Author Topic: Building my new workshop  (Read 79169 times)
Re: Building my new workshop
« Reply #25 on: March 20, 2013, 05:23:45 PM »
Makes sense. I have a timer / thermostat on mine set to 7.5 Deg C at night & 17.5 during the day, but tend actually to leave it on night setting unless I'm actually in there or it burns too much oil (it's an air blown wet c/h system with a 'system' boiler)
Offline mechman48
« Reply #26 on: March 23, 2013, 05:38:42 PM »
I have two small oil filled rad's in my garage conversion, therm'controlled, one at either end & they are just the job, with the insulated walls & roofing it stays at around 4-6 deg' C when the outside temp has dropped to below 0*, keeps the rust at bay  :thumbup: I usually tweak them up to get the temp up to 10 -12 'C so it's nice & cosy at the mo' but usually end up switching them off after about an hour as the residual heat is more than enough for a couple of hrs, well worth the money  :thumbup: haven't left them on overnight, as yet have to find the temp dropping lower than 4*C   :clap: .  Looks like yours is going to be a super workshop  :headbang:
George
George.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #27 on: April 01, 2013, 11:33:08 AM »
Another little update:
We've managed to get all the plasterboard fixed, joints scrimmed and then compound applied twice and then sanded.
Result:-
As this is just a workshop I am not going to go overboard on the joints, they are covered and while not up to a standard for my house, the fact is that most of the walls will be covered up with shelves and cupboards ( and eventually swarf and oil )
Then today we managed to nail up the 1st coat of paint. It's a bit rough looking, but the 2nd coat will smooth that out.
Then we'll be putting in some of the electrics.
Not much to report really, progress is slow but steady.
Tim
« Reply #28 on: April 01, 2013, 12:27:28 PM »
Tim
Looks like the shed is comeing along nicely. A lot of work but will all be worth it in the end.
Sounds interesting that new paint. What kind of nails do you use to fasten it down with?   :lol:  :lol:
Offline spuddevans
    • My Photo website
« Reply #29 on: April 01, 2013, 12:36:43 PM »
Flat head ..... Very wide flathead  :lol: :lol: And wear eye-protection, the paint tends to splatter a little  :D
Tim
« Reply #30 on: April 01, 2013, 01:04:34 PM »
Hi Tim
I never did like painting but thought that your method might be OK. Looks like it might work good but cleanup will be a beach.   :lol: :lol: :lol:
Offline spuddevans
    • My Photo website
« Reply #31 on: April 01, 2013, 03:55:14 PM »
Tell me about it, but at least it wasn't as bad as the time I used my air-nailer   :palm:
Tim
« Reply #32 on: April 01, 2013, 11:36:46 PM »
Nice job Tim!
I am a bit jealous!
Offline spuddevans
    • My Photo website
« Reply #33 on: April 03, 2013, 02:38:18 PM »
I got the second coat of paint nailed up, looks a bit more consistent now.
My dad also brought round 2 sheets of 6mm ply (Actually not quite full sheets, about 7x4 ft each) Which we screwed up onto one wall along the top, it will be great for hanging tools and little shelves wherever I want.
Gave it one coat of paint,
And then after a few hours, another coat,
My dad also brought round a few fluorescent light fittings, they may or may not work, so I gotta test them before putting them up. Hope to put the lights up on Friday afternoon, then will be clearing out everything from the workshop at the weekend, another friend is coming round on early next week to install the floor screed to level up the floor.
That's the plan anyway.
Onwards and sideways,
Tim
« Reply #34 on: April 05, 2013, 03:45:43 PM »
Looks great Tim. Looking forward to you getting back on with posting some interesting projects. Looks a nice workshop.
Offline spuddevans
    • My Photo website
« Reply #35 on: April 05, 2013, 04:03:41 PM »
Thanks for watching along guys.
I've turned to some of the electrics, now that the paint is dry I can put up some lights, so I did
From the other end
A couple of them need the ballast replacing, got 3 electronic ballasts on the way so when they arrive I think that I'll be getting a tan while in the workshop.
I also installed my little consumer unit and temporarily wired up half of it to operate the lights.
That white flex coming out from the lower left of the consumer unit is just the temp incoming supply, I have yet to run the permanent supply out.
Next I have to clear out everything to make way for laying the floor screed on monday.
Onwards and Sideways
Tim
Offline ChriX
    • My wiki
« Reply #36 on: April 06, 2013, 05:31:06 AM »
Wow this is coming on so fast; looking forward to seeing you move the tools in!
Offline spuddevans
    • My Photo website
« Reply #37 on: April 07, 2013, 11:57:23 AM »
Can there be any more sad a sight than a workshop filled with nothingness ????
That's it ready for the cement screed which will hopefully go in tomorrow, the OSB boards are just there to protect the DPC from getting tore up with the wheeling of cement in.
It's getting closer to having workshop-type-furniture installed
Tim
« Reply #38 on: April 07, 2013, 12:02:36 PM »
Awesome Tim. That is coming along quite nicely!
« Reply #39 on: April 07, 2013, 12:11:54 PM »
"Sad sight" ......... Yer what????   :bugeye:
Tim. I'm seeing tremendous potential, and future comfort and happiness!  :headbang:
Hope it develops into all you hope for it......  :thumbup:
Offline shipto
  • Redditch, UK
« Reply #40 on: April 08, 2013, 03:39:38 PM »
looking cool  :thumbup:
Offline spuddevans
    • My Photo website
« Reply #41 on: April 09, 2013, 08:20:30 AM »
Little Update:
Got the floor screed down yesterday, it took 1.25 tonnes of cement (all shovelled by yours truly)
Now gotta wait for a week for it to harden enough to walk on. But I might find a couple of things to do around the outside.
Tim
Offline Swarfing
« Reply #42 on: April 09, 2013, 02:35:20 PM »
 :bugeye: Christ if it took 1.25 tonnes of cement how much ballast did it take for to make the concrete   :lol:
Once in hole stop digging.
Offline spuddevans
    • My Photo website
« Reply #43 on: April 09, 2013, 03:54:06 PM »
You wouldn't believe it!!!
It was just sand and cement, no aggregate. Just a plain cement screed on this one, thickness between 2" and 4" to level it all up.
Tim
« Reply #44 on: April 09, 2013, 05:26:11 PM »
 Looking Good Tim  :thumbup: :clap: .........You will sleep well tonight  :)
 Cheers Mick
Offline Swarfing
« Reply #45 on: April 09, 2013, 06:39:06 PM »
Good job Tim  :thumbup:
Offline Lykle
  • Country: cy
« Reply #46 on: April 10, 2013, 07:53:24 AM »
In regards to the electrics, I put one group on a switch by the door that switches that group on and off. This way I am sure that everything is switched off before I go up.
Then around the workshop I drop two double sockets, the left ones are switched with the main switch, the others are on permanent. This way I can decide to leave things on or centrally switched off.
The centrally switched sockets run my lathe, mill, grinding and sanding, but it also includes the compressor, my music and fan extractor in the back for clearing the welding smoke. It works like a charm.
I like the look of your place, it looks like a great place to work. Your floor is definitely a lot better than mine is, it looks so smooth and level. Wow, great job.
Lykle
Lykle
Design, Build and Enjoy life.
Offline spuddevans
    • My Photo website
« Reply #47 on: April 10, 2013, 04:56:34 PM »
Thanks guys :thumbup:
Great minds think alike, I too am planning to have a master switch next to the door for most of the sockets while keeping just a few unswitched (by the master)
Seems like it will be a good system, your experience makes me think so.
Tim
Offline PeterE
  • Gothenburg
« Reply #48 on: April 10, 2013, 05:15:08 PM »
Also I have found it wise (donīt ask me how I know  :palm: ) to separate socket groups from lighting groups. It is so annoying when the shop goes black when at machine has blow a fuse.
BR
/Peter
« Reply #49 on: April 19, 2013, 02:10:23 PM »
Hi Tim,
           This a great space and looking fine, you will lose all sense of time when building your projects, especially with your favourate radio programmes, and heater. Like you when I built my workshop I planned for all my electrical sockets plus a contingency factor. Ten years later I need more than double the originally installed, and it is not easy doing retro fits when you have more machinery and storage. I believe you will fill every available space eventually. If I where in your shoes I would double the amount of sockets you need now. I have at least six sockets that have short trailing leads with four socket outlets.
                                                        Job Well Done          Enjoy Cheers David
