Author Topic: Home built die filer  (Read 101278 times)
Offline Henning
  • All the kit and no clue!
Re: Home built die filer
« Reply #25 on: August 10, 2011, 04:54:17 AM »
Wow! That's impressive  :clap:
Cool project  :thumbup:  :nrocks:
Henning
« Reply #26 on: August 10, 2011, 05:42:36 AM »
Lovely work. I hope you have something sturdy to screw it down to coz the first time I started the motor on my butterfly it tried to take off :D
« Reply #27 on: August 10, 2011, 05:53:00 AM »
Looks it's going to be a real practical tool. Look forwad your speedy progress (insert a green smile here - I'm workking on one chineese project...it's really taxing me).
Offline cfellows
« Reply #28 on: August 10, 2011, 10:15:48 AM »
A great project, Al.  You're really doing a nice job.
Chuck
« Reply #29 on: August 10, 2011, 12:23:52 PM »
That's coming together nicely Al!  :thumbup: :clap: :clap:
« Reply #30 on: August 10, 2011, 01:50:18 PM »
Yeah, very nice and flying along at a pace I could only dream of!
« Reply #31 on: August 10, 2011, 06:34:17 PM »
Al,
Really great, you certainly don't hang about. :clap:
Looking very good, nicely photographed as well. :thumbup:
« Reply #32 on: August 10, 2011, 06:45:10 PM »
very nice  :thumbup: :thumbup: :thumbup: :clap: :clap:
Offline CallMeAl
« Reply #33 on: August 11, 2011, 11:19:14 PM »
Thanks for the comments!
Yes, I did move along quickly after the casting was drilled and bushed.  The rest of the parts were pretty straight forward except the cross slide/reciprocating rod clamp.  I have gotten my shop and tooling to a point and learned enough, had enough blunders, and watched enough other peoples methods and projects on the forum that I can I do the easy stuff quickly! :D
Here are a couple of shots of the complete assembly except for the table I have made a pattern for but have yet to cast.
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1511Upload.jpgHome built die filer
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1512Upload.jpgHome built die filer
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1513Upload.jpgHome built die filer
I have take the time to run the reciprocating mechanism in and it operates very smoothly.  Here is a test run with my two speed drill.  I quite pleased with how it works.
It will never operate as fast as it does in the 2nd half of the video, but I had to hot rod it a little! :)
Now to make the table, mount it, and hook up the little motor I found at an estate sale.
Thanks for viewing.
Al
I skin cats my own way!
Offline HS93
« Reply #34 on: August 12, 2011, 12:20:11 AM »
that looks great, now what you need to do is sent your pattern to the uk as it is nice and ligt as compaired to a casting and one of the members who does castings over hear can nock some up and sell them to all us mayhemmers over hear saves it laying around your workshop doing nothing or if you have plans for it the pattern could be made hear.
keep up the good work
Peter
« Reply #35 on: August 12, 2011, 03:59:14 AM »
Great work Al !!
« Reply #36 on: August 12, 2011, 05:57:55 AM »
Al,
That is really good. :clap: :clap: :clap:
Works a treat. :thumbup: :thumbup: :thumbup:
« Reply #37 on: August 12, 2011, 07:30:25 AM »
Nice work congratt  :clap: :clap:
« Reply #38 on: August 12, 2011, 09:06:30 AM »
Brilliant!  :thumbup:
Offline Pete49
« Reply #39 on: August 12, 2011, 09:46:13 AM »
Top job on that and so quick too. :bow:
« Reply #40 on: August 12, 2011, 01:12:51 PM »
Ditto on what was said above.  :thumbup:
Great job, and I think as Peter mentioned, you could probably make a bit of hobby spending money if put on the market.  :med:
Offline CallMeAl
« Reply #41 on: August 17, 2011, 11:19:56 PM »
Well I finally got this die filer pretty much done.
Thanks everyone for the comments.
I doubt there would much of a demand for these castings, they aren't as finished as some would expect and I'm far too lazy to try to make them marketable. This was just an exercise to try to expand my knowledge on pattern making and casting and hopefully end up with something that would be useful, plus I feel like I need to justify the money and time it took to put my little foundry together! ::)
Here are the final stages:
Cast the table pattern.  You can see the size on the sprue I used to try to prevent shrinkage defects.  I seemed to work since none appeared in the casting:
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1517Upload.jpgHome built die filer
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1516Upload.jpgHome built die filer
Machined the pivot for a true surface to hold the table while fly cutting with the big shop built adjustable fly cutter I made.  I don't get to use this very often.  Check out the video at the end to see it in action:
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1518Upload.jpgHome built die filer
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1519Upload.jpgHome built die filer
Table mounted on the die filer:
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1522Upload.jpgHome built die filer
I made a mount for the die filer and the motor to drive it. I hung it off my grinder stand to use the light attached to the grinder, thrifty yes, but is vibrates a little more than it would on a stand alone base.
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1527Upload.jpgHome built die filer
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1532Upload.jpgHome built die filer
Notice the use of the split switch/plug combo I found in my junk drawer - it controls the motor and provides another handy plug in socket!
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1524Upload.jpgHome built die filer
The motor mount and a close up the 1/8 hp motor I got at an estate sale which came with an adjustable pulley that was worth more the $10 I paid for the motor.  The motor is just perfect for this application.
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1525Upload.jpgHome built die filer
http://i61.photobucket.com/albums/h49/apowellx/Die%20filer/IMG_1526Upload.jpgHome built die filer
Anyway, that's the project finished except for drilling a hole to lube the drive shaft bushings (made grease?)
Now, I have figure out what to do with it?  Here is a video of the table fly cutting and it in operation for the first time.  I only had a thin piece of galvanized sheet to try it out on.  Don't know what I'm doing and it shows!  I think this would be a great tool for the kind of clock work stuff craynerd does.
Thanks for sticking with me through the whole process, I enjoyed your comments.
Al
« Reply #42 on: August 18, 2011, 12:53:35 AM »
Al
Looks to me like you made a very nice job on that, casting, machining and all. Once you use it a few times you will start to realize more places that you can use it instead of other machining operations. You will wonder how you got along without it. Thanks for taking us along for the ride.  :D :D
« Reply #43 on: August 18, 2011, 01:42:51 AM »
Your castings have come out really nice, and so has the whole project. This is the sort of thing I would get a huge kick out of - building a machine and then making use of it.
Well done!
« Reply #44 on: August 18, 2011, 01:51:23 AM »
Blummin well done Al!  :clap: :clap:
That's a resounding success!  :)
I've enjoyed/ understood all you've shown and explained....... Thanks! :thumbup:
« Reply #45 on: August 18, 2011, 01:59:59 AM »
Thats a great project and I am sure a very useful tool at the end of it! :thumbup: :thumbup: :thumbup:
Offline Anzaniste
« Reply #46 on: August 18, 2011, 02:10:10 AM »
Respect! From first posting on this forum on 5th August to completion on 18th August, now that is impressive and a quality article as well. Respect.
I also like your fly cutter; is it to the design in James  Harvey's book?
« Reply #47 on: August 18, 2011, 03:42:42 AM »
Nice work Al! That's a proper looking piece of kit; give it a lick of paint and people will be asking where you bought it from.
As far as what to do with it; my brief readings would suggest that it's pretty much a replacement for hand filing, especially where intricate shapes are needed.
I'm definitely adding one of these to the long list of Things to Make (When I Have a Foundry)...
Offline jgroom
  • Kansas USA
« Reply #48 on: August 18, 2011, 11:13:43 AM »
Very nice Al!  I think this is the kind of tool that you never think you need but after you have one for a while you wonder how you ever got along without it.  :clap:
« Reply #49 on: August 18, 2011, 01:04:48 PM »
Al,
Superb project and presentation.  :bow:
I like the grinding/filing station. Looks like you need to make that filing stand a bit more sturdier and perhaps a slower speed. Just suggestion mind you. All in all a nice little project you presented us with. :beer:
