Author Topic: lathe cross slide 'dishing'  (Read 76443 times)
Offline steamer
Re: lathe cross slide 'dishing'
« Reply #25 on: June 03, 2012, 12:55:00 PM »
If the perfect lathe was perfectly rigid, a working tolerance would be superfluous...we would strive for perfect geometry to compliment the perfect rigidity.  All the parts made on the perfectly rigid perfectly aligned lathe,....would be perfect.
We don't live in a perfect world though do we..
Concave facing allows a part fixed to a faceplate to bear on the outside diameter.  A very stable condition!    Otherwise if the part was convex, it would only bear on the center and perhaps 1 line along the side of the cone so generated.   A very unstable condition.
Draw the figures for yourself...you will see what I mean.....and as a side note, at the tolerance levels we're talking about, whether it's conical or spherical ...well it's REAL hard to tell.
Additionally as a facing cut is put on a large diameter part, more axial deflection will occur the farther from center that the tool cuts.   A concave (conical or spherical)  initial condition will counter that to some extent. That's just physics....no material is infinitely rigid....to some small extent, everything is made of rubber...lathes and work pieces alike. The machining process is just not completely deterministic......This can be frustrating, but don't let "perfect" get in the way of "good".  There's still lots of good parts that can be made on our compromised and imperfect lathes
"Mister M'Andrew, don't you think steam spoils romance at sea?"
Damned ijjit!
Offline Davo J
« Reply #26 on: June 04, 2012, 11:09:45 AM »
Your lathe sounds like it's out a lot. I think the manufacturers allow a bit of concave to allow for wear over the years. If it was dead on any wear would meant your parts wouldn't seat properly.
Offline Miner
« Reply #27 on: August 07, 2012, 03:59:18 PM »
This is a fairly old thread, but I thought I'd throw a few extra comments into it. Obviously concave is much better than convex for the reasons already mentioned. You could even readjust, scrape, re-shim everything into dead true, or at least as well as your best indicator would allow you to achieve a flat surface. Except!!!!, just like Davo and maybe others have mentioned, that wouldn't last very long at all due to the way cutting tool pressures would wear the cross slide dovetails. Even the very tight clearances on brand new high end lathes that allow the slide to move at all will show as a deflection at the cutting tool tip. So if everything was adjusted to allow a dead flat facing cut to be taken, and taking into account that deflection. It wouldn't take very long or very much wear and you would then have a lathe that faced convex. So another reason the lathe manufacter's set them up to face concave is to allow them to wear in towards flat. This is the same idea and reason why a lot of tail stock center lines are set slightly high on most good lathes.
It's also quite easy to accurately measure just how much any lathe is out from a dead true facing cut. It does require a good dependable .0001 reading DTI that will give accurate and repeatable readings. Probably for the most of us, the lathes faceplate would be the the logical item to use. Just take a fine faceing cut across it till it fully cleans up. Using a DTI with the indicator tip on the faceplate and moving it across the faceplate from the O.D. towards the center, or going in the opposite direction from the C/L out towards you just like the facing cut was done will tell you less than nothing. Your just duplicating what the facing tool did.  That's not how it's done. You indicate from the face plate C/L to the face plates outer rim farthest away from you. The reading you then get will be TWICE the actual deviation from true flat. Normally a lever type DTI isn't all that accurate for a distance measurement. But for the small deflections you should be seeing, it should be ok.
I'd also caution anyone making this test to not assume the headstock is out of alignment if they get higher indicator readings for concave or convex than they'd like. Those readings could easily be and probably are a cross slide wear or alignment issue. The less you pay for a lathe or the older it is then the more chance there is of it being a cross slide problem.
It's a bit OT to the thread, but if you are going to run this test? Then you may as well test the headstock bearings at the same time. Just take a fine clean up cut on the face plates O.D. and then setup the indicators tip on the face plates OD farthest away from you. To make it a bit clearer, if the cutting tool cut the face plates rim at the 9 0'clock position your going to set the indicators tip at the 3 o'clock position. Slowly rotate the face plate 360 degrees by hand, and the deviation from zero you see will again be twice the amount of what the actual out of round condition is.
« Reply #28 on: August 13, 2012, 04:35:32 PM »
Thanks for that exposition, Pete. As I mentioned in this thread back in April, facing cuts on my Chinese lathe are far more dished than is acceptable, and I have just applied your method of establishing just how bad things are. Not wanting to end up with a badly dished faceplate, I chucked up a 85mm OD, 50mm long lump of cast iron, and used that, taking each cut with the saddle locked, the topslide gibs tightened and the tool held in the original "4-way" toolpost rather than my QCTP, all for maximum rigidity.
Both a finger DTI and a plunger type used from the centre to the far side both indicated a variation of 0.27mm over 40mm; as you said, that needs to be halved, giving 0.135mm dishing over 40mm. The dovetail on top of my saddle is 160mm long, so both sides of the dovetail would need to be skimmed in a sort of wedge shape to a depth (on the headstock side) of virtually nothing at the front to 160/40 x 0.135 = 0.54mm at the back and vice versa on the tailstock side. Actually, 0.45 or 0.50mm would probably be safer, leaving a bit of concavity but definitely avoiding convex facing, which would leave me worse off than I am now.
0.5mm is too much to take off using my meagre scraping skills, particularly inside a dovetail. I thought my dovetails might be the 55° sometimes favoured by the Chinese, but they are 60°. I have procured a good quality 60° cutter, and was thinking of milling the dovetails down, then scraping to final fit. Before doing that, it would obviously be wise to ensure the mill is trammed properly, and that the saddle is of consistent depth with no warp.
Do folk more knowledgeable than me (that would include just about all Madmodders) think this might work, if done carefully?
I have made dovetails before but only little ones on extra holders for my QCTP and the like, where there wasn't much at stake; nothing crucial like this proposal.
Offline Miner
« Reply #29 on: August 13, 2012, 08:05:00 PM »
Andy,
Your more than welcome. Depending on your own perceptions of machine tool alignments and what's normally posted on forums like this. It can be humerous or more than a bit frustrating. I certainly don't and never will know even half of what I'd like to about this subject alone. But you do need to run at least one more test before you go any further. And it's going to be a bit tough to keep this even somewhat short.
Your lathe bed needs to be properly leveled first. No I'm not about to get into exactly why 90% of what's normally posted about that "lathe leveling" is wrong. But it is, and most don't understand that it's only a starting point.
But you need to get your lathe bed leveled as accurately as possible with the most accurate machinist's level you can find, buy, borrow, beg, or steal. That puts your lathe bed into an "almost" neutral cutting condition. That's your starting point. You'll now need a fairly large diameter bar of free machining material. Aluminum, brass, or leaded steel would be best. The material length sticking out past the lathe chuck should be no more than 3 times it's diameter. Obviously the larger the diameter is, then the longer it can be, and the more accurate and finer your test results will be. You have to test the headstock alignment before you start remachining or scrapeing anything to be sure you don't in fact have a headstock alignment issue.
Best case? I'd shoot for something like 3" plus in diameter and say 6" plus long, yes that's a 2-1 ratio. But it's also more dependable and your not pushing the limits. So you start out with a leveled lathe bed in that neutral condition, then with that bar sticking out of the lathes chuck and WITHOUT tailstock support. You then make cutting passes till the bar is fully machined around it's OD and from it's outer end and all the way up to the lathe chuck. Your last clean up pass should be with a freshly sharpened tool, or a brand new carbide tip and an ultra fine depth of cut so your not putting any heavy stress into the part your cutting. Use a really good micrometer and get a good accurate OD dimension on the outboard end, and as close to the chuck as you can get. This will give you the results of how well aligned your headstock is to the lathe bed. This test IS NOT optional. You have to know exactly what you have before you start any remachining for alignment. Ideally both measurements should be exactly the same. That shows that the headstock C/L is in line and looking dead straight down the lathe bed.
Yes the numbers you've obtained so far are way more than they should be. Excessivly so, You do need to run the above test and figure out 100% for sure where that misalignment really is. I can't stress this enough. It could even be a combination of a headstock and cross slide alignment.
My apologys for using imperial measurements, but it's what I'm used to and my brain can easily visulise. It's my understanding that higher end precision industrial lathes are always set up with the headstock dead true to the lathes bedways. Depending on the exact description of that lathe as it's being built as just a standard or a higher end toolroom lathe, the cross slide is always purposely ground and scraped on a inward bias. Your parts are or should be always faced concave. I'm only going by what I've read. Standard lathes allow up to .001 concave over a 12" diameter. Toolroom lathes should be around .0005 concave over that 12". I have read a few items that don't conform to those exact standards, so I just can't give you a hard number.
If your headstock does prove to be true? Then the only place it can be out is the cross slide dovetails. Your test numbers so far do show something is way out of alignment. But to be honest, proper dependable test numbers do require the largest diameter you can swing. This isn't the place to cut corners and still obtain the correct test results you want. If it were me? I'd fasten a heavy plate of aluminum to your faceplate and again make that test cut I detailed in my previous post. Idealy you want the largest diameter your lathe can swing and takeing into account the usable low rpm your lathe is capable of.
You did an excellent job of setting your lathe up with a few precautions I neglected to mention trying to shorten things up a bit, so you've obviously got a good idea of what's involved.
With some good accurate test numbers under actual cutting conditions and using the largest diameter material that's practical, you should then be able to set up your parts in a properly trammed mill, and if your cross slide is the part that's defective? You should be able to set it up and remachine it well within what's needed to do the final scrapeing to the alignment specs. you decide on.
I'll be the first one to admit that all of the above is a huge long drawn out PITA, but there really aren't any short cuts. My last two posts are a prime reason why I've always thought you should buy the very best and most accurate and dependable metrology equipment you can afford. I own a variety of Chinese, Taiwan, Austrian and North American built machine tools. None of them are even close to the worlds best. I have had my Austrian built lathe adjusted to turn parrellel to less than .0002 over almost 12". It won't maintain that over even a 5 degree temperature change. But it does show what's possible even with relitively cheap home shop equipment. But if you can't measure it? You can't adjust it.
For sure I'd really like to know what your final results are though.
One more hint? The more you understand about all this, the more diligent you'll be about keeping machine tool slides clean and over lubricated. My slovenly habits really got an abrupt change after reading the Connelly book Machine Tool Reconditioning.
Offline Fergus OMore
« Reply #30 on: August 14, 2012, 08:55:01 AM »
Andy, Before you start on the heroics of taking off metal, why not simplify it by putting some on?
As far as I can see it- and I don't know your lathe or whatever, you can add Turcite or Moglice or perhaps on of the other 'goos' or metal filled plastic fillers. My Myford has a Turcited saddle to fill the damage of centuries- well, years of misuse. There is nothing cheap and nasty about it, it is professionally done.
So using the same idea, you can slightly build up the saddle edges  to remove much of the concavity.
Millions of years ago or a little less, there was an article in ME about building up a vee way lathe bed with shimstock in the worn bit. The grinding was done but only on the newly applied metal shim.
Contray to Pete( sorry old friend) Connolly never had the use of modern plastics. I'm thinking that more available Devcon  might be suitable and I have certainly been surprised with Loctite660.
If all fails, you are no worse off.
Norm
Offline Miner
« Reply #31 on: August 14, 2012, 02:40:06 PM »
As per usual Norman has given a great example of another direction you can go. And he's certainly quite correct about the modern moglice type materials aren't mentioned in that Connelly book since it was written, or at least it's latest up date was in the 1950's. But I don't know of anything that is up to date that covers what that book does.
There was a thread started last year? on either this forum or on the HMEM forum where the poster was doing a full rebuild on a Chinese hobby grade lathe using exactly what Norman has mentioned along with precision scrapeing for correct alignments. . Sorry I don't have a link for that thread. Maybe someone else remembers it? I was more than a little impressed with that posters work and results though.
« Reply #32 on: August 14, 2012, 03:07:49 PM »
Great advice on above two posts but just to confirm milling the slides will work fine when 3 dimensionally clocked up.
At the time i was a non working partner in such a business and gave all the bits to the chief grinder as a foreigner. Had the saddle milled on my ML7 after giving it a little bit for a couple of weeks, the rest was ground first class except the bed.
Have seen Turcite on jobs, usually hinge pins that cant be removed. Cant confirm whether they last after though.
« Reply #33 on: August 14, 2012, 03:34:19 PM »
Whilst still quite poorly( Pneumonia) I can say that I clearly recall a Moglice write up in Model Engineers Workshop. Again, Moglice do seem to have a website but I DO have a favourites entry for Devcon products. Adding a bit to Jonny's remarks, I bought an old Myford Super 7B and paid £250  about 18 months ago for the bed  to be professionally reground and got a build up in Turcite for the underneath of the saddle.
Earlier still, I 'did up' a Super7 and filled the worn number 1 shear with a Loctite metal filler.
Again, I wrote up a doing up of a friends ML7 using a locally available  Lumsden grinder which Blancharded. Somewhere in Model Engineer I think.
Rambling on somewhat, I recall that the late Martin Cleeve added a extra front and rear gib to a ML7 and someone said that Myford had adopted the change from the narrow gib principle.
Certainly, Jack Radford wrote up his modifications to his Super7.
So armed with a decent scraper -ex an old file and a dollop of perhaps Devcon or Loctite it should be possible to make small adjustments- without causing damage.
Enough, I'm repeating myself and need to kill the rest of my 'bugs'.
Enjoy, eh?
Norm
« Reply #34 on: August 16, 2012, 07:19:43 PM »
Thanks, chaps. You have given me a lot of  :scratch: , hence the delay.
As to checking headstock alignment, all I have ever done is to use "Rollie's Dad's Method". Now, I appreciate that RDM can't distinguish between a misaligned headstock and a bed which is warped, but readings and the associated mathematics done at 1" intervals down an 8” test bar showed deviation of zero near the chuck increasing in regular steps to something like 0.0008" at the far end, which I reckoned wasn’t too bad for a Chinese 7x12. It is a somewhat heavier and more robust machine than the usual Seig and Real Bull versions, but even they have a reputation for stiffness having regard to their dimensions (something to do with Young’s Modulus) when compared to “real” lathes, to the extent that they seem to operate satisfactorily sitting on their on their rubber feet.
At any rate, I’m not going to risk doing more harm than good by trying to correct less than a thou over 8”. And chucking up a 3” diameter, 6” long bar as Pete suggests might cause spindle droop on a little lathe like mine; it would weigh around 12lb. But I do have some 2” OD thick walled steel tube so could try it with 4” of that to save weight.
The Moglice (or similar) idea has its attractions. It was shown in Stefan’s thread here http://madmodder.net/index.php/topic,6990.0.html where he was giving a larger version of my lathe a good going over. He didn’t mention using it for the cross slide, but did use it on his topslide dovetail. He used an accurate straightedge with a 60° bevel along it to press against the Moglice while it set, and there could be difficulties setting one of those up on one side of the dovetail so it would tweak the angle round by about 0.18° (about 11 minutes of arc), and then setting up again to get the other side of the dovetail parallel to the first. I’ll think about it, but it might be hard to accomplish.
Milling (followed by scraping) might be easier to set up. A true round bar could be tucked into one side of the dovetail and a parallel placed against the bar. Then, with a DTI held in the spindle and its finger bearing on the outside edge of the parallel, the position of the cross slide on the mill table could be adjusted so the clock showed the required amount of deviation.
Still giving it a lot of thought rather than getting on with the job, and any further input would be welcome.
Offline Miner
« Reply #35 on: August 17, 2012, 09:17:59 AM »
Hi Andy,
You found the exact thread of Stefang's I was thinking of. There's a lot of great tips in that thread. And that pipe you have should work real well for running a proper test. At less than .001 taper in 8", it's looking like you can pinpoint the major problem area as being in the cross slide dovetail. Even remachining it without hand scrapeing would get you a lot closer that it is now.
Once your problem is corrected, you may want to check the tailstock also. My C-6 had the tailstock pointing uphill .009" over 2". It was useless the way it was.
« Reply #36 on: August 17, 2012, 01:24:19 PM »
You keep  :poke: ing me to do more tests, Pete  :)
But at least the tailstock one was easy to do; I've just tried it. Over 2", it points skyward by just under 0.0005", which ain't too bad. Not as good on a horizontal test, though. It is aiming to the left, by a smidgeon over 0.0015". That can probably be dealt with by shifting the top casting slightly relative to the base, though the trick will be to tighten it up so it ends up both parallel to the centre-line and without any offset.
Offline Miner
« Reply #37 on: August 17, 2012, 02:49:56 PM »
LOL, my apology's Andy. But the more I've learned about this, then the less I take for granted. Mistakes in manufacturing, or checks that get missed can and do happen on even the very best and most expensive top quality machine tools. You really do have to run your own full set of Slessinger? (spelling?) tests. Norman of course knows the correct spelling. And as you've already learned, running these tests can tell you things that you'd really rather not know.
One more tip. And I got severly burned on this one. A good DTI doesn't weigh very much at all, and they are about the best way to measure that your tailstock morse taper bore is correct and centered in alignment to the spindle C/L for both vertical and horizontal alignment while being hand rotated from the lathe spindle if you don't have a Burke co-axe indicator. BUT!!! you would be amazed just how much those light weight DTI's can flex even a 3/8" steel rod when their extended out from the headstock spindle. The difference between the top and bottom reading while swinging that DTI around is amazing to see. I fought with my tailstock vertical adjustment for a few hours till I finally realised I was actualy seeing the effects of gravity. Having to read that reversed DTI reading in a mirror in certain positions doesn't help either. You may already know about that, but I figured it was worth mentioning. But that vertical alignment has far less importance than the horizontal one does as long as your tailstock barrel is correct like yours is. Within a very few thou should be ok. Ideally, zero/zero would obviously be the best.
I am more than a bit happy that you started this thread though. Sadly there's far too much misinformation about "proper" machine tool alignment posted on all the hobbiest forums.
There are some real experts who are very knowledable about this that could easily find fault with my rather poor understanding about this subject.
« Reply #38 on: August 17, 2012, 03:24:35 PM »
I didn't start this thead, Pete - unclesteve did, and I seem to have hijacked it. I hope he doesn't mind, but he hasn't posted on it for nearly four months.
Thankls for the tailstock advice; I'll certainly follow it when I get to the tailstock. The measurements I made were on the outside of the tailstock ram, so are no help in establishing whether its internal taper is in line. I haven't got a co-ax indicator, only a normal DTI. I suppose the best way to minimise the effect of gravity would be to put my boring head in the spindle and hold the DTI in it so the size of circle described by its finger can be adjusted. If the taper isn't true, then I'll have to shell out for a Morse taper reamer.
By the time you've finished with me, I'll need to mortgage the house  :lol:
(Why am I laughing?  :( - that's better.)
Offline Miner
« Reply #39 on: August 17, 2012, 07:24:23 PM »
OK then my apology's to Uncle Steve. However it worked out, it was and is a good thread. And I really can't see where anyone would think you've hijacked it.
Nope, forget the MT reamer unless yours is in bad shape as far as being scored, or it was originally machined to a poor holding taper. All it will do is follow pretty well what you already have. And it takes only a very few .001's of MT reaming and you could very easilly get into the range where a standard MT taper might not fit correctly for something like a drill chuck, or the male taper could bottom out inside before it's fully seated. Even with a machine MT reamer, I'd still turn it lightly by finger pressure alone to just clean up any internal burrs on a unhardened MT. You really don't want to do any actual cutting if possible. If you do need to recut that MT taper? A good MT reamer isn't the place to try and pinch pennies. Buy the best you can afford.
They do make MT test bars, but good hardened and ground examples so their accurate to very low tolerances are pretty expensive. I own a couple of them that were built in the U.K. To be honest? They aren't quite as useful as I thought they would be despite the comman perception that they can be used for accurately checking headstock alignments. Standard affordable lathes that most of us can actualy buy usualy have a fairly inaccurate alignment of the internal MT against the O.D. and headstock bearings. And even one speck of airborne dust could be more than enough inside that headstock taper to throw your results out. I've yet to check any headstock taper that was truely concentric with the spindle rotation anyway. Maybe Myford or better lathe owners don't have that problem? With a spotlessly clean and correct taper? They can be useful as a check for just how straight the head or tailstock bores are.
Checking the outer I.D. along with as far as you can get inside with a DTI should give you a good general idea if everyting is straight on the MT headstock & tailstock tapers without a MT test bar though.
You also should run a few general checks with the tailstock barrel extended and retracted along with being locked and unlocked.
This as a hobby for most of us I think, and we are using relitivly cheaper machine tools, So I guess we shouldn't expect perfection. But if you don't test and understand where the inaccuracys are, then there's no hope of compensating for, or with luck correcting them if or when it's needed. And for anyone else reading this? if you've never done machine tool alignment checks like this, You will learn and start to understand a lot.
But it's also these types of alignment checks that have reinforced my thoughts about buying any lathe that doesn't have or come with a test certificate. Without that, it really doesn't matter to a dealer how inaccurate any machine tool is built. My C-6 would instantly break the tips off any center drill I used with the factory machined alignment. My less than poor dealer who is no longer in business wasn't too concerned about that problem.
« Reply #40 on: August 17, 2012, 08:24:51 PM »
Funny you should mention test certs, Pete. My lathe actually came with one. They only measured the exterior of the tailstock quill, rather than its internal taper. In the vertical plane, the results are about the same as those I just made , but they are half a thou better in the horizonal.
Getting back to the main theme, there's no box on the test sheet to be filled in for perpendicularity of cross slide to spindle axis. I think I can guess why!
Offline Miner
« Reply #41 on: August 17, 2012, 08:43:04 PM »
Uhh, Depending on what side of the ownership coin your on, your statement is funny/not so funny, and your obviously correct about your conclusions.
My one and only lathe I've ever bought that did come with a proper test certificate has tested out slightly better than the factory written test results. I'd guess from me takeing much more time and possibly using better test equipment than the factory did. :scratch:
« Reply #42 on: August 29, 2012, 02:44:33 PM »
Just come across the site for turcite
http://www.moglice.com/index.php
So, where do you get it from in small quantities?
What would be the best for a quill.
Offline Miner
« Reply #43 on: August 29, 2012, 04:03:57 PM »
Jonny,
There's a thread running right now on the HSM forum about Turcite and Rulon that you might want to read. Due to Moglice's composition, I'm not sure I'd use it to support a spindle or quill. I know far less about all this than I'd like to, but maybe line boring oversize and at the correct alignments and then sleeveing the oversize bore with bronze or cast iron might be better? I've read of a few people doing this while rebuilding lathes, and they had a good internal combustion engine rebuild shop precision hone the sleeved bore to fit a reground tailstock spindle.
« Reply #44 on: August 30, 2012, 07:11:59 AM »
Thanks Pete, just thought it might get me out of the proverbial but too much hassle, so looks like seeking out a Bridgeport now.
Offline Miner
« Reply #45 on: August 30, 2012, 11:48:22 AM »
Jonny,
Your welcome, but I kind of feel like I've spoiled your day. There's a lot of people far more knowledgeable about this than myself. Maybe start a thread about what your exact problems are? Somebody here just may come up with a simple solution.
Offline bp
« Reply #46 on: August 30, 2012, 09:09:36 PM »
When I had to work for a living, I was involved in changing the focus of a workshop from predominently manual machines to CNC machines.  One of the biggest step changes was when we got three Bridgeport VMC1000s when they were made in Leicester.  They had (I think it was) Turcite on the X and Y axis slides, and the factory was very proud of the 24 hours of hand scraping on each machine.  In their day, the mid nineties, the B'port machines were excellent value and performance.  When I retired in 2008 we still had the three machines and they were going well.
cheers
Bill Pudney
« Reply #47 on: September 24, 2012, 06:19:25 AM »
 Well, I seem to have dealt with my cross-slide, and have got the excessive dishing (0.35mm/0.0053” dip in the middle of an 80mm/3.15” workpiece) down to about 0.02mm/0.001”. As I said earlier, I didn’t want to get too near perfection for fear of going too far and ending up with convex facing cuts.
The job was done on my old Dore Westbury miller with a 60° dovetail cutter. Setting the saddle up wasn’t easy. The lathe is Chinese, so nothing is particularly parallel or square to anything else, and the only available datum faces were the two horizontal sliding surfaces on the top. I bought a couple of cheap Ebay feeler gauges to provide me with a variety of shims so I could get those sliding surfaces true. Here it is, with clamps everywhere I could fit one, including some  hemming it in, because the “shims” were shiny and slippery, and it would have been a disaster if the job shifted.
http://i689.photobucket.com/albums/vv257/andyf1108/Saddleonmill_zpsc581d730.jpglathe cross slide 'dishing'
Other problems encountered were:
1. Tramming the miller, which had to be done with the head at what would be working height (fairly low in this instance) in case its round column is not dead staight. In that case, altering its height after tramming would throw things out again. I adopted this rather nice technique http://rick.sparber.org/TM.pdf .
2. The gib had conical dimples, no doubt made with a drill bit. The ends of the M4 adjusting screws weren't pointed or turned down in any way. As the dimples only roughly coincided with the screws, the gib had been twisting slightly as I tried to adjust it in the past. No wonder adjustment was always a compromise between no tight spots on the one hand and no free play on the other. To cure this, I flat-bottomed the dimples with a 4mm slot drill, faced the ends of the screws and turned the threads off their ends (happily, I have an old Perris baby lathe to use while the Chinese one was dismantled).
3. There are no saddle gibs bearing on the underside of the bed on my lathe. The side plates (those which normally carry the gib plate adjusting screws on Chinese saddles) were a close fit to the bed, so there was no discernible rock. In any case, unless I was turning something so large that the tool was no longer over the bed, or was using a back tool post, cutting forces would push the saddle down on to the bed, so the side plates would have nothing to do. But for some reason, after reassembly, the front plate was too tight on the bed, so I had to interpose  about a thou of kitchen foil shim between it and the saddle. The rear plate was too loose, so about 2 thou had to be removed by draw filing. The result was pretty good; no discernible rock, and the saddle can be lugged along the bed quite easily, without resorting to the apron handwheel.
All in all, I’m happy with the result. The dishing has been reduced to what for me are acceptable limits, the carriage is nicely fitted to the bed, and the cross-slide gib problem has been eliminated.
My thanks to all who took an interest, particularly Pete (Miner); I hope his recovery continues. Likewise, I trust that Norm (Fergus) is over his pneumonia.
Offline Miner
« Reply #48 on: September 24, 2012, 11:07:29 AM »
Hi Andy,
 :beer: You did a hell of a good job in my opinion. That's a huge improvment over what you started with.  You might want to recheck your lathe after it's done some work just to give you a general idea of the direction it's starting to wear in. (convex, concave) Due to the minor tool marks, you might see a quite high wear rate to begin with till the slides wear in a bit, and then the the actual wear rate will slow down to normal. It's the tool marks and direction they run why shapers are the preferred machine tool for non ground or hand scraped dovetails.
LOL, I'll bet you learned and now understand a lot more than you did before starting that job. There's a LOT more to proper machine tool alignment than most would think. But it's also not a job that should be rushed, and you have to be 100% certain of your test results and where the problem really is.
The last I heard Norm is doing much better, but it might be a couple of weeks before he checks back here. I'm doing........ok. Too many pills for breakfast though. :(
« Reply #49 on: September 24, 2012, 12:47:28 PM »
.... LOL, I'll bet you learned and now understand a lot more than you did before starting that job. There's a LOT more to proper machine tool alignment than most would think. But it's also not a job that should be rushed, and you have to be 100% certain of your test results and where the problem really is.
Damn right I didn't rush it, Pete, though I wasn't exactly putting in 8-hour days and did take 10 days off in France at the beginning of this month. I'm just a hamfisted amateur tinkerer, not a machinist. "Measure twice, cut once" - I must have checked about 8 times before each cut.
One question: the operation involved shaving a bit off each side of the saddle dovetail, so there's now about 1/12" daylight behind the gib strip. Does this matter, or should I be thinking about a new, thicker gib? To may way of thinking, the only time it might really matter is when taking cuts away from the headstck, when the pressure will be taken by three out of the four gib screws, which are only M4 and will be in clear air for over 1/12", including the end which passes into the modified dimples.
« Last Edit: September 25, 2012, 05:44:39 AM by andyf »
