Author Topic: My first engine and it runs (but WOW does it knock).  (Read 14584 times)
Offline marfaguy
« on: August 14, 2011, 10:30:07 PM »
It knocks and is pretty loud but it runs. :-) As our UK cousins would say I'm quite chuffed. It's from the HMEM EZ build plans. I didn't do a build log since world+dog has done this one and it's a pretty well documented build. It's pretty noisy, but it runs!
  • Country: za
Re: My first engine and it runs (but WOW does it knock).
« Reply #1 on: August 15, 2011, 12:30:57 AM »
Well I think that's pretty good, :D  my first engine was no where near as good as yours.
Looks nicely made to me, and it runs very well :thumbup: :clap:
So you are chuffed, and so you should be smashing little engine that. :clap: :clap: :clap:
Offline Aestus57
  • Country: scotland
  • Caithness, Scotland
« Reply #2 on: August 15, 2011, 01:35:55 AM »
 :clap:
Superb, and well done for tackling a slide valve as a first engine.  :thumbup:
Think I'm suffering De Ja Vu and Amnesia at the same time, I'm sure I've forgotten this before!
Offline AndyB
« Reply #3 on: September 22, 2011, 07:25:04 AM »
Well done!!
I was thinking... :lol:...you could fit a radial ball or needle race as an easy fix for the flywheel. Just fit over the crank and press the flywheel to it and the bearing plate. They are found everywhere as thrust bearings...computer harddrives etc.
Offline danstir4
« Reply #4 on: September 22, 2011, 08:32:28 AM »
Good job!  Thanks for sharing.
« Reply #5 on: September 22, 2011, 01:08:15 PM »
A good start of making engine, with some small modification you will have a nice engine  :D
Offline marfaguy
« Reply #6 on: September 28, 2011, 09:27:22 PM »
As somebody mentioned...
Don't think of it as "It runs but it's noisy"
instead think of it as
"It runs and it's noisy" :D
« Reply #7 on: September 29, 2011, 04:03:11 AM »
Marfa.
The only phrase needed is, "It runs"....... No buts, or ands:D
Blummin well done, for your first engine!  :clap: :clap: :thumbup:
Offline johnbaz
    • My Flickr
« Reply #8 on: October 11, 2011, 08:13:54 AM »
Smashing li'l engine  :clap: :clap:
I liked how you described it in the vid!!- "noisey bugger"!!!  :D
Cheers, John  :thumbup:
Offline -steves-
« Reply #9 on: October 11, 2011, 08:19:40 AM »
Well if i ever get around to starting my little Stuart engine, let alone finishig it, i will be chuffed if it runs half that well :)
very new to all this....
« Reply #10 on: October 11, 2011, 05:29:25 PM »
Great very well done :thumbup: :thumbup:
Put a bearing in there and it will be spot on :dremel: :dremel:
