Author Topic: Real Bull Machine 7x14 mini lathe headstock tapered bearing upgrade help please  (Read 47117 times)
Hi SLM,
Can't give you a length for my spacer. It's inside the covers, in a frozen workshop........  :(
Also, they're all individual to each modified machine.
Mount the tumbler gear, and both locknuts, in their relative positions. With the l/h nut, flush with the end of the spindle. (As, 2nd  pic down)...  http://madmodder.net/index.php/topic,1292.0.html
Then measure between bearing face and tumbler gear face......  :thumbup:
Offline SLM
Thanks!  I was thinking that the distance from the bearing to gear plus a few thousandths for preload would be right, just gotta try to measure it.
Any idea what the OD of the material you used is?  I know my 1.250" stuff is too small. Maybe I can dig up some 1.500" aluminum.
I made mine the same diameter as the bearing inner ring.......  :thumbup:
Then reduced the drive belt area, to clear the larger diameter pulley/ belt.
IIRC, the diameter was 1.5 inches......
I may still have an offcut from the bar I made my spacer from... :dremel:
Shame you're across the pond else I could have posted it to you :Doh:
Offline SLM
Thanks guys!  :D
John, postage would be a killer, LOL!  I think I can get 1.5" locally so I'll try and get some measurements tonight or tomorrow and go from there.
I've already noticed an improvement parting off the spacer I made with the tapered bearings. :)
Thanks guys!  :D
So a worthwhile investment of time and materials...? :coffee:
I think so, and have never looked back...
My Sieg machine is a great little machine and I love it.... :clap:
I'm just in the middle of making some more tool holders for the qctp I made for it a while back..Next I think is going to be a saddle stop ( again..I already made one for it but took it off to put on another machine...err yes the one I sold.. :D)
Offline SLM
Considering it had to come apart to replace the gear it was definitely a worthwhile upgrade! :) Probably worth it just to do the bearings but I'd do the gears while it was apart.
I've read a carriage lock would also be a good help with facing and parting. One of those is on my list of wants followed by a stop. Being able to bore / drill to the same depth sounds very nice!
Hi SLM,
SLM.
Had an overnight think.  :scratch:
The tumbler gear position, must be in working alignment with it's mating gears. The corresponding position of the locknuts doesn't matter.......  :thumbup:
Offline SLM
Ah, good point!  All those bits are still scattered around the basement, I never thought of them. I guess the best way then is going to be to rig those back on and measure.
It looks like the optimal OD for the spacer would be 1.750" as the1 1/2 is still smaller than the bearing but it isn't available locally. I'm sure it will be better than the 1.500" stuff though!
