Author Topic: Big Mill Engine  (Read 25584 times)
Big Mill Engine
« on: July 22, 2012, 05:16:39 PM »
Lads
Made a start machining the engine base cast yesterday
I cant do much untill i get the cylinder cast & machined
This bit was just plain hard work ,eventually i had a nice flat face to work from
It is a decent size when you see it on the mill:slaphead::slaphead:
Re: Big Mill Engine
« Reply #1 on: July 22, 2012, 05:20:44 PM »
It just fits on the 626 MILL John  :lol: :lol: :lol:
Re: Big Mill Engine
« Reply #2 on: July 22, 2012, 05:22:29 PM »
yep he got the lenth right
Re: Big Mill Engine
« Reply #3 on: July 28, 2012, 10:39:30 AM »
Jesus ... it's a monster!  :bugeye:
Are you just machining things to fit around this as you go then John?
Re: Big Mill Engine
« Reply #4 on: July 28, 2012, 11:57:15 AM »
Very nice, but I have to ask, how big is this monster  :lol: :lol: :lol:
Re: Big Mill Engine
« Reply #5 on: July 28, 2012, 12:45:17 PM »
I have modified the patern i used for the marine engine once i have a cylinder things will just start to appear
Re: Big Mill Engine
« Reply #6 on: July 28, 2012, 01:01:10 PM »
 :jaw:
That thing is a monster!
  • Country: za
Re: Big Mill Engine
« Reply #7 on: July 29, 2012, 02:44:50 PM »
Sure is a big un  :clap:
Re: Big Mill Engine
« Reply #8 on: July 29, 2012, 03:56:50 PM »
Lads
Not much progress to report
I was hoping to get the cylinder cast today
I painted the modified patern yesterday and the paint reacted (it looked like it had the pox)
Paint stripper and start again is the only way
Re: Big Mill Engine
« Reply #9 on: July 29, 2012, 04:47:14 PM »
By 'ek John!
That's just a bit awesome......  :bugeye:
Good luck with the build!  :thumbup:
Offline millwright
  • Leeds West Yorshire
Re: Big Mill Engine
« Reply #10 on: July 29, 2012, 04:57:09 PM »
Didnt realise the size of it John, Now you have put in perspective  :bugeye: wow
Re: Big Mill Engine
« Reply #11 on: July 29, 2012, 05:37:42 PM »
well pefecshon can not be rusht john  keep it up
Offline nel2lar
Re: Big Mill Engine
« Reply #12 on: July 29, 2012, 09:27:33 PM »
Are you going to pour the cylinder in brass? That is a first class act. Looking good.
Nelson C
Re: Big Mill Engine
« Reply #13 on: July 30, 2012, 03:04:36 AM »
  Hi John , looking good  :clap: :thumbup: :clap: :thumbup: , dont know how but just noticed the posts now , will be watching as you go.
   :beer: Mick.
Offline nel2lar
Re: Big Mill Engine
« Reply #14 on: September 26, 2013, 12:10:58 AM »
What happened to the Big Mill Engine? Looks like you staled out. How come.
Nelson Collar
Re: Big Mill Engine
« Reply #15 on: September 26, 2013, 01:56:08 AM »
Too busy, making videos?   :thumbup:
Re: Big Mill Engine
« Reply #16 on: September 26, 2013, 03:22:12 AM »
Will be interesting to see how big you can get the flywheel machined ?
Offline NeoTech
    • Roughedge Hobbyworks
Re: Big Mill Engine
« Reply #17 on: September 26, 2013, 03:42:08 AM »
How many pounds of aluminium goes into that thing? Or Volume.. didnt know you hade the capacity for such big pours. =)
Re: Big Mill Engine
« Reply #18 on: September 26, 2013, 06:19:07 AM »
Should be able to machine quite a large flywheel horizontally on his 626 vertical mill with ingenuity - could even mount an outrigger for the hub to increase maximum diameter. (That's actually an advantage of the Bridgeport style in that you can swing the ram and head a long way left or right for this sort of thing)
Andrew
Re: Big Mill Engine
« Reply #19 on: September 26, 2013, 11:10:46 AM »
You can also just make up a temporary "lathe" for something like that. A couple of pillow blocks for an arbor, etc.
Offline S. Heslop
Re: Big Mill Engine
« Reply #20 on: September 26, 2013, 02:21:32 PM »
I've done stuff like this for wood but how would you go about the toolrest for metal?
Re: Big Mill Engine
« Reply #21 on: September 26, 2013, 02:56:11 PM »
The base casting is just "maturing" I will get to it one day
Re: Big Mill Engine
« Reply #22 on: September 26, 2013, 04:39:42 PM »
Steve, two possibilities.
1.)  A simple woodturning style tool rest and a hand graver -- this is how the original metal lathes worked, and for something like a flywheel, I think it would be quite workable -- particularly for aluminum, which I'm guessing would be cast for this engine.
2.) I could easily temporarily remove the cross slide from my Gingery lathe and run it onto a bar of cold rolled steel as ways -- since that's what the ways are composed of in the first place.
It may be possible to do the same thing by removing the cross slide from another type lathe fastening it down on the temporary setup, and just using the top slide for motion. The range of motion needed to finish the rim of a flywheel is quite small, and this is a one time job, equivalent to faceplate work, so a little ingenuity would see it accomplished with minimal materials, I think.
Probably my first choice would be # 1 above, as a flywheel rim isn't required to fit anything, but must only be made concentric to the bore and smooth.
Offline Jasonb
Re: Big Mill Engine
« Reply #23 on: September 27, 2013, 02:23:24 AM »
Picture is as good as a thousand words
J
Re: Big Mill Engine
« Reply #24 on: September 27, 2013, 03:51:31 AM »
J
So true!  :bugeye:
What a crackin' setup! For a "bodge job".  :clap: :clap:
Takes me back to my early days, with my oppo, Harry. Together, we were devastating........  :thumbup:
