Author Topic: Chester 626 mill CNC Conversion  (Read 681659 times)
Offline Jasonb
Re: Chester 626 mill CNC Conversion
« Reply #200 on: January 21, 2012, 03:23:03 PM »
Wot no paint!
Enjoying the mini series as much as the main feature.
J
Offline John Swift
« Reply #201 on: January 21, 2012, 03:43:54 PM »
Hi Rob ,
it looks  too good to hide under a coat of  paint     :ddb:
what speed did you face the underside of the plate with it being unbalanced ?
PS     can't wait for the next instalment of the cnc mill
« Reply #202 on: January 21, 2012, 03:54:01 PM »
 :lol: :lol: No paint Jason  :Doh:
Hi John ,,,,,,,,, so thats what i was doing  :lol: :lol: :lol: :lol: :lol:
I think i will leave the angle plate's  O natural  :med: i quite like the look of em .
The lathe was set to 190 rpm's  any faster and it started to move across the shop  :palm:
« Reply #203 on: January 21, 2012, 04:04:54 PM »
Rob,
How did you fashion the clamp plate from such heavy flat bar? :scratch:
You're obviously a 'Madmodder' of great talent.. :D
ps thnx for the invite :thumbup:
« Reply #204 on: January 21, 2012, 04:22:35 PM »
Hi John
Rob,
Geordie no how ,,,,,,,,,,,,,,,,,,,,, I cheated and welded it up ,,,, its made from four bits stuck together  :lol: :lol:
« Reply #205 on: January 21, 2012, 06:00:53 PM »
HI nothing wrong with them rob I will place my order gnaw  can I have 10 please      :) :) :) :)
Offline arnoldb
  • Windhoek, Namibia
« Reply #206 on: January 22, 2012, 02:07:03 PM »
 :bow: :bow: Great looking Keats plate mate  :thumbup:
Suppose i better get on with what i was originally doing in this thread ,,,,,,, if i can remember what that was  :scratch:
:lol:  let's see now could it be the r....e......, k..... h.. & m..., ... ... ...  - No; hang on...   :poke: It was putting J.S. to sleep...  I better shut my trap  :lol:
 :beer:, Arnold
« Reply #207 on: January 22, 2012, 04:04:56 PM »
 :beer:, Arnold
 :lol: :lol: :lol: i shut your trap  :hammer: :lol: :lol:
Getting distracted again mate  :palm:,,, wile looking at the Keats and thinking what a pain it can be to set things up vertical both ways on the mill to do work on the end of long parts i doodled this up    :Doh:
Probably all been done before ,, cos there is nowt new in this game  :dremel:
« Reply #208 on: January 22, 2012, 05:56:30 PM »
I'm fairly sure you were making some scrap metal so the rest of us would feel a little less inferior?  :lol:
Seriously - blummin good work as usual Rob, that keats thingy looks fabulous.
« Reply #209 on: January 22, 2012, 05:58:49 PM »
Rob,
Just to comment on the Keats.
Looks terrific, nicely made, and well finished. :thumbup: :thumbup: :thumbup: :clap: :clap: :clap:
Good post.
Offline Jasonb
« Reply #210 on: January 23, 2012, 02:35:39 AM »
Rob rather than that mill contraption can't you just bolt your new Keats plate to the mill table to do the same job?
J
Offline SemiSkilled
« Reply #211 on: January 23, 2012, 02:43:45 AM »
Rob, your drawing looks a bit like a Rike vice I think its called.
http://littlemachineshop.com/products/product_view.php?ProductID=2304
Nowt new like you said  :beer:
Lee
Offline Davo J
« Reply #212 on: January 23, 2012, 02:54:46 AM »
Hi Rob, :wave:
What happened to the CNC mill, just kidding it has been an interesting read. :beer:
 :proj: :mmr: :headbang: :headbang:
You do a great job of taking photos all the way through. I do some photos and know how easy it is to forget and how much extra time it takes , so thanks as it makes it a good read.
I also do the weld and machine type of of jobs because getting casting done over here is near impossible.
Keep up the great threads
« Reply #213 on: January 23, 2012, 12:02:55 PM »
Thanks Ade and Dave  :beer:
J
The Keats would be OK for shorter lengths ,,,, as i said Longer lengths of stock/jobs   For example this operation on the clamp bar .
The Keats would be no good whats so ever .
Yes i could faff about and packing it  up ,, also the Keats has a large foot print so it could not be used so well on the surface grinder .
As i have at a rough guess a Ton ++ of steel  :)  i may as well use a bit up and build one  :dremel:
Lee
Hi Lee ,,,,,,,,,,,,,Looks very much the same ,,, slightly different clamp  :med:
Hi Rob, :wave:
Thanks Dave
Pleased you liked the photos  :thumbup: you should take your camera in the shop more often  :poke:   Have you ever thought about setting up  your own foundry ? ,,,, I probably would have cast these if i had got my butt in gear and sorted the furnace  :Doh:  :proj:
Cheers Lads Rob
Edit :   Thinking allowed again  :palm:  ,,, maybe a smaller version that would fit the mill vice may come in handy .
« Last Edit: January 23, 2012, 12:33:45 PM by Rob.Wilson »
« Reply #214 on: June 05, 2012, 10:57:55 AM »
Warning: this topic has not been posted in for at least 120 days.
Unless you're sure you want to reply, please consider starting a new topic.
   :Doh: its been that long  :lol:
Picked  up a couple of 8mm pitch/20mm timing pulley's tother day for the Z axis .
Part machined up the mounting block for the Y axis nut to see how much room i had left to fit the Z lead screw pulley .
mmmmmmm there is no room to fit the pulley  :lol: :lol: :lol: :lol:
I can turn the nut 90 deg that would give me another 7 mm to play with . Wont look as nice  :(
I was never impressed with the section of casting that houses the Z axis bearings , and there was not allot i could do with it as it is to fit the new bearings ect ,,,,,,,,,,,,,,,,, so  i removed the offending lump  :)
No going back  :lol: :lol: :lol: :lol:
« Reply #215 on: June 05, 2012, 12:12:38 PM »
Now, that's a bit drastic. Even for you.........   :bugeye:
I hope you've got a plan, Rob!     :smart:
« Reply #216 on: June 05, 2012, 12:31:12 PM »
You got plenty of cutting discs mate :bugeye: :bugeye: :bugeye: :bugeye:
Offline Davo J
« Reply #217 on: June 05, 2012, 01:03:59 PM »
Hi Rob,
Your doing some fantastic work as usual.
I know your probably well aware of this, but I just thought I would mention that cast iron gusset helps hold the Y axis ways apart, so when tightening the gib it wont squash the ways in.
I will keep watching to see what your doing, but as with all your projects I am sure you have it all worked out and under control.
I was thinking about you the other week when I was chasing up one of your posts for someone, and got thinking I have not seen much of your work lately, then I remembered you did your back, how is that going? I have a broken C3 disc, and I know how these things can lay you up.
Keep up the great work and posts. Always interesting to read and the clear pictures are a bonus.
Offline arnoldb
  • Windhoek, Namibia
« Reply #218 on: June 05, 2012, 01:05:56 PM »
 :D :D  Good to see you back on the mill job mate  :thumbup:
Even if you look like you might be making even more work for yourself on it  :Doh: :lol: :lol: :lol: :lol:
 :beer:, Arnold
Now, just keep it up  :whip: :whip:  :D
« Reply #219 on: June 05, 2012, 04:38:34 PM »
well dun rob
« Reply #220 on: June 06, 2012, 01:39:17 PM »
Cheers Lads  :)
 :lol: :lol: :lol: :lol: :lol: i like drastic David  :lol: :lol: :lol:   ,,,,,,,,,,, Sort of have a plan  :dremel:
Hi Rob,
Cheers Dave ,,, my back is much better now thanks  :beer: ,,,,,,,,,,,,,, Good to see your paying attention  :med: ,,,,,,,,,,,,, I had measured the casting at a few reference points before and after i had copped that portion of the casting , so i could check for any movement in the casting , there was none  :thumbup: ,, i will be replacing the part i chopped out  :dremel:.
 :beer:, Arnold
 :lol: :lol: :lol: :lol: :lol: :lol: no point doing it the easy way Arnold  :Doh: :lol: :lol: :lol: :lol: :lol: :lol:
« Reply #221 on: June 06, 2012, 02:43:47 PM »
Evening Lads
The two lugs that i had left on the casting will be used to mount the new Z axis bearing support   :dremel:
Using my HZ arbour vertically allowed me to reach into the casting to machine the lugs . :dremel:
Now i have something to work from  :med:
« Reply #222 on: June 06, 2012, 04:33:01 PM »
Very nice Rob :clap: :clap: :clap:
I see the casting is shiney on the inside :) :) :) :)
« Reply #223 on: June 06, 2012, 05:22:52 PM »
I think this says it all:
 :jaw: :loco: :bugeye: :bow: :bow: :bow:
Really nice work Rob, those lugs cleaned up a treat, and what a stonking setup.
Note to self: Once finances recover, buy horizontal arbour to use as spindle extension....
« Reply #224 on: June 06, 2012, 05:58:01 PM »
Cheers John  :thumbup:
Thanks  Ade ,,,,,,,,,HZ arbours do save the day sometimes  :dremel: :D
Spun the nut 90 deg and machined of the excess from the nut mount .
Plenty of room for the pulley and the nut to pass  :ddb: :ddb: :ddb:.
I will have to make a new nut mounting block as it looks naff as is  :coffee:
