: March 03, 2013, 01:50:25 PM »
John this is what I use its made by Neway. Its hand operated and very well.
« Reply #13 on: March 03, 2013, 03:12:35 PM »
Yeah ,I've seen the Neway offerings but they are very expensive.............Not quite within my budget..  :coffee:
« Reply #14 on: March 03, 2013, 03:42:41 PM »
Don't know how big your valves are but maybe this would be helpful to at least look at.
http://www.homemodelenginemachinist.com/f31/4-cylinder-ohv-engine-new-cylinder-head-work-progress-5529/index4.html#post62611
