Author Topic: ML10 sadle travis handle thread  (Read 10719 times)
Offline HS93
« on: July 21, 2012, 08:41:11 PM »
HI I have a ML10 at the moment I am having problems with my hands and am finding the small handle that travises the sadle hard to use, it is a typical myford handle that is just threaded on my lathe is a late imperial lathe so does anybody know what thread it is so I can get an adapter made to fit a slightley biger round folding handle, any help would be appreatiated
Peter
Re: ML10 sadle travis handle thread
« Reply #1 on: July 22, 2012, 03:48:34 AM »
Hi Peter ,  is the hand wheel difficult to get off ?
Just a thought , what about doing away with the handle and fitting a motor to drive the carriage  :zap:
« Reply #2 on: July 22, 2012, 04:05:12 AM »
HI PETER THE THREAD YOU REFER TO IS 5/16 INCH BSF   REGARDS  DAVID
« Reply #3 on: July 22, 2012, 04:24:21 AM »
Nice one David  :thumbup:  , and welcome to Madmodder  :wave:
Offline HS93
« Reply #4 on: July 22, 2012, 05:48:16 AM »
thank you for that ,Ill order a tap today . and welcome to maddmodders you will like it hear a great buch  of helpfull people.
                                   :ddb: :nrocks: :ddb: Peter  :ddb: :nrocks: :ddb:
        :mmr:
Offline HS93
« Reply #5 on: July 22, 2012, 06:00:44 AM »
Hi I have been  thinking of fitting a stepper to it for some time, I dont do screw cutting but it would not stop me if I wanted to anyway I have a dog clutch, I am about to get someone to move the lathe of it's risers and on to the bench so I can fit a glass scale, so I will look in to a simple belt drive like I did on the mill z way.
thanks again Rob, the gloves are great after one wear they expand and fit nice.
        :mmr:
« Reply #6 on: July 22, 2012, 04:43:33 PM »
hi well this is a bit of a tip get sum toothd belt and  mack a band out of it to go rawnd your hand wheels if thats the type you are gowing to fit see pic
Offline HS93
« Reply #7 on: July 22, 2012, 05:22:05 PM »
Ill try that. thanks
Peter
« Reply #8 on: July 22, 2012, 05:28:37 PM »
Pleased the gloves do the job for you Peter , giz a shout if you run out  :thumbup:
