Author Topic: Chester 626 mill CNC Conversion  (Read 681666 times)
Re: Chester 626 mill CNC Conversion
« Reply #300 on: July 05, 2012, 01:08:20 PM »
Tare-arsing is another one.......
 :lol: :lol: :lol: forgot about that one David  :headbang: :headbang:
Hi Nick ,,,,,,,,,,,,, thought you may have finished that loco  :poke: :)
Hi Rob,
Do you mind me asking where you manage to acquire such large lumps of steel from?
I feel like I'm forever finding ways of building big parts by bolting little ones together, due to a shortage of large stock.
I rummage around the local scrapyard and the offcuts sections of some of the metal suppliers, but rarely find any solid steel above 50-60mm dia either as square or round.
Cheers,
Rich
Hi Rich ,,,,,,,,,,,, All my stock is scrounged ,i am luck in that my job gets me into a few places were getting hold of 8"x12"x24" lump of scrap steel is not a problem ask John DB LOL , I also do work for a metal supplier on the valley so i get to raid ,or a better word would be rape there scrap skips LOL .
Working with forklift trucks means i have access to any amount of say 50mmx100mm by about 400mm long , I cut the back section of the fork out, between the hanger .
ending up with a very usable lump of tough steel . :)
  I also when i can be arsed strip the rods from hydraulic cylinders , maybe its just me but when i look at something i think what usable material is there for me hidden within   .
just noticed your just down the road from me ,,,,,, Have you tried Grievsons scrap yard on Station  road   walker ?
« Reply #301 on: July 05, 2012, 02:37:13 PM »
Oy! How do you process hydraulic cylinder rods? They are hard chromed? Turn under it and use juicy steel under? What kind of material it is?
« Reply #302 on: July 05, 2012, 02:54:16 PM »
Hi Pekka
Yes its hard chrome same gear as ballscrews etc ,,, just turn under the chrome ,, no idea what grade of steel ,,, turns fine  :thumbup:
The cylinder tubes come in handy too  :med:
« Reply #303 on: July 05, 2012, 03:40:23 PM »
Hydraulic cylinder rods are induction hardened so only the skin is hard - once you're through that it's esy eough to turn. Only trouble you'll get is if there are any drillings in it coz you'll the interrupted cut in the hard skin will break your inserts.
« Reply #304 on: July 05, 2012, 03:57:53 PM »
A bit more done tonight ,,,,,,,,,,,,,did naff all last night  :palm:
Finished the turning on the block .
The spigot is a nice snug fit in the knee .
Still a bit to do  :dremel:
Pondering which way to mount the motor .
The lazy way ,straight out using a coupling .
Or stick it under the knee ,belt and pulleys  ,,,,,,,,,more machining.
« Reply #305 on: July 05, 2012, 04:04:14 PM »
You know yourself how it should be mounted :Doh: :Doh:
Offline loply
« Reply #306 on: July 05, 2012, 06:50:25 PM »
Hi Rob,
I know Grivesons but never been in. Might have to pop in one day.
Funny you should mention forklifts, I work just opposite Permat in Camperdown, I might have a word with the lads there about any surplus forks! They seem to deal with some huge machines, saw one the other day which looked like it could lift a house.
I think I just need to "up my game" on scrap metal collection  :clap:
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #307 on: July 06, 2012, 12:31:02 AM »
Another beautifully done piece, Rob.  Someday afar off, some guy will be looking at this mill and think to himself;
"Wow, a real machinist has had his way with this thing".
Dean W.
Shop Projects:
« Reply #308 on: July 06, 2012, 05:11:00 PM »
Nah - they'll say 'they don't make Chinese stuff now like they used to' :D
Offline Dean W
« Reply #309 on: July 06, 2012, 09:33:40 PM »
Well, they never have.   ; )
Dean W.
Shop Projects:
« Reply #310 on: July 07, 2012, 01:00:46 PM »
Cheers Lads  :beer:
Dean ,,, our they may say what the F%$k was he thinking  :loco: :lol: :lol: :lol: :lol:
Well finished the machine work to the Y axis block , well all bar a few holes for the motor mounts .
I slapped the knee back onto the mill and there is enough room or the Y axis motor to fit underneath , so i may as well mount the X axis motor  under the table , i will loose a tad, 30mm of travel , but the machine will have a much smaller foot print and it gets rid of those couplings Mr JS said were ****  LOL  . So i have a weee bit more machining to do  :headbang:
« Reply #311 on: July 07, 2012, 01:40:09 PM »
I wish my parts came out that nice...  :drool:
I swear, you must have machinist elves living under your workbench. Nice work my friend.  :bow:
« Reply #312 on: July 07, 2012, 04:10:56 PM »
I don't mind the perfect surface finish - I'm guessing most of this is done on the shaper, and I believe shapers give fabulous finishes. So I can cope with that.
What I can't get my head around is those radiused corners. They are perfect. Perfect. Every single one of them. Smooth, shiny, consistent and not a hint of a ridge* where the cutter was 0.0001" out of position either on the X or Z axis. Rob how the f****k are you doing that?!?
I am not worthy:
So, I tried to get a finish even close to resembling yours. And my lathe spat its chuck at me. I can't say I blame it...
* There's only one thing I can produce which is smooth, shiny, consistent and without ridges. And it sure ain't metal.  :doh:
« Reply #313 on: July 07, 2012, 04:36:56 PM »
Close Eric ,,,,,,,, i have a midget helper that dose al the work   :lol:
Thanks Ade  ,,,,,,,, I used the HZ mill to do the radius ,then a few licks with a file , very fine file, two of the rads were completely filed ,the two that run up to the bolt flange ,using a rad gauge  to check   :dremel:
PS no shaper work on this part  :palm:
« Reply #314 on: July 07, 2012, 04:59:14 PM »
It is all true Ade
I have seen him file a radius before :clap: :clap: :thumbup: :bow: :bow:
That is a great photograph rob :D :D
I have a couple of little helpers as well :Doh: :Doh:
« Reply #315 on: July 07, 2012, 07:27:20 PM »
well dun rob keep it up
« Reply #316 on: July 08, 2012, 01:22:41 AM »
Is that a steel boiler I spot on the floor behind you're little helper ?
« Reply #317 on: July 08, 2012, 02:47:29 AM »
Thanks John n Bob  :beer:
Hi Stew , it is a boiler for a 4" Tasker tractor ,something i started way back before the boiler regs changed , meaning now you have to be  a coded welded  :palm:  , all the plate , tube ,welding rods  are boiler spec (with paper work), just not me LOL .Actually over spec i used 5/16 pate and tube instead of 1/4 .
So it just sits there getting in the way , the drawings for the engine are very poor too, lots  of mistakes  :(
« Reply #318 on: July 08, 2012, 04:43:09 AM »
That looks a very nicely built boiler Rob Pity about the change of regs, rendering it US, don't supose ther's a way round it.
You can use it as a door stop or a paper weight  :lol: :lol: :lol: :lol:
Drawing errors is something of a perenial headache, with models, just got to read ME to see that, but I look at it this way sorting out the errors is just part of the game that makes the hobby interesting, my experience from industry is that drawing errors are not unusual:- come across some howlers in my time.
« Reply #319 on: July 08, 2012, 05:04:21 AM »
It is still use able , for my own use , just could not sell it , or i could get coded ,all welds have been crack tested ,all passed , the thing is i weld jobs at work that operate at a much higher pressure 3000psi  :bang:  , I may turn it into a Portable engine .
There are drawing mistakes and mistakes , when i complained about the drawings , i got a letter back from the lad who did the drawings saying they were fine , then a week latter Camden books sent me an error list 1 and 1/2 sides of A4  ,so the drawings are good REALLY !  , so now that i have CAD i may re-draw it and do a copper boiler .
Meccano ,, actually put mistakes in there build  instructions to get you to think  :med:
Offline Jasonb
« Reply #320 on: July 08, 2012, 09:39:03 AM »
Rob, you don't have to be coded, just submit some test welds to an independant boiler inspector (not a club inspector) and they will test and I'm sure yours will pass then you will have a legal boiler. It will cost a bit but not as much as buying a ready made boiler.
Was chatting to someone yesterday at tehe Guildford show and a new copper boiler for my 2" Fowler is £2200 thats a 50% increase since I bought mine.
J
« Reply #321 on: July 08, 2012, 09:55:09 AM »
Hi Jason
Now that has brightened my day up , i will look into that cheers  :ddb: :ddb: :ddb: :beer: i thought i was doomed .
"2" Fowler is £2200"  wow ,but  still worth it , when you  take into consideration the time and materials , the price of copper has rocketed and the  Silver solder bill for a boiler that size would be a few quid , also  not everyone has the equipment to heat such large lumps of copper . No rust to deal with .
Thanks Rob ,,,,,,,,BIG smiles
Offline David Jupp
  • Teesside - UK
« Reply #322 on: July 08, 2012, 12:40:23 PM »
Retrospective approval is likely to be tricky.  It only shows what your welds are like now - not necessarily what they were like when the boiler was welded.  Test pieces are typically done before commencing manufacture - the approval of a welder will only be valid for a period of time for the particular weld procedure used.
If you do find a way forward, I'm sure others would be interested.
« Reply #323 on: July 08, 2012, 12:59:09 PM »
I'm sure Rob wouldn't do this, but a less scrupulous person might be a bit economical with the truth over the fact that the boiler existed before the test weld was submitted, and delete any evidence that it had been made at an earlier date from internet forums (e.g. Madmodder) just in case either inspector happened to read them.
« Reply #324 on: July 08, 2012, 01:35:47 PM »
Good point David , these rules an regs are enough to make you go mad , one year its OK to weld the job up yourself  the next its not , same boiler in copper no such regs , anyone without any previous silver soldering experience/training  can solder up the boiler , if it passed the hydro test its good to go .
Hi Andy , yes there are a few unethical ways i could get round the problem , but i will not be going down that route I will play by the rules ,however maddening they are.
Rob ,,,,,not smiling LOL
