Author Topic: Potty Dake Engine  (Read 69126 times)
Re: Potty Dake Engine
« Reply #25 on: November 07, 2012, 01:44:03 AM »
Found this picture of a dake engine being used to power a winch, this got me wondering if I could use my engine to model this set up, but I'll need to drop on some gears bigest about 4 to 5 " with the reduction train to match, can any one help ?.
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/DCP_1520a.jpgPotty Dake Engine
« Reply #26 on: November 07, 2012, 02:10:25 AM »
Hi Stew
Adding the winch would be a touch. Dont think i have any gears lying about. If you get stuck i could cut a set ot plain gears, leaving you to cut the spokes out.
« Reply #27 on: November 08, 2012, 02:27:48 AM »
Thanks Rob
I won't be taking this any further until I know I have a running engine, in the mean time I'll keep looking for gears, if nothing turns up I may just take you up on the offer.
Thanks again
« Reply #28 on: November 08, 2012, 12:19:40 PM »
I realy wasn't looking forward to maching the recesses I'd ran through it countless times in my mind with some wierd and wonderful ideas, but wonce I'd got the parts arround me I decided to keep to the simplest method.
So for the frame I just bolted the back plate to the frame, clocked it up square on the mill table.
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2422.jpgPotty Dake Engine
Then centred the mill on the bearing housing bore in the back plate.
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2425.jpgPotty Dake Engine
sorry about the crap pic.
Then using the boring head bored out the recess.
sorry no pic.
This is it finished.
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2426.jpgPotty Dake Engine
For the inner piston again this was squared up on the table, and using the edge finders it was centred under the mill
At this point thing got hairy.
I had the boring tool sticking out of the side of the head as i thought this was a less flimsy set up but it ment I had to run the mill in referse, this worked fine for the outer frame.
But I didn't realise the mill head was screwed into the morse taper mandrell, this time the bugger unscrewed.  :doh: :(
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2438.jpgPotty Dake Engine
This gave me an involantry bowel movement, after a shower and a change of pants,  :lol: things wern't as bad as they looked the part and boring head wasn't damaged.
So changed to this method i was pushing the capacity if the head, but by taking small cuts it all worked out.
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2441.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2447.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2448.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Dake%20Engine/131_2449.jpgPotty Dake Engine
Hopefully that the worst bit over, its getting close to the moment of truth.
« Reply #29 on: November 08, 2012, 02:04:43 PM »
Whoops! Glad it did no harm, considering the amount of work you've put into it.
I see that we got the full unexpurgated version, whereas you redacted it for the ME forum. They only got your last pic, labelled "Got the recesses machined in the cylinder for the inner piston flange apparently this helps with sealing of the ports."
« Reply #30 on: November 08, 2012, 02:56:07 PM »
Well...... That incident gave me something to comment on Stew!  :bugeye:
So pleased, no operators, (or project or equipment), were harmed during the making of this adventure.
I'm still smockravelled with the rest of it, though........  :scratch:
Keep on, keeping on mate!  :thumbup:
« Reply #31 on: November 10, 2012, 06:22:06 AM »
Made the crank yesterday, and i was thinking not much more now just the flywheel, then I remembered I had a spare 4" flywheel from the Simpson and Shipton build why not give it a go
And it lives:----              we have a runner
 :nrocks: :nrocks: :nrocks: :nrocks: :nrocks:
 :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb:
 :headbang: :headbang: :headbang: :headbang: :headbang:
I'll make a vid and post it sometimes over the week end
« Reply #32 on: November 10, 2012, 07:04:50 AM »
Video - or it didn't happen :)
Well done Stew - superb job  :bow:
« Reply #33 on: November 10, 2012, 07:06:07 AM »
Thanks Bill
Her's the vid
« Last Edit: November 10, 2012, 08:56:13 AM by Stilldrillin »
« Reply #34 on: November 10, 2012, 07:11:26 AM »
 :clap: :clap: :clap: :clap: :clap: :clap: nice one Stew  :)
« Reply #35 on: November 10, 2012, 07:15:28 AM »
 :thumbup: Another great little engine rolls off your production line! I don't know how you get them to run first time.
« Reply #36 on: November 10, 2012, 08:33:55 AM »
That's marvellous Stew!  :thumbup:
Job's a good un!  :clap: :clap:
« Reply #37 on: November 10, 2012, 02:19:03 PM »
Wow you did it again  :bow: :bow: :bow: :bow: :bow:
Offline Noitoen
« Reply #38 on: November 11, 2012, 10:41:04 AM »
Sounds like a a truck with a flat battery trying to start  :thumbup:
« Reply #39 on: November 12, 2012, 01:53:11 PM »
Thanks Guys
by popular request her's the vid of the innards, hope you don't think my explination is too clumsy.
« Reply #40 on: November 12, 2012, 02:48:48 PM »
Thank you very much for good explonation on this marveles machine. You are an artist and this engine is a pice of art.
 :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
« Reply #41 on: November 12, 2012, 03:41:26 PM »
There's nowt clumsy, about that description Stew.   :smart:
I've got it, now......... I think!  :thumbup:
Well done, on all counts.  :clap: :clap:
Offline Deko
« Reply #42 on: November 12, 2012, 06:03:04 PM »
Stew, you should have made two.  One with no valve plate so you could use the complete one to drive the other (the one with no valve plate) so when showing folk they can see how it works. I am sure most folk will not have a clue otherwise, they will no doubt think it is some kind of turbine.  :palm:  Excellent job as usual. :thumbup:
Cheers Dek.
P.S. Gears and perspex still here !!! ( only one of each, large one 3.7" 4 to 1 small one)
« Reply #43 on: November 13, 2012, 02:48:26 AM »
Cheers Guys
Cheers Dek.
I've kicked the winch idea into touch Dek I don't think it will be feasable because of its slow running and at the moment it hasn't got a lot of power I can easily stop it with my hand so I don't think it will drive the gear train. In stead I'm going to make a big 4.5" light weight drive pully, just ordered a length of tube from ebay.
I was wondering about a wood model to show the innerds, but not sure if I'll do that as I wan't to get on with the Simplex work, just too many projects  :proj:
 :D
« Reply #44 on: November 19, 2012, 12:56:28 PM »
Where have the links to the vids gone  :scratch:
Bit of an update:- made the two way valve.
http://i431.photobucket.com/albums/qq32/sbwhart/Photobucket%20Desktop%20-%20STEWART-HP/IMG_3842.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Photobucket%20Desktop%20-%20STEWART-HP/IMG_3843.jpgPotty Dake Engine
Not bad:- still needs a bit of sculpting though.
« Reply #45 on: November 19, 2012, 01:17:42 PM »
That looks good Stew!  :clap: :clap:
What links, to which vids? Looks ok to me......... :scratch:
« Reply #46 on: November 19, 2012, 01:44:43 PM »
I think its my end Dave, had a clean up of my programmes and I think I deleted something that lets me see videos.
I get this message on the BBC site Cannot play media:-- You do not have the correct version of the flash player. Download the correct version
It has a link to adobie flash player tried down loading it but nothing happens, have we got a computer buff out their who can help.
« Reply #47 on: November 19, 2012, 02:21:37 PM »
That's ok Stew!  :thumbup:
We'll blame you..........
« Reply #48 on: November 21, 2012, 02:19:46 AM »
What an interesting and fun engine, I am very impressed, well done.
        David
« Reply #49 on: November 25, 2012, 05:05:58 AM »
Thanks Guys
Decided to make a pully for the engine, as i think making it into a winch would be a none starter.
Made it from a bit of 4 1/2" steel tube with the spokes generated from a bit of 5mm plate and stuck the lot together with high strength loctite.
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_3860.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_3866.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_3881.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_3888.jpgPotty Dake Engine
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_3884.jpgPotty Dake Engine
