Author Topic: WM14 mods to Z way with a stepper  (Read 13291 times)
Offline HS93
« on: September 20, 2011, 03:15:40 AM »
I have problems getting my arm up high enough to turn the handle on the z way on my new mill , so I decided to fit a stepper motor,It  has been done so that it can still be  opperated manualy  it is just a 6 mm plate with a ballrace and the one of the original thrust bearing plus a smaller one to replace one of the original the gear has the back machined out for the thrust plus a keyway cut, it all goes together , Simmples  :lol:  I am using my RT controller for now to test it but have the stepper and a unit to controle in ready to box up (hands have been a bit stiff) so when I fit the buttons on the head ill post again.
                                 :ddb: :ddb:  :nrocks: Peter :nrocks: :ddb: :ddb:
http://www.youtube.com/user/onehs93?feature=mhsn
Re: WM14 mods to Z way with a stepper
« Reply #1 on: September 20, 2011, 03:48:52 AM »
Nicely/ neatly remedied Peter!  :clap: :clap: :thumbup:
I do a lot of straightforward drilling, and one of the reasons I bought another Conquest was the Z axis, side handle.
Offline HS93
« Reply #2 on: September 20, 2011, 04:00:21 AM »
this has a handle for drilling  as well, plus a fine feed on the quill.    I should be able to program it to drill to a set depth if needed, but the main reason is because I cannot reach the handle to move the head up and down, I am also putting a stepper on the bed as a power feed, but will still be able to use it manualy.
Peter
« Reply #3 on: September 20, 2011, 04:45:43 AM »
Peter.
I understand your type of machine has only around 2" quill travel.
My drilling handle and fine feed move the head. Handy having full vertical travel, for hopping over r/t chuck jaws. between holes.
I don't have your problems. But, didn't fancy having to regularly stretch to the top of the machine for Z adjustment.....
Offline DaveH
  • Kempton Park, South Africa
« Reply #4 on: September 20, 2011, 01:02:44 PM »
Peter,
You have done a nice job on that.
Always good when a plan comes together ....... and it works :thumbup: :clap:
Offline HS93
« Reply #5 on: September 03, 2012, 12:44:39 PM »
this is for  martink
It was simple to do I removed the top plate and made a new one in aly with a bearing(ballrace flanged) in the centre I did a 2 to 1 belt drive with T5 belts the motor came from http://www.arceurotrade.co.uk/Catalogue/Stepper-Motors/Stepper-Motors     the 180 n
the driver came off ebay http://www.ebay.co.uk/itm/Stepping-Motor-Speed-Regulator-Reversible-Direction-CW-CCW-Stepper-Pulse-/320879363082?pt=LH_DefaultDomain_0&hash=item4ab5e6840a they also do the drive board http://www.ebay.co.uk/itm/CNC-DC12-34V-3A-Single-Axis-Stepper-Motor-Drive-based-on-TB6560-for-4-6-8-lead-/320918218100?pt=LH_DefaultDomain_0&hash=item4ab8376574
then just use a old lap top power supply they are simple to connect up and even come with pre made wires back to the handle if you use a standard T5 belt drive from http://www.hpcgears.com/products/pulleys_belts.htm the gear is driled out to fit the z axis and a grove filed in for the key I then fitted a few grub screws to make shore it was tight .if you need any more specific help just ask I may have some pictures somewhere
Peter
Offline martink
« Reply #6 on: September 03, 2012, 01:58:11 PM »
Thank you for the details, Peter. No doubt you'll be getting a few PM's from me when I've saved some of my pocket money. That's if I can get SWMBO to give me some. :)
Offline ibuildstuff4u
« Reply #7 on: September 03, 2012, 04:35:44 PM »
I'm looking to do a similar build to my X2 milling machine for a power feed for the table.  I could use a DC motor, but I think the stepper motor would provide more low speed torque and a better speed control.
I was looking at the same controller as your build but also found this one that is a lot cheaper.  I may pick one up to see if it would work.
[url]http://www.ebay.com/itm/330528895509?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_4170wt_1165/url]
Offline HS93
« Reply #8 on: September 03, 2012, 04:43:12 PM »
Yep got one of them, ut if you look at the ctr board it comes with leads to connect to the one I am using so easy peasy for someone who does not like stepper drivers, simple is best  also i think the one I have chosen may put out a bit more power.
no problems martink just ask
peter
