Author Topic: crayford type focuser for telescope  (Read 12237 times)
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
« on: October 17, 2011, 08:20:32 PM »
My son has an 8" telescope and wants me to make one of these focusing devices - ideas shown here:
http://www.atmsite.org/contrib/Sapp/Focuser/CrayFocus.htm
One thing that isn't shown is the mating faces between the telescope and focuser. Clearly the focuser needs to have a curve machined into it at a 4" radius. Now, getting the workpiece 4" away from the spindle center isn't a problem, BUT, I am looking for advice on the best way to machine the curve.
I wondered if it would be possible using a boring head, but am concerned about flexing at that radius. If a boring head is viable, what size would be recommended, bearing in mind tooling cost is limited.
Thanks for any help.
Ian
If it works, take it apart and find out why!
Re: crayford type focuser for telescope
« Reply #1 on: October 18, 2011, 04:36:58 PM »
If you can put up with an ellipse rather than a perfect radius, you should be able to use smaller radius tool (boring bar/fly cutter) at an angle to the work piece. (e.g at 90' the cutter will be flat , at 0' it will cut it's own radius but in between it will cut an ellipse with a major 'radius' close to your 4")
http://www.practicalmachinist.com/vb/general/milling-radius-tilting-mill-229362/
« Last Edit: October 19, 2011, 09:16:41 AM by BillTodd »
Offline dickda1
« Reply #2 on: October 18, 2011, 10:40:43 PM »
Being an old (quite old) telescope maker, I have always wondered about cutting threads for a focuser.  Always heard that a rolled or ground thread was the only one that would be smooth enough to avoid excessive wear.  Please post your experience with the new focuser - I am interested.
-Dick
Skype: VladTheChemist
Offline kvom
« Reply #3 on: October 19, 2011, 08:22:46 AM »
A flycutter could also machine the radius as could an endmill with the part mounted on a rotab.
Offline johnf345
« Reply #4 on: October 20, 2011, 03:57:19 PM »
There are two ways of doing this.
Firstly the workpiece is mounted in a vice mount on an angle plate mounted on a rotary table.
The distance from the center of the table to the paart is the radius of the cut.
It is possible to use an endmill in the vertical head if the length of the cut is short.
Better than this is to tilt the head and use a ball ended endmill.
The alternative method is to mount the workpiece in the vice mounted on an angle plate.
The cutting is done with asuitable cutter in a boring head.
Set the diameter of the boring head to the final diameter required.
This can be done by fitting two fences the required distance apart on the milling table and then moving the table
or the adjustment on the boring head till it fits between the two fences.
This sort of part has be made accurately if its going to look the part.
Offline Old Bill
  • Aggressively passive
« Reply #5 on: November 02, 2011, 01:08:06 PM »
I agree that machining the curve would be the cleaner, more professional way to do this, but if you need a simple solution, you could mount two lengths of round stock on the edges of the base that are parallel to the centerline of the tube. You would have to be sure to mount these equidistant from centerline of the focuser tube to prevent canting off center. With some figuring, the base will just touch at the apex of the circle while the round stock provides the 'feet' for mounting. A bit of foam rubber could be used to 'seal' light and dust from coming in from the bottom of the base.
Old Bill  (For the record, I'm not Bill. Heck, I'm not even old. I'm just some guy using his name....)
