Author Topic: Boley 4LV  (Read 227040 times)
Re: Boley 4LV
« Reply #75 on: January 05, 2020, 03:11:54 AM »
Very nice Mark.
John Winter ( Johnwinter.co.uk ) for ferrosilicate
Offline RotarySMP
Re: Boley 4LV
« Reply #76 on: January 05, 2020, 05:04:09 AM »
Thanks for the link Andrew. The only suppliers I had found were chinese, and will sell it by the ton.
Mark
Mark
Re: Boley 4LV
« Reply #77 on: January 05, 2020, 06:10:09 AM »
I did a foundry tour video last week, which answers those questions.
Mark
Thank you, that was very interesting and information is really good.
Offline RotarySMP
Re: Boley 4LV
« Reply #78 on: January 05, 2020, 06:54:27 AM »
Thanks for the feedback
Mark
Mark
Re: Boley 4LV
« Reply #79 on: January 23, 2020, 08:32:49 AM »
Mark
Mark,
I just got a quote from John Winter, £3.50/kg, minimum 100kg  silicon at 75%. Shipping to France, £135
A bit beyond my budget! Cheers, Matthew
Re: Boley 4LV
« Reply #80 on: January 23, 2020, 08:49:03 AM »
I will mark your end of term report 'Must try harder searching for things '  :clap:
eBay :
https://www.ebay.co.uk/itm/FERRO-SILICON-Pieces-750g-Si-75-86-Fe-23-89-1-6mm-FREE-P-P/254387618810?hash=item3b3aaf03fa:g:yo4AAOSw5nJeJttt
(£14.50 free delivery from Nottingham - 750 grams)
https://www.ebay.co.uk/itm/FERRO-SILICON-Pieces-1500g-Si-75-86-Fe-23-89-10-50mm-FREE-P-P/372798633338?hash=item56cc87b57a:g:iAIAAOSwM~tacFaN
(£18.50 free delivery from Nottingham for 1500 grams)
Re: Boley 4LV
« Reply #81 on: January 23, 2020, 10:01:43 AM »
eBay :
Thanks Andrew, you'll have to do online courses in searching!
Offline RotarySMP
Re: Boley 4LV
« Reply #82 on: January 23, 2020, 11:03:12 AM »
I also contacted John Winter buy they did respond. Thanks for that link Andrew. The Dash in the name was the key. I'd dearched Ebay before, but only found US venders.
Mark
Mark
Re: Boley 4LV
« Reply #83 on: January 23, 2020, 11:37:50 AM »
How much of that you need? in proportion of the melt?
Offline RotarySMP
Re: Boley 4LV
« Reply #84 on: January 24, 2020, 08:25:18 AM »
No idea. Once I get some, I'll go through Luckygen1001 and Olfoundryman's Youtube channel as they have some stuff on FeSi.
Mark
Mark
Re: Boley 4LV
« Reply #85 on: January 24, 2020, 10:03:22 AM »
I contacted Luckygen, he uses .25% to 0.5%. This must be added at the end of the melt and poured within ten minutes!
Re: Boley 4LV
« Reply #86 on: January 24, 2020, 10:09:26 AM »
eBay :
Andrew,
I have another search problem, then I'll stop high jacking this thread! I'm looking for a graphite sleeve or bush, 80mmx 100mm long with a 60mm bore, so far I've drawn a blank , any ideas? Regards, Matthew
Re: Boley 4LV
« Reply #87 on: January 24, 2020, 11:09:20 AM »
Mathew, I may have some in my 'EDM Sinker' box of electodes - I'll have a look tomorrow morning
(The big maker / supplier of graphite as used for EDM electrodes is 'Poco' so meanwhile search on that  :thumbup: )
Re: Boley 4LV
« Reply #88 on: January 25, 2020, 07:58:36 AM »
Matthew,
My bigger bits of graphite are:
BAR:
50 diam X 85
155 diam x 65
37.5 diam x 225
SLAB
270 x 210 x 20
(All dimensions mm)
Re: Boley 4LV
« Reply #89 on: January 25, 2020, 08:19:49 AM »
Andrew,
Thank you for looking! I am looking for a cylinder, 80mmx100 with a bore of 55mm, so, a bit bigger than anything you have! I have found the POCO Graphite site and I'll do some telephoning on Monday. I have found a very interesting youtube video on making air bearings using graphite, my idea is to make an air-bearing tool holder for my Clarkson tool and cutter grinder!
Thanks again, regards Matthew
Re: Boley 4LV
« Reply #90 on: January 25, 2020, 08:54:56 AM »
So what advantage has the graphite over bronze, or mild steel even?
When the air is applied shaft and housing do not contact each other, so it is only if the air supply fails when the spindle is still driven that there is any issue, and a pressure switch and air reservoir should cope with that contingency  :scratch:
Re: Boley 4LV
« Reply #91 on: January 25, 2020, 10:51:19 AM »
The advantage over metals is that is porous so the compressed air doesn't depend upon drillings to to create the cushion of air and that it is possible to bore it accurately by hand. With a chrome plated rod there would be no risk of corrosion!
Re: Boley 4LV
« Reply #92 on: January 25, 2020, 11:58:49 AM »
Sintered bronze bushes are porous so don't rule them out if the graphite isn't forthcoming (need to flush the lube out first though)
Re: Boley 4LV
« Reply #93 on: January 26, 2020, 08:31:23 AM »
Andrew,
Thanks for the idea, I've found another solution, 4x100mm squares, 25mm  thick that I can stack to get the size I want. Off to order an off-cut of chromed bar!
Cheers, Matthew
Offline RotarySMP
Re: Boley 4LV
« Reply #94 on: January 26, 2020, 10:33:33 AM »
Thanks for posting the Ferosilicon ratio.
The threadjack doesn't bother me, but a project as cool as a home made air spindle for the Clarkson it worthy of it's own thread. I'll be watching out for that, as I have a Clarkson as well.
Mark
Mark
Re: Boley 4LV
« Reply #95 on: January 26, 2020, 12:00:14 PM »
Matthew, beware that a fair amount of graphite came on the market a few years back  from behind the old 'Iron Curtain'  that was suspected to have come from 'test reactors' and was significantly radio-active  :bugeye:
Re: Boley 4LV
« Reply #96 on: January 26, 2020, 12:26:37 PM »
Whilst mild radiation probably isn’t a major concern for wrinklies, better to be safe around younger generations.   Worth having in the workshop, especially with questionable scrap metals for the same reason as Andrew mentioned.
https://www.banggood.com/Geekcreit-Assembled-DIY-Geiger-Counter-Kit-Module-Miller-Tube-GM-Tube-Nuclear-Radiation-Detector-Geekcreit-for-Arduino-products-that-work-with-official-Arduino-boards-p-1136883.html?rmmds=mywishlist&cur_warehouse=CN
Re: Boley 4LV
« Reply #97 on: January 26, 2020, 01:01:56 PM »
Thanks for the warning Andrew, I'll risk it!
Re: Boley 4LV
« Reply #98 on: January 26, 2020, 01:07:00 PM »
Mark
Mark,
I've only got as far as rough dimensions in my head, I've ordered the Graphite and a 70x190mm off-cut of chrome bar, it'll get clearer when the materials arrive!
Cheers, Matthew
Re: Boley 4LV
« Reply #99 on: January 26, 2020, 01:09:40 PM »
hmmmm, I think I'll risk it!!
