Author Topic: Chester 626 mill CNC Conversion  (Read 667514 times)
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
Re: Chester 626 mill CNC Conversion
« Reply #375 on: July 31, 2012, 04:23:14 PM »
nither am I the bumpy bits in the main hole are the result of lengthening the large hole to make a BIG slot to allow movement two big holes with centre offset by say 10mm
Yes, but he SHOULD have milled them away so the edge of the slot was the usual baby-soft chrome-plated wonderfinish...
Bingo!  That's why I think he farmed this piece out to the local chop shop.  You know... The place next
to the little greasy taco shop down the road.  ; )
Dean W.
Shop Projects:
« Reply #376 on: July 31, 2012, 04:47:53 PM »
 :lol: :lol: :lol: :lol: :lol: You lads crack me up  :lol: :lol: :lol: :lol: piss taking TWATS  :lol: :lol: :lol:
JS and his Voodoo knocked out my home BB Sunday ,,,,,,,,back up now  :ddb: :ddb: :ddb:
A few strokes of the file sorted out the BUMP  :)
Y axis mount just about done .
need to re drill the fixing holes in the motor , should be 6mm , but are actually 5.5mm  :palm:
Women's beach volley ball ,, were ,when  :drool:
« Reply #377 on: July 31, 2012, 05:02:20 PM »
Looking real class Rob  :thumbup: :thumbup: :thumbup:
Have you tickled them with the surface grinder  :drool: :drool: :drool: :drool:
« Reply #378 on: July 31, 2012, 05:14:31 PM »
oooooo nice
Offline Dean W
« Reply #379 on: July 31, 2012, 05:21:42 PM »
Now, that's much mo betta, Rob!
Dean W.
Shop Projects:
lordedmond
« Reply #380 on: August 01, 2012, 02:41:56 AM »
 I liked the bumpy bits , it proved that Rob was a mortal being like the rest of us, :D
Stuart
« Reply #381 on: August 05, 2012, 10:46:39 AM »
a WEE bit more done , X motor mount finished and finished up all the work too the table ends , had to re work the RH table end as the motor was original going to go on the LH end of the table straight out ,cant mount motor underneath table on the left as it would twat Z motor ,  RH table end had only machined for one bearing to carry the end of the screw .
Better make a start on the Z motor mount  :dremel:
Anyone no how to change the position of the "Home position" on the Mach3 screen  as is it is bottom left , i would like it top right ?
Cheers Rob
« Reply #382 on: August 05, 2012, 12:45:18 PM »
Turn the freeking screen round.
« Reply #383 on: August 05, 2012, 03:04:27 PM »
  Looking good Rob :thumbup: :thumbup: , its going to like very neat once its done, much better than the motor sticking out option you mentioned.  :clap: :clap:
  Cheers Mick.
« Reply #384 on: August 05, 2012, 03:35:42 PM »
Rob, what sort of capacity do you expect the machine to have in terms of cutter size and DOC on various materials? Looks like some hefty motors being used there.
« Reply #385 on: August 05, 2012, 03:50:46 PM »
That is looking really neat and compact  :thumbup:  :thumbup:
I dont think you will have any problems with the mountings flexing  :lol: :lol: :lol: :lol:
At this rate you should have it finished to do the valve cover on my mill engine :drool: :drool: :drool:
« Reply #386 on: August 05, 2012, 04:03:04 PM »
Cheers Lads  :beer:
Never gave it much thought Pete , but i bet it will snap cutter easy with me at the helm  :lol: :lol: :lol:  ,, the limiting factor will be the HP at the spindle .
Second job mate  :lol: :lol: :lol:
« Reply #387 on: August 05, 2012, 05:19:04 PM »
Rob,
Very nice  :thumbup: :clap:
Offline Mayhem
  • purveyor of mischief
« Reply #388 on: August 11, 2012, 08:19:51 AM »
Hey Rob - looking really good (as usual).
Offline sdezego
« Reply #389 on: August 11, 2012, 01:06:03 PM »
Unreal workmanship in here.  I just love seeing your work  :beer:
Offline 9fingers
    • Info on Induction motors (Heavily UK based!)
« Reply #390 on: August 11, 2012, 03:37:42 PM »
Rob, Isn't your X axis motor seriously limiting the X travel on your set up??
I've just been measuring my 6 x26 and at the left most table position, the right hand end of the table casting, is level (within a knat's cock) with the right hand side of the knee casting.
It looks to me that your X motor will hit the knee about 60mm before that point?? :bang:
This is my machine at extreme left travel
http://i115.photobucket.com/albums/n313/9fingersphotos/VMC%20Modifications/xtravel1.jpgChester 626 mill CNC Conversion
and the DRO showing the max travel
http://i115.photobucket.com/albums/n313/9fingersphotos/VMC%20Modifications/IMG_1898.jpgChester 626 mill CNC Conversion
sorry about the poor photos
Bob
« Reply #391 on: August 11, 2012, 04:32:12 PM »
Cheers Lads  :beer:
Hi  Bob ,in a word Nope as is I have 420mm  :)
If i had mounted the motor direct I would of had another 65mm of travel
Offline 9fingers
« Reply #392 on: August 11, 2012, 04:44:28 PM »
Ok I think I've solved it. My table casting is only 610 long so more like a 6 x 24 :bang:
My 426 mm travel is however at the expense of part of the dovetail not being engaged but I hope that will not be a problem.
Bob
« Reply #393 on: August 11, 2012, 04:51:07 PM »
Hi Bob , cant see it being a problem  :thumbup:
Got to ask are you planing on making 16" long parts (allowing for tool width )  cant see me needing something that long ,and if i did I would probably get/make a bigger mill   :dremel:
Offline 9fingers
« Reply #394 on: August 11, 2012, 04:59:27 PM »
I used to work on panels for electronic equipment in 19" racks.
I always had to re jig to do the 'other end'. A right PITA
I quite often have a vice on one end of the table and use the other half for mounting stuff direct onto the table.
I can always cope with some extra length :lol:
Bob
« Reply #395 on: August 11, 2012, 05:00:41 PM »
Bob
 :lol: :lol: :lol: :lol: me too  :Doh:
« Reply #396 on: August 11, 2012, 05:16:48 PM »
Bob
Bob , you need to squeeze a Brideport into that garage of yours <G>
AWEM
Offline 9fingers
« Reply #397 on: August 11, 2012, 05:23:47 PM »
Fancy meeting you in here!
I've not seen the floor in that garage for years Andrew! :lol: :lol:
Bob
« Reply #398 on: August 11, 2012, 05:52:31 PM »
Not allot of actual work on the mill done this week , but  i did crack out the  etch a sketch  and doodle up a drawing for the Z motor mount .
Suppose i better get up early the morn and zap some plate together before i get dragged to the beach for the day  :palm:
« Reply #399 on: August 11, 2012, 07:02:28 PM »
Beach ??
Beach in fooking Yorkshire ?  Give over, next thing you will tell us you have indoor privy's
