Author Topic: Chuck stop  (Read 31582 times)
Chuck stop
« on: February 04, 2009, 12:04:43 AM »
To compliment Ralph's mill backstop, here is one for your lathe chuck.
This is an extract from an email I sent to a good friend.
Find attached a C-o-C for a chuck backstop. You might need to find out if the morse taper can fit thru your chuck, if it does, then just use a length of bar to tap it back out from the rear of the spindle when you have finished. I have turned the tapered bit down before now, so it isn't as wide at the big end, just to get it to fit thru the chuck. With all my backstops, I just turn up a range of rod lengths and diameters and use what is required for the job.
I hope it can be understood.
Offline SPiN Racing
Re: Chuck stop
« Reply #1 on: February 04, 2009, 12:40:15 AM »
OK Waitaminute...
Insert Noob comment here.
My Lathe has.. the ability for rod to be passed through it. I think 0.8 diameter.  Are you saying that.. the end of it might be a MT taper? Inside the threaded end? (Threaded where the chuck goes onto it)
Im at work or I would bundle myself up and go out to the garage and check.
SPiN Racing
Re: Chuck stop
« Reply #2 on: February 04, 2009, 01:28:10 AM »
Spin,
If it is any sort of normal lathe it should have a morse taper socket in the spindle nose.
Going by the diameter you have mentioned, it would most probably be 3MT.
If it is a 3MT, you could easily take your chuck off and mount in MT collets. Just make yourself a drawbar to hold them in and tighten them up, away you go, precision machining. But only for short lengths of material.
Offline John-Som
    • Start Model Engineering
Re: Chuck stop
« Reply #3 on: February 04, 2009, 04:48:18 AM »
Thanks John
To suit my particular lathe, which has very limited space behind the chuck - well actually there isn't any space at all. I shall modify the soft MT3 taper by removing all the excess overhang and fitting with a threaded rod and lock nut as per C-o-C
http://i256.photobucket.com/albums/hh200/cormorant2/CCF04022009_00000.jpgChuck stop
John S
start-model-engineering.co.uk - a friendly place for model engineering beginners
Re: Chuck stop
« Reply #4 on: February 04, 2009, 05:18:09 PM »
Nice one John.
Where did you get the blue C-o-C from?
Offline rleete
Re: Chuck stop
« Reply #5 on: February 04, 2009, 06:00:51 PM »
Must be the advanced package.
Re: Chuck stop
« Reply #6 on: February 04, 2009, 08:22:26 PM »
Well I doubt I'll be trying to "stylee" one of those up.... But making one to do the job will be a fun little exercise  :dremel:
Nice to know your still holding back tips n tricks to surprise us with John   :smart:    :)
Re: Chuck stop
« Reply #7 on: February 05, 2009, 04:01:57 AM »
Defintely not holding back Ralph.
I have to wait until it resurfaces from the dark chasms of the grey matter before it gets posted. :med:
Reminders are a great help, when people ask for suggestions or ways to do things :wack: :poke:, then it all comes flooding trickling back.  :smart:
But I have to be quick to catch it, otherwise it sinks again. :med:
Re: Chuck stop
« Reply #8 on: February 05, 2009, 04:10:44 AM »
I have just had another look at your C-o-C, do I detect a bit of banned straight edge use in there?
I have to draw the line here, that is getting very close to technical drawing, a totally different product, and one which will mean you paying royalties on my other package R-o-C (Rule-o-Cad). :lol:
Damn those pirates. :hammer:
Offline John-Som
Re: Chuck stop
« Reply #9 on: February 05, 2009, 04:36:39 AM »
honest guv, no mechanical aids were used in producing my superior C-o-C though I will admit to a nip of the hard stuff to steady my wavering hand. Oh and version 3.2 does feature a colour upgrade. Jolly useful if you are making bits out of coloured plastic.
JohnS
