Author Topic: Furnace temperature  (Read 11896 times)
Offline ironman
Furnace temperature
« on: June 26, 2012, 12:22:44 AM »
Have you ever wondered how hot it gets in a furnace melting cast iron? Have a look at my video
Here is another video about making a cast iron flywheel for a model steam engine
   ironman
Re: Furnace temperature
« Reply #1 on: June 26, 2012, 07:50:37 AM »
What do you use to measure the furnace temperature with? I've seen thermocouples that go to 1100oC, but nothing that will do 1600oC, and my Google powers are weak today...
« Reply #2 on: June 26, 2012, 09:01:55 AM »
Ade,
At work (in the semiconductor industry) we used Platinum Rhodium T/Cs (Type B) which can go up to 1800oC.
I've just found Tungsten Rhenium T/Cs which can go up to an amazing 2300oC!
http://www.thermocoax.com/doc-Temperature_sensors/E201-0_Thermocouple_C.pdf
Cheers.
« Reply #3 on: June 26, 2012, 10:16:14 AM »
....At work (in the semiconductor industry) we used Platinum Rhodium T/Cs (Type B) which can go up to 1800oC.
I've just found Tungsten Rhenium T/Cs which can go up to an amazing 2300oC! ....
Must be a trick spot welder to weld those hot junctions.
So - next challenge for Rob 'the miracle worker' Wilson - can you come up with a suitable rig (chrome plated of course) so we can all make our own?
« Reply #4 on: June 26, 2012, 10:44:46 AM »
Phil - have you seen the price of those things? I've only found 1400oC thermocouples on general sale, and they come in at between £300 and £3500 depending on length & thickness (oo-err). Makes the £28 I paid for a K-type 1100oC one seem quite reasonable...
« Reply #5 on: June 26, 2012, 12:12:34 PM »
Dave -- You don't need to weld TC wires together (though I agree that it is better and more accurate if you do), you can just coat them thermally conductive grease, twist them together, and squash them in a press for intimate contact.  Probably half the TC's currently measuring experiments in R&D labs around the world are assembled this way.
Hopefully I have not lost it (a paper -- not my mind), but I have instructions for making a calibrating an optical pyrometer that we used to measure hypergolic plumes a few years back.  Other than gaining access to qualified high temperature test standards, it is a simple device that only costs a few $$$ to build (under $15 as I recall from 2005).  As my unit was built using customer's parts on time they paid for, it ended up staying with the customer after my work was done.
Offline ironman
« Reply #6 on: June 27, 2012, 12:29:57 AM »
Looks like you have covered the answers I was about to give, R type wire is very expensive but will go to 1770C. K type will only go to 1200c but it is very cheap. That unit I bought about 18 years ago and was very expensive and I see nothing has changed.  ironman
