Author Topic: Lightning Strike  (Read 10671 times)
Offline 75Plus
Lightning Strike
« on: June 30, 2012, 10:17:52 AM »
In a recent post lightning striking a bridge was mentioned.
Check out this aircraft strike.
This is the biggest hole in an aircraft caused by a lightning strike that I
have ever seen. The pilot must have gotten religion immediately after he wet
his pants. I'll bet his ears rang for quite a while afterwards.
OK. So, you're in the left-hand seat of an airliner, cruising gently along
at 400 knots.  The aircraft's on auto-pilot and you're browsing through The
Financial Times, checking to see how your new shares in Facebook are
performing while you sip a nice cup of coffee. Suddenly the loudest sound
you will ever hear goes off just behind your left ear! You're blinded by the
flash and can't hear yourself panic. But you're still alive, so you
immediately consider retirement!!
Re: Lightning Strike
« Reply #1 on: June 30, 2012, 11:58:41 AM »
Sure it's lightening ?
By the shape of the hole in the second picture it looks like someone in cattle class has exited after being offered seconds on the airlines main meal.
John S.
Offline kwackers
« Reply #2 on: June 30, 2012, 05:37:08 PM »
Shouldn't there be another hole somewhere?
The plane cant just absorb the energy so it must have left/entered somewhere else.
« Reply #3 on: June 30, 2012, 06:35:11 PM »
The plane cant just absorb the energy ....
Yeah, it can.
Black Hole innit ???   :smart:
BC
« Reply #4 on: July 01, 2012, 04:00:15 AM »
Normally, lightning barely affects aircraft. They are frequently struck - being big metal objects - but the lightning simply passes over the skin and continues towards its target - ground...
If this plane was on the ground when it was struck, then I can understand the damage; but in the air? Does not compute...
tumutbound
« Reply #5 on: July 01, 2012, 04:13:18 AM »
It wasn't a lightning strike but an electrical fire that happened on the ground.
Some more details here.
