Author Topic: clausing lathe apron  (Read 7997 times)
« on: February 12, 2013, 03:23:28 AM »
A while ago I said I was going to take the apron off because the feed screw would tighten and engage on it's own..
 http://i1322.photobucket.com/albums/u577/tom_osselton/Photobucket%20Desktop%20-%20TOM-PC/DSC_0286_zpse35275c0.jpgclausing lathe apron
I was actually suprised  to see how simple it was just a taper fit but I couldn't see how to keep them separate so it wouldn't engage!
http://i1322.photobucket.com/albums/u577/tom_osselton/Photobucket%20Desktop%20-%20TOM-PC/DSC_0276_zps402d80f9.jpgclausing lathe apron
on the other end there is just a knob, washer with flats so it couldn't spin on the shaft and a nut to lock it all together. My son took it to work and polished the shaft and I decided that it needed a spring in the holes for the dowels and found some 24 mm ones at the hobby store and it works great now it's a treat to use so if anyone has this problem give it a try.
