Author Topic: ogan Lathe motor issues-need help  (Read 7339 times)
Offline DrPatron
« on: November 05, 2011, 11:38:23 PM »
I think the motor on my Logan Lathe (11"x36") is dying, lacks,  power and is heating up.  It's kind of like me -old and tired I need to find a repacement. The original is a 1/2 horsepower.  Don't what kind to buy, needs to be reversable and don't know how to wire it that way.  Any help appreciated
Re: ogan Lathe motor issues-need help
« Reply #1 on: November 06, 2011, 08:07:36 AM »
Hi DrParton,
I have a Logan lathe. I needed to gear a gear for at one time and contacted Scott Logan at Logan Actuator Co. They are still in buisness.
Contact Scott at sales@lathe.com  Their web site is www.lathe.com
It's a place to start anyway. Scott's very helpful and freindly. Hope this helped.
Offline hopefuldave
« Reply #2 on: November 06, 2011, 08:08:34 PM »
Hi Dr,
If this is Some Years Old and single-phase (i.e 110 / 220 volt), it might be worth swapping the motor capacitor/s before shelling out on a new motor - getting hot, lacking torque, poor starting too?
The cap/s will be tin can shaped, probably under a cover or clamped on the outside of the motor, should be marked with the capacitance and voltage. Your nearest motor shop is likely to stock them for a few Local Currency Units each.
Also, making an assumption, it may have a centrifugal switch for the start capacitor and it may be stuck - you should hear a clunk as it slows after switchoff if it has one, they soimetimes stick for no readily apparent reason!
Just my ha'pennorth,
Dave H.
Offline DrPatron
« Reply #3 on: November 06, 2011, 10:44:24 PM »
thanks for the help Guys. I'll post what I find out-Drp
