Author Topic: C Spanner (Case Hardening)  (Read 16698 times)
« on: January 18, 2009, 08:46:27 AM »
Hi Chaps
I was going to put this as part of my Loco build, but thought it made a nice mini project and bring in the topic of case hardening.
C Spanner
The gland bolts on the steam chest of my Loco build, when assembled won’t be very accessible, they have two cross screwdriver slots with the slide valve rod running through the middle. Adjusting them without damaging the screw will be difficult and replacing them will be a complete strip down job, what’s needed is a bespoke C spanner.
I’ve made the spanner from some ¼” mild steel plate, that I’ve case hardened.
Mild steel has a low carbon content and can’t be harden, but if you soak the material at temperature in a carbon rich environment the surface of the material takes up the carbon allowing the surface to be hardened:- this is case hardening. In the good old days this process was used a lot particularly in thing like shafts where you could have a hard wear resistant surface but with a tough core.
What you need:-
1:- Gas burner.
2:- A hearth.
3:- Case hardening powder, I got mine from www.chronos.ltd.com in the UK.
4:- Quenching water or oil.
Method:-
1:- Machine the spanner to the finished shape.
2:- Bring it to a nice bright cherry red on the hearth. Tip:- try to do this in natural light to get the true color.
3:- Bury it in the hardening powder and leave it there to cool.
4:- Remove it from the powder, leaving all the crusty powder on it, and bring it to cherry red again and hold it at this temp to burn the powder in a bit more.
5:- Quench in the water.
6:- Clean and polish
Job Done  :thumbup:
Quick check with a file and you’ll find it skids over the surface
This is the way I do it some of you Chaps may have better ways but this works fine for me. :headbang:
One final thing don't set fire to your shop   :hammer: :zap:
Have
fun
Re: C Spanner (Case Hardening)
« Reply #1 on: January 18, 2009, 11:54:01 AM »
Nice write up Stew, spot on process.
I would just like to add a comment because of a safety issue with case hardening powder.
Case hardening powder, if stored in nice dry conditions can last for many many years.
'Kasenit' or 'Casenit' is a trade name that is used in the UK, and has been called that for as long as I can remember.
So any of you older ones, or ones of you who have inhertited some case hardening powder from long ago, no matter what the name, should dispose of it straight away, do not even open the tin.
Early versions of case hardening powders contained fairly high quantities of cyanide, and we all know what that does. The later versions that have been available for the last few years are safe, as long as you follow the safety guide that comes with the product.
I have no idea how long ago the formula changed, but to be on the safe side, I personally would dispose of any you even suspect of being rather old or from unknown sources.
Then go out and buy some of the modern formula.
Sermon over.
« Reply #2 on: January 18, 2009, 02:36:53 PM »
Hi John
Thanks for the safety reminder, I'd forgotten  :scratch: that cyanide was used a few years ago, the stuff I use is only a couple of years old so will be OK.
« Last Edit: January 18, 2009, 02:57:06 PM by sbwhart »
Offline SPiN Racing
« Reply #3 on: January 18, 2009, 04:44:24 PM »
Very very cool :)
I was wondering how to harden things.
SOme of the internal parts on the Mazda, need to be hardend for the higher RPM race engines.. like the gears the rotors rotate on.
Very cool stuff.
SPiN Racing
« Reply #4 on: January 18, 2009, 05:31:48 PM »
Thats pretty neat. I have always wondered about the process.
« Reply #5 on: October 28, 2009, 03:45:19 PM »
Bringing this from the dead ....
Once case hardened, can it be tempered so that it is not so brittle or is this not necessary since only the surface is hardened?
« Reply #6 on: October 28, 2009, 03:55:34 PM »
No you don't normaly aneal a case hardend surface, when you case harden you only get a hard surface skin  fraction of a mm thick.
Case hardening is normaly done to improve the wearing properties and toughness of an item, its not used for cutting tools.
Hope this helps
« Reply #7 on: October 28, 2009, 04:45:57 PM »
... its not used for cutting tools.
Who mentioned anything about cutting tools  :lol: :lol: :lol:   OK OK, I`m going to have to make the damn cutter again as this ain`t no damn silver steel!!!
« Reply #8 on: October 28, 2009, 05:33:48 PM »
I wondered why the sandwiches tasted funny after case hardening something  :coffee:
John S.
Offline 75Plus
« Reply #9 on: October 28, 2009, 05:42:23 PM »
I have used Kasenit since 1962. It was safe for home use at least that far back. Only disappointment was that it will NOT do the nice colors as is found on some of the better shotguns.
Joe
« Reply #10 on: October 28, 2009, 08:43:27 PM »
Joe
Isn't that called "bluing" and is done with some kind of salts or oils? A kit for bluing, both hot and cold, can be bought from Brownells.
Offline 75Plus
« Reply #11 on: October 28, 2009, 09:33:56 PM »
I am not referring to bluing Bernd, take a look at this site for an excellent example of color case on a double bbl. shotgun.
http://www.danthegunman.com/index.php?option=com_content&task=view&id=16&Itemid=25
Joe
Joe
« Last Edit: October 29, 2009, 07:38:42 PM by CrewCab »
« Reply #12 on: October 29, 2009, 09:14:39 AM »
Joe,
Thanks for showing that. I'd forgotten about the bone and wood charcoal. Those are nice colors. I bet it takes a bit of practice to get that kind of beauty out of metal.
« Reply #13 on: October 29, 2009, 10:53:04 AM »
Stew, might need to borrow that soon  :lol:
 :offtopic: How tight do you go with those nuts? Do you have graphited yarn behind them or 'o' rings?
« Reply #14 on: October 29, 2009, 11:09:56 AM »
High Nick
I used graphite yarn you don't have to go too tight just so you feal a little resistance.
