Author Topic: Overhaul of my SB 9A  (Read 43321 times)
Offline steamer
Re: Overhaul of my SB 9A
« Reply #25 on: August 26, 2012, 07:43:01 AM »
OK this week, I'll be sending my bed out for grinding hopefully this week,,,,,as long as work doesn't get in the way.
"Mister M'Andrew, don't you think steam spoils romance at sea?"
Damned ijjit!
Offline steamer
« Reply #26 on: September 27, 2012, 05:20:22 AM »
OK!    The bed has been ground!   It should be here on Friday....then the fun begins!  :beer:
The bed was a mess.   There was .007" of wear on the front way....the rear way was higher than the front way...which means it was machined that way in 1951...Neither of the saddle ways were straight and the gib way....the one underneath on the back of the bed that the saddle gib bears against was out of parallel by .003".   Additionally the V ways were not 90 degrees.
But all the flaking was there! :lol:.....which means it was machined...and flaked.., but not scraped for alignment...ever!
So much for Southbend quality!.....
All has been corrected...everything...I've been told .....is parallel to .0004" over the 54" length.
That'll do
Now the scraping begins....saddle first.
I have some mods to do to the saddle and the tailstock...and the bench...patience.
Damned ijjit!
Offline Sic Semper Tyrannis
« Reply #27 on: September 27, 2012, 01:43:28 PM »
Who ground it?  What was turnaround?  Can you share price?
Offline RotarySMP
« Reply #28 on: September 27, 2012, 03:05:53 PM »
While you are waiting for it to return, you could build a wooden chuck carrier, so your don't ding that beautiful bed during a chuck change :)
http://www.homemadetools.net/images/3/handmade_chuck_carrier.jpg
http://www.practicalmachinist.com/vb/attachments/f38/11731d1234044888-lathe-chuck-how-big-can-i-hand-mount-000_0649-1.jpg
Mark
Offline steamer
« Reply #29 on: September 27, 2012, 09:22:42 PM »
The grinder was Forest City Grinding, Rockford Illinois.
His prices are VERY reasonable.....but not cheap.  ( 500-1000)
However, I'd say they are far more reasonable than some I got quotes from  :jaw:
If you contact him, have your act together and know what you want.   He's very busy.
I found him extremely easy to work with.
You have to find your own way to ship back and forth.
Damned ijjit!
Offline steamer
« Reply #30 on: September 27, 2012, 09:31:59 PM »
Thanks for the pictures and reply Rotary!
I plan to use a piece of plywood like I usually do...which should suffice.   I might mention my 12" logan has chucks heavy enough to use a cradle though
Damned ijjit!
Offline RotarySMP
« Reply #31 on: September 28, 2012, 04:56:50 PM »
Looking forward to seeing photos of the the newly ground bed.
Mark
Offline steamer
« Reply #32 on: September 28, 2012, 05:54:54 PM »
Me Too!    shipping is delayed.....Monday!
Damned ijjit!
« Reply #33 on: September 29, 2012, 04:22:08 AM »
Dont no how i missed the start of this thread  :palm:
first rate job Dave  :med:
Now this is a true machine overhaul showing how it really should be done ,i am sure you will be rewarded a hundred fold by the work and attention to detail you have put in .
what make of marking dye are you using ?
Offline steamer
« Reply #34 on: September 29, 2012, 09:12:15 AM »
Hi Rob,
Here you go.
It's water soluable and readily available.    E S Dyjek
http://i164.photobucket.com/albums/u27/mcandrew1894/tooling/P2050083.jpgOverhaul of my SB 9A
Damned ijjit!
Offline steamer
« Reply #35 on: October 03, 2012, 05:54:48 PM »
Here's the bed....need to check it but it sure looks nice!
http://i164.photobucket.com/albums/u27/mcandrew1894/Southbend%209A/2012-10-02_20-15-18_791.jpgOverhaul of my SB 9A
http://i164.photobucket.com/albums/u27/mcandrew1894/Southbend%209A/2012-10-02_20-15-24_915.jpgOverhaul of my SB 9A
http://i164.photobucket.com/albums/u27/mcandrew1894/Southbend%209A/2012-10-02_20-15-36_390.jpgOverhaul of my SB 9A
http://i164.photobucket.com/albums/u27/mcandrew1894/Southbend%209A/2012-10-02_20-15-47_928.jpgOverhaul of my SB 9A
Damned ijjit!
Offline RotarySMP
« Reply #36 on: October 04, 2012, 04:44:31 PM »
Nice!
Mark
