Author Topic: Keyways outside the box.  (Read 9655 times)
« on: February 06, 2013, 04:27:56 PM »
As many know most of my work is emergency repairs and some jobs can be very testing in setups and methods
Today got the usual rush job in about 2:00 pm. Stonking great lovejoy coupling off a 75 HP motor off local water treatment plant.
seems the grille on the input for the pump rotted away and it sucked a tree into pump which didn't do it a lot of good.
Screwed the end off the motor which was 65mm diameter and has an 18mm keyway in it.
Motors is no panic, fit brand new motor and later refurb the old one as a spare.
Problem is the coupling, motor side. it's shredded the rubber coupling, no swaet new ones available but it's also ripped the keyway out of the coupling and tatered the bore up.
Ok rebore out, press, loctite and pin new sleeve into position, pretty standard, nothing new or unusual but it now requires an 18mm keyway 75mm deep in the new sleeve.
I only have broaches to 16mm and do not have a 65mm bushing anyway.
Slotter still needs some work doing on it so grab the Quillmaster with right angle extension and off it up to see if it will go 75mm down.
General picture of setup.
Close up of the first cuts, keyway is laid out to give a guide to follow. Cutter is a stubby 5mm carbide. The right angle extension should take 3/16" shanked tooling but it's hard to find over here so it's been bored out to 5mm.
Head was checked from trap and the quill was used as it's quicker than winding the knee up and down, up and down.
In that much of a rush, forgot to get a picture of the finished keyway as the driver rolled up early
Offline stovebolt
Re: Keyways outside the box.
« Reply #1 on: February 06, 2013, 05:38:59 PM »
 Another good save, Sir John, you shouldn't ever have to buy another pint.     :clap:  :clap:  :clap:
« Reply #2 on: February 06, 2013, 10:59:09 PM »
You certainly make it look easy but I guess with the right equipment and a bit of head scratching it all comes together. From the sound of things you have saved their bacon more than once, hope they appreciate it. Thanks for sharing that with us John.
« Reply #3 on: February 07, 2013, 07:44:39 AM »
Good job John.
Do I detect failure to clamp the Quillmaster properly before putting a cut on?
The marks to the left of the keyway look like the cutter scurrying across the surface.
How long did it take to chew the keyway out? I don't suppose you can put on a very big cut with the Quillmaster.
Cheers.
« Reply #4 on: February 07, 2013, 10:42:55 AM »
Nicely played John, I'm glad a Quillmaster finally found a use.
I just wish it were my Quillmaster which has been sitting quietly and uselessly in the cupboard since I bought it about 4 years ago...
Q: Is there a technique for removing the RA head? I undid the screw on mine, but no amount of pulling, twisting or shoving moved it; I didn't want to try violence in case I damaged something. Is there a trick/technique, or is it just brutalise it off? Ta.
