Author Topic: Overly complex Camera Mount (Lot of Pictures)  (Read 11615 times)
Offline SPiN Racing
« on: February 05, 2009, 10:41:30 PM »
SO I was trying to take pictures of the stuff I have been making.. and decided to make a camera mount.
I was explaining what my idea was to our 14 year old son, and the ideas were flowing.. he was helping build the idea... and the need for more complexity came further and further into play.. and what we ended up with is a little complex..... BUt it should likely work out ok.
In essence.. I have a 0.75 steel rod I am going to cut some threads into, and screw it to a magnetic base, like those for a dial indicator.
What we came up with is several small square blocks of steel with a hole drilled, and a slot cut so they are adjustable. With each pair of blocks attached to each other you will form a simple joint o sorts, and be able to adjust the angles fairly widely.
Anyhow.. here are some pics.
(I still need to go get a base, and use the damn thing)
Oldest son lining up the drill bit to the marked holes in the stock we were cutting the joints out of.
Another shot of my oldest lining up another hole.... And you can see the rod sticking out... that is a "precision" parallel I had.. which consists of a section of threaded rod, with a large long.. nut on it. That happens to bring the metal up to a point it is repeatable, and level.
Lightening holes in it.. ahem
Hacking em out with the band saw...
Parts cut up... Large one doesnt have the slot cut yet.. because it needs to be bored out to 3/4.
My first REAL boring attempt.  Well it wasnt an attempt.. I bored a 0.50 hole to 0.75. SO It wasnt an attempt.  :thumbup:  OH YEAH... Notice its in the 4 Jaw.. and Off center???
Another shot of the boring parts. ;)  Better shot of the 4 Jaw, and the part being off center. (On purpose)
Tada!!!!
Power Tapping  :thumbup: Yes I power tap that stuff.. its mild steel.. with lube, drilled properly. I figure if I can power tap stainless with the libe and stuff, I can power tap mild steel. ANd it tapped into it like butter. I power in, in back gear slow..a bit to get started.. back it out by hand, then manually get it back in the groove, and a turn or two.. then kick on the power again after adding lube. Go about half depth. Then back out some, clean with brush, re-lube, and power back in. Makes nice clean smooth threads. (Not sure if thats right.. but it works LOL)
Parts test fit..
Assembled after slight blingification on the buffer. The blocks are not stainless so I need to shine em up a bit! SO they dont rust. <WINK>
The rods are stainless.. and of course.. a polish was thrown on them as well.
OH and the tapping... went very nicely now that I used the Die the correct way..   :doh:
I will post a pic of it set up once I get the base tomorrow (fingers crossed that Im not sicker)
« Last Edit: February 05, 2009, 10:44:05 PM by SPiN Racing »
SPiN Racing
Re: Overly complex Camera Mount (Lot of Pictures)
« Reply #1 on: February 06, 2009, 02:01:50 AM »
Good Job Scot  :thumbup:.
Nice to see you've got your son working and learning as well.
A bit more bling and you'll be putting Ralph to shame  :lol:
Have Fun
« Reply #2 on: September 20, 2009, 09:54:20 PM »
Spin
Just going thru some old posts and found this one and realized you never posted a picture of the finished product. Just curious. :doh:
« Reply #3 on: September 20, 2009, 10:02:52 PM »
Don,
Seems like Spin has dropped off the earth. His last visit was back on June 25.  :scratch:
Hope he's Ok.
« Reply #4 on: September 20, 2009, 11:29:19 PM »
Thanks
Usually I click on the name and check for last posts but this time I didn't and it came back to bite me. I too hope that he is OK and will some day return. Maybe when winter come and it drives him inside! :lol: :lol:
« Reply #5 on: September 21, 2009, 02:06:59 AM »
Got an email from Scot via u tube when I showed my loco running so he's still keeping an eye on things
Hope he's OK
« Reply #6 on: September 21, 2009, 02:31:25 AM »
Hope he's OK
That good to hear Stew. Thanks for the update.
« Reply #7 on: September 21, 2009, 09:53:36 PM »
That's quite a collection of swarf you have there  :clap:
Offline SPiN Racing
« Reply #8 on: September 23, 2009, 07:16:26 PM »
Heya Guys!
I will pop a post in the general forum, but I am still around when able LOL.
The Camera Mount didnt end up very functional, although it was neat looking. It worked with the mag base I had for it, and It was positionable... BUT only after spending a couple minutes with a Allen Key and adjusting things a bit.
To fine tweak things required the key again and more fine tuning.
I ended up going to Wholesale Tools, and buying a Mag Base with the arms etc for 9.95, and putting the camera on that. :)
SPiN Racing
« Reply #9 on: September 23, 2009, 08:06:31 PM »
SPIN Racing
Glad to see that your still about. I know sometimes life gets in the way of our fun and hobbies. We are always glad to have you here when you are able.  :D :D :D
Cheers  :beer: :
