Author Topic: Box Spanner Fix  (Read 8699 times)
Offline mzt
Box Spanner Fix
« on: September 12, 2012, 03:42:27 AM »
Some days ago, I had to apply a pipe to the handle of the box spanner I’m using on the mill, to remove an overtightened drill chuck:
ended with the business end of the spanner breaking into pieces, luckily the chuck was released at the same moment.
This is definitely not a fix, but I needed something made quickly (and it is still working after a few days. Might end up with
press fitting a collar to this one, someday)
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1197.jpgBox Spanner Fix
But I want a more durable one (though the above one reminds me not to overtighten the chuck ANYTIME I’m using it).
Started with this
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1200.jpgBox Spanner Fix
And drilled thru a portion of it to the distance between the flats of the square on the drawbar (8mm),
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1201.jpgBox Spanner Fix
then some length of it to the distance between the opposite corners (10mm)
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1203.jpgBox Spanner Fix
A quick visit to the marking bench
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1206.jpgBox Spanner Fix
Then to the mill, to drill the four 1.5mm dia holes (some 12mm deep)
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1208.jpgBox Spanner Fix
Took a picture of the other end, too, toghether with the next tool I’ll use, tomorrow.
(I wish I kew where the square file is gone: will do with the triangular one with a little more care).
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/01_IMG_1210.jpgBox Spanner Fix
Passing close to the vise, on my way to bed… ..it’s almost done now, but no pictures yet.
Marcello
Re: Box Spanner Fix
« Reply #1 on: September 12, 2012, 03:46:48 AM »
After some careful filing, that will be a great repair Marcello!  :clap: :clap: :thumbup:
Offline mzt
Re: Box Spanner Fix
« Reply #2 on: September 13, 2012, 06:03:00 AM »
The spanner shaft (a 12mm bolt, should be strong enough for the job) turned to .07mm interference fit,
drilled for the handle, tapped for a set screw.
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/02_IMG_1216.jpgBox Spanner Fix
Now in the press, barely within the envelope of the machine
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/02_IMG_1219.jpgBox Spanner Fix
Here it is! I’m definitely satisfied with the fit and finish of the square socket.
May add a taper pin, or have somebody welding the parts together, someday.
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/02_IMG_1220.jpgBox Spanner Fix
Marcello
Offline mzt
Re: Box Spanner Fix
« Reply #3 on: September 20, 2012, 04:21:38 AM »
Now I have a working replacement wrench, I can take the risk of fixing the broken one, finally.
First of all, I removed the jubilee clip and paper tape that were holding the loctited part in place,
then put it into the lathe to gain a round end: was not sure about applying intermittent cuts to a glued part,
but it did not move. That material is glass hard, btw.
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/03_IMG_1228_zps9b1a2fc0.jpgBox Spanner Fix
Next, I turned an alu. collar to press fitting diameter. I suppose steel would have done better, but there
were some alu. tubing odds into the box: too tempting.
Press-fitting the collar.
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/03_IMG_1230_zpse0ff414c.jpgBox Spanner Fix
The finished job.
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/03_IMG_1236_zpsae7c8300.jpgBox Spanner Fix
As for the homemade one, I managed to fit an 1/8" taper pin in it.
http://i1226.photobucket.com/albums/ee403/mzetati/_Tools/Box%20Spanner/03_ITaperPin_zps3643d3e3.jpgBox Spanner Fix
I measured the diameter of the pin at (A) and (B), then divided the distance from A to B by the number of drills
I had... then it was only a matter of applying enough force to have the pin squeezed down the stepped hole.
Marcello
