Author Topic: M & W Automatic Centre Punch - Repair?  (Read 17159 times)
« on: August 18, 2012, 11:28:03 AM »
Hi there, all,
I have a poorly Moore & Wright automatic centre punch, if I adjust the punch pressure from minimum to maximum it auto-punches OK the first time and then goes all passive.
I've partially dismantled it but haven't found anything obviously wrong.   :bang:
Before I go for broke and take it completely to pieces, PLEASE is there anyone out there who is familiar with the internals of the beast and can give me any pointers?
A photo or exploded diagram would be nice.
Re: M & W Automatic Centre Punch - Repair?
« Reply #1 on: August 18, 2012, 06:11:28 PM »
hi well i have one of them and it did the same thing as your has dun when i gave it a bit oil i striped it all out gave it a bathe in sum pant thiners then i put it back together with sum white grees worked well ever since
Offline Mayhem
  • purveyor of mischief
« Reply #2 on: August 20, 2012, 05:51:48 AM »
Hope this helps.  I know the little baseball bat part has to be the right way around otherwise it won't work.
Sometimes mine does what you describe and if I give it a light tap against the bench it is fine.  Mine probably needs a lube but you know how it goes...
Offline holmes_ca
« Reply #3 on: October 11, 2013, 01:45:15 AM »
Hi there, all,
Pete, I have the heavy duty M&W the one with the large ball on the top handle, I can take a photo tomorrow and forward showing the internal parts and how they are arranged in stages, I must say mine works perfectly, I use it all the time,
Let me know if interested,
......Edmund......Alberta......Canada
« Reply #4 on: October 11, 2013, 03:48:40 AM »
Pete, mine went all limp on me as well a few years ago  :(
Nothing at all looked wrong with it, but as I had spare points for it I changed it out and it cured the fault. There must be some rounding on the back groove of the point, but for the life of me I couldn't see what. Certainly when I put the old one back the symptoms returned.
« Reply #5 on: October 12, 2013, 04:22:51 PM »
Hi there, Edmund and Andrew,
Thank you for your posts.
Edmund:  I'd be very grateful to see some photos of your centre punch in its dis-assembled state but I hope that it'll still be working once you've re-assembled it!  I'd hate to have it on my conscience if it didn't survive the experience!!
Andrew:  I'll take mine to pieces again and examine the back end of the point.
I bought this centre punch as a back-up but my main one seems to have gone into hiding!   :bang:   :bang:   :bang:
