Author Topic: What Was This Used For  (Read 18588 times)
« on: October 07, 2012, 05:31:54 PM »
Lads
A friend of my Dad passed away a good few years ago
He was in to model boat building as is my Dad
Today his wife called in to see my Father bringing with her his hobby tools and models
I got all the electric drills sanders ect (no metal working tools)
I did find this one item that interests me , it is made to a very high quality about 4 inch diamiter
Has any one any idea what it was made for it must be quiet old
http://i261.photobucket.com/albums/ii63/john970s0/IMG_4384.jpgWhat Was This Used For
http://i261.photobucket.com/albums/ii63/john970s0/IMG_4383.jpgWhat Was This Used For
http://i261.photobucket.com/albums/ii63/john970s0/IMG_4382.jpgWhat Was This Used For
Re: What Was This Used For
« Reply #1 on: October 07, 2012, 05:58:52 PM »
mmmdon't no just a gess can it be sum sort of molding patern
Baldrocker
« Reply #2 on: October 07, 2012, 06:24:52 PM »
What krv3000 said or maybe an advertising/sample piece.
br
« Reply #3 on: October 07, 2012, 06:29:42 PM »
It is not a pattern
Intersting though
Offline Fergus OMore
« Reply #4 on: October 07, 2012, 06:38:56 PM »
Let's say that  it was 'irish' begorrah.
« Reply #5 on: October 07, 2012, 06:41:19 PM »
Could it be a template for a mold  :coffee:
« Reply #6 on: October 07, 2012, 06:43:01 PM »
Let's get closer and say 'Belfast'
« Reply #7 on: October 07, 2012, 06:56:26 PM »
It's a pastry mold, for making decorative pasty cups.
« Reply #8 on: October 07, 2012, 07:07:39 PM »
well no mater wot it is dont live it liying a rawnd the wife my think its to go on the wood burner   on a nuther note haw is the no smoking gowing and i will be poping up to see you all being well this sat
« Reply #9 on: October 08, 2012, 03:09:21 AM »
Oh dear- the IQ test :doh:
Read what is given.
Machetts is- and Google says- it's a shop. Google says Machett shop is in Belfast
Google says its a music shop.
Oh dear. Oh dear. And it still exists.
« Reply #10 on: October 08, 2012, 10:20:21 AM »
It is not a pattern
Intersting though
Why not a pattern, it looks like one!
Offline 75Plus
« Reply #11 on: October 08, 2012, 10:38:55 AM »
Read what is given.
Fergus,
You mis-spelled your search word. It is Machfitt which when Googled takes you to Machfitt Flooring and other locations.
My guess for the use would be a paper weight as it appears to have been handled quite a bit.
Joe
« Reply #12 on: October 08, 2012, 11:07:00 AM »
Ah well, I got to Machett Music  and it
 is probably 'Machine Fitting Shop'
So it looks like a mould for a gear.
What a shame to find it so boring :doh:
« Last Edit: October 08, 2012, 11:48:09 AM by Fergus OMore »
« Reply #13 on: October 08, 2012, 11:47:29 AM »
No-one has explained the word "slot" yet.
Machfitt Shop Slot?
Slot Machfitt Shop?
Shop Slot Machfitt?
Googling returns nothing useful; Machfitt flooring as already mentioned (doesn't explain shot; or shop particularly well).
There's no sign of Machfitt in either the Domesday book or 1911 census (or earlier). Could Machfitt be German, i.e. this was something that came over during or after WW1 or 2? Again, google is unhelpful.
If it were not stamped, I would have suggested it was an engineer's exercise, judging by the lines drawn on the teeth; I would definitely think it was handmade, but as to its purpose or maker, it would seem the required information is not yet online...
« Reply #14 on: October 08, 2012, 11:50:40 AM »
Apologies- Ade!
See my boring correction.
N
« Reply #15 on: October 08, 2012, 11:53:38 AM »
Apologies- Ade!
N
You must have been typing at the same time I was...
Hmm - Slot[ting] Mach[ine] Fitt[ing] Shop? Tenuous.... it reminds me of one those Backronyms you see so often these days.
PS: If it were a mould, wouldn't it need to split at the widest point to facilitate its removal?
« Reply #16 on: October 08, 2012, 12:20:20 PM »
There is a misplaced "." between "MACH" and "FITT", as if whoever stamped the letters found he hadn't left quite enough room when he got to the end. Accordingly, perhaps it should begin with FITT, and be read as FITT.SHOP.SLOT.MACH.
FITT: must be an abbreviation = Fitting, Fitters ?
SHOP: probably a full word, rather than an abbreviation.
SLOT: might be a full word, but more likely an abbreviation for something like "Slotting"
MACH: probably an abbreviation for Machine or Machinery.
Not that this adds much illumination.
Andy.
Offline 90LX_Notch
« Reply #17 on: October 08, 2012, 06:00:07 PM »
A pattern for a gear for the repair of a slotting machine (slotter) that was located in the fitting shop?  That explains the lack of a part number and a manufacturer's name.
Former HMEM member.
« Reply #18 on: October 08, 2012, 06:06:14 PM »
This item is very intreging
It is not a pattern for casting (the angles are all wrong for that)
It is held together by a wood screw i will take it apart and report back  :drool: :drool: :drool:
« Reply #19 on: October 09, 2012, 03:07:21 AM »
          I was actually going through a routine of checking back history- I was wrong but the principle applies.
I assume that your father's friend worked locally ie on the Tyne somewhere. Your Dad would know this. There are still some of us who have 'survived' and still are 'with it' to work it out.
For a start, it is going to be a biggish firm to have a  separate
 machine shop for slotters. I was thinking of Vickers intially  but thought more of Churchill Gears that were at Blaydon. It sort of ties in with the type face used on wood which I have on some of my stuff from the 40's and 50's.
Regards
Norman
« Last Edit: October 09, 2012, 04:11:25 AM by Fergus OMore »
