Author Topic: Welding Table = Pure Genius  (Read 20922 times)
Offline cedge
« on: January 14, 2013, 09:37:25 PM »
Not sure if this one has been posted before, but I'm giving it 100 bonus points for ingenuity. I'm also going to have to have one of my own.  :bow:
Offline shipto
  • Redditch, UK
Re: Welding Table = Pure Genius
« Reply #1 on: January 15, 2013, 03:18:35 PM »
Very nice I may have a go at one myself with a few differences.
« Reply #2 on: January 15, 2013, 05:29:19 PM »
That would also make a fantastic engine stand.
« Reply #3 on: January 15, 2013, 06:00:48 PM »
What an excellent idea...
off to eBay to find out how much bowling balls cost...
« Reply #4 on: January 15, 2013, 06:03:13 PM »
I have loads of brake discs
« Reply #5 on: January 16, 2013, 06:17:37 AM »
Offline Troutsqueezer
« Reply #6 on: January 16, 2013, 12:46:19 PM »
The Internet is a wonderful thing....
-Dennis-
Once you see the bandwagon, it's too late.
Offline sebwiers
« Reply #7 on: January 16, 2013, 04:07:15 PM »
My scultpture textbook in art school had this basic design, as a woodcarving clamp.  The bowling ball had a double ended lag screw on it; you just screwed on your hunk of wood and started carving.  Instead of disc brakes, the model there had a stand made of 4 4x4 posts hinged at the corners of a 2x2 square of plywood with opposing members joined by threaded rods running through pivots halfway up.  The bowling ball rested in notches cut in the ends of the 4x4 posts.  Basically a big gripper-clamp for the bowling ball.  Not nearly as quick to adjust, but then wood carving isn't a fast process.
Offline phillip
« Reply #8 on: January 25, 2013, 08:14:47 PM »
How is he releasing the pressure off the jack? All the ones I've seen, The bleeder is a screw. :scratch:
"If it’s true that our species is alone in the universe, then I’d have to say that the universe aimed rather low and settled for very little"
« Reply #9 on: January 29, 2013, 08:34:07 AM »
A versatile bit of kit, I like it.
                                              David
Offline Rubes
« Reply #10 on: January 29, 2013, 09:18:13 AM »
If you look at the other video of the build, he shows the jack from a motorcycle lift that has a quick release valve rather than the bleeder screw.
Offline phillip
« Reply #11 on: January 29, 2013, 07:21:20 PM »
AHAAAaaaaaa!
