Author Topic: Sieg Super C3 bearing change  (Read 52566 times)
Re: Sieg Super C3 bearing change
« Reply #25 on: July 17, 2016, 03:49:08 PM »
Marco,
You would be better removing the bearing you have already installed on the spindle.....
Once removed, lightly polish the shaft journals so that the inner races are a tight-ish push fit...just make sure that when you polish them, they remain round not oval.... :dremel:
If you cannot remove the front bearing, make sure the rear bearing will move on the spindle journal, otherwise you wont be able to set the preload....
