Author Topic: Cutting Big Holes In Thin Sheet  (Read 18600 times)
« on: September 11, 2012, 04:56:57 PM »
Lads
I have been wanting to make a storage rack for R8 collets for some time
I had thought about using wood (but i just dont like the stuff)
Settled in some 1.4 mm aluminium
This was cut to size and bent to fit in a metal drawer
Marked out to give 30 holes
I made a simple hole cutter from some shiney bits of steel i had found under the bench
The pictures tell the story
The studding is 10mm the finished holes 23mm
Finished job much better than those red plastic tubes
Re: Cutting Big Holes In Thin Sheet
« Reply #1 on: September 11, 2012, 04:59:26 PM »
Nice job and well executed..... :bow:
Looks simialr to the Qmax chassis punches that were around in the 70's.. ( I think they are still available? )
« Reply #2 on: September 11, 2012, 05:01:56 PM »
Basically a home made copy
Great for aluminium
Would need to be hardend for steel
« Reply #3 on: September 11, 2012, 06:47:31 PM »
well dun john
« Reply #4 on: September 11, 2012, 09:42:50 PM »
It looks like those holes came out nice and cleanly.  I wouldn't have realized that you could get such nice results with that method.
« Reply #5 on: September 12, 2012, 03:53:48 AM »
Oh! I like that method John!  :clap: :clap:
Beautiful finished product too.....  :thumbup:
« Reply #6 on: September 12, 2012, 04:30:30 AM »
Yes John, still around. Bought a 5/8" about a year ago. I have about 12 of them. No soddin' 5/8" size though.
How is it you seem to have every size except the one you need ...
I felt sure I should have one. IIRC it was for B7G valve bases ...
Dave BC
« Reply #7 on: September 12, 2012, 06:47:45 AM »
Tidy work there John... that die - did you cut it on the lathe with an interrupted cut, or on the mill with a large cutter, or some other method?
Thanks for showing  :thumbup:
« Reply #8 on: September 12, 2012, 07:12:46 AM »
Ade
I turned the die to be a good fit in the sleve then just put it in the vice and milled the end with a big cutter
A bit dress up with a file
  • Country: za
« Reply #9 on: September 13, 2012, 02:44:05 PM »
Nicely done  :thumbup: :clap: :bow:
