Author Topic: Table mounted collet chuck.  (Read 14254 times)
Offline dvbydt
« on: August 10, 2011, 04:00:14 PM »
When I ordered an MT3 ER32 collet chuck from CTC I also got a 20mm plain shank one like this :-
The shank was removed with a cut off disk in an angle grinder, leaving this :-
Next the outer body was turned and drilled. Originally I intended to shrink fit it to the chuck, but it seemed a shame to
ruin the finish, so I uused JB Weld and two grub screws.
The cut off shank was mounted in the 4 jaw and trued up. Using a 20mm collet in the assembly, it was faced
and bored out to 16mm.
One of these :-
was turned into a 16mm spigot for the rotary table.
So, I can now mount chuck on the table,
or on the rotary table.
That will hold from 2mm to 20mm dia.
Thats all my modding for Today's post!
Ian
Re: Table mounted collet chuck.
« Reply #1 on: August 10, 2011, 04:22:34 PM »
Very nice Modding Ian.  :thumbup:
« Reply #2 on: August 11, 2011, 02:17:35 AM »
That's cute, Ian!  :thumbup:
A handy little weapon. Well done!  :clap: :clap:
« Reply #3 on: August 11, 2011, 03:01:02 AM »
Now thats a neat idea far better than my method of doing the same thing.
Thanks for showing.
« Reply #4 on: August 11, 2011, 03:15:44 AM »
That is a really smart idea!
« Last Edit: August 11, 2011, 11:01:24 AM by craynerd »
« Reply #5 on: August 11, 2011, 04:38:27 AM »
Nice job Ian. I like te dividing-head centering stub.
Offline Davo J
« Reply #6 on: August 11, 2011, 06:50:30 AM »
Nice job, :beer:
Just a suggestion
If you open it up to 20mm all the way through, the maximum size for the ER32(20mm) stock could go right to the bottom. It would mean making a new 20mm spigot though.
Offline dvbydt
« Reply #7 on: August 11, 2011, 05:09:27 PM »
Thanks for your interest guys.
Dave, yes I did go through that idea but the soft end arbor was not big enough where I needed it. So, I decided that I would just use a table mounted 3 or 4 jaw chuck when necessary.
The concentricity errors build up so that it is about 0.10mm (0.004")  TIR, but this can be reduced to 0.03mm (0.001") with a tap from a soft hammer.
Ian
Offline Davo J
« Reply #8 on: August 12, 2011, 06:12:45 AM »
If you ever have a need to use the full depth, you could shrink fit a larger piece into you arbour.
Nice work with what you have done though. :beer:
Offline dvbydt
« Reply #9 on: August 12, 2011, 05:28:23 PM »
Yes Dave, I may do that. It has the advantage of being able to finish machine the spigot diameter on the mill, so getting it more concentric.
Ian
