Author Topic: Micro DRO made from tyre tread depth gauge  (Read 140975 times)
Re: Micro DRO made from tyre tread depth gauge
« Reply #75 on: August 17, 2011, 12:33:56 PM »
Mine arrived today...
Runs off a 3v CR20xx coin cell battery...Shame it wont accept the data plug on my remote readout...So cant tell if its compatible or not..like my scales are..Something to work   madmodder  I guess  :dremel:
« Reply #76 on: August 18, 2011, 02:32:09 AM »
These reader heads DO work with the cheap 6" digital caliper scales, coz I've tested it. Can't fit the boards onto the metal slides of the calipers though without milling a step in each side of the PCB.
« Reply #77 on: August 18, 2011, 10:03:35 AM »
I'll got my today, but I am not shure how to build it. I have a minilathe and it don't looks exactly as the project show.  :scratch:
Here is a pic of my lathe.
I need a good advice how I should do.  ::)
Offline ksor
    • Keld's hjemmeside
« Reply #78 on: August 18, 2011, 10:33:23 AM »
I think the idea with the magnets is good - I'll use mine - when I get them - for both my mill and lathe - then the idea with the magnets is good, I think !
With the magnets you can place it whereever you want on then mill or the lathe - if it's iron of cause.
I'll make mine with magnets I'm sure.
Best regards
KSor, Denmark
Skype name: keldsor
Offline ksor
    • Keld's hjemmeside
« Reply #79 on: August 25, 2011, 08:43:27 AM »
Now I got mine in hand - thanks JohnC !
I dicovered a small hatch opposite the battery hatch - looke like 2 wires could be solded on the pcb !
Do some of you know what this is good for ?
Best regards
KSor, Denmark
Skype name: keldsor
« Reply #80 on: August 25, 2011, 08:49:23 AM »
It's the dataport - you can run a cable to a serial interface and hook it up to a pc to make a cheap DRO, among other things.
www.yadro.de
« Reply #81 on: August 25, 2011, 09:18:57 AM »
www.yadro.de
If anyone has a 'scope, I'd be interested in pictures of the waveforms etc. to see if is possible to add it to my PIC based DRO project
tumutbound
« Reply #82 on: August 25, 2011, 09:32:53 AM »
The most commonly used protocol is this one.
Offline ksor
    • Keld's hjemmeside
« Reply #83 on: August 25, 2011, 09:38:59 AM »
I just tried to replace the moving "ruler" with a small "ruler"-like peace of aluminum - it seems to work too = the digits changes as I move the aluminum !
This implies that I can use all the full range of the digimeter 0-999.99 mm by just replacing the original ruler with a longer one !
I wonder what is the theory behind this small peace of magic - any link ?
Best regards
KSor, Denmark
Skype name: keldsor
Offline Corvus corax
« Reply #84 on: August 25, 2011, 10:46:48 AM »
www.yadro.de
That's exactly what I was wondering about. I have been looking at your PIC DRO for some while now. Good work BTW!
« Reply #85 on: August 25, 2011, 10:47:54 AM »
Yes you can. You can use any length scale you can find. Longest I heard of was 1.5m.
Offline ksor
    • Keld's hjemmeside
« Reply #86 on: August 25, 2011, 10:52:30 AM »
... any length scale ...
Yeah, but just a peace of aluminum ?
How does this work - it must have something to do with the pattern on the PCB and maybe small current circles induces in the aluminum or ... ?
Best regards
KSor, Denmark
Skype name: keldsor
Offline John-Som
    • Start Model Engineering
« Reply #87 on: August 25, 2011, 12:40:20 PM »
Forget about springs - the adaptation is easier than we all thought. As Aussie Jim pointed out why not simply put a magnet on the end of the probe. I am showing Mk l and Mk ll versions on my website and soon we will have Aussie Jim's Mk lll version on show.
John-Som
start-model-engineering.co.uk - a friendly place for model engineering beginners
« Reply #88 on: August 25, 2011, 01:22:48 PM »
No, the slide has to have a pattern of conductive pads (it cannot be just plain) the sensor is capacitive
see:
http://madmodder.net/index.php?topic=4444.msg48960#msg48960
Offline ksor
    • Keld's hjemmeside
« Reply #89 on: August 25, 2011, 01:37:32 PM »
I've tried with a peace of ordinary aluminum and it worked - the digits changed as I moved the aluminum and was fixed when I hold it still.
Best regards
KSor, Denmark
Skype name: keldsor
« Reply #90 on: August 25, 2011, 02:05:00 PM »
Maybe so, but plain aluminium won't have the proper pattern for the quadrature encoder to give an accurate result.
Offline ksor
    • Keld's hjemmeside
« Reply #91 on: August 25, 2011, 02:10:15 PM »
I see no pattern on the original slider - OK, maybe it's on the backside of the aluminum strip of the slider.
Best regards
KSor, Denmark
Skype name: keldsor
« Reply #92 on: August 25, 2011, 04:29:27 PM »
Curious  :scratch:
The typical digital vernier has a plastic cover over the patterned 'pcb'
Is the aluminium strip actually aluminium or just aluminium coloured (like paint)?
A typical read-head will see almost any change of capacitance as movement, so I'm no too surprised a plain metal strip will cause the digits to change, but I would be surprised if they have found a way to 'read' the surface capacitively in a similar way an optical mouse can with reflected light.
« Reply #93 on: August 26, 2011, 12:58:38 AM »
It's under the silver sticker. The pattern itself is a stick-on part too.
« Reply #94 on: August 30, 2011, 05:04:33 AM »
Yesterday I tried one on my mill.
Since I wanted a bit more travel I left the spring out altogether. Just gravity allowing the probe to touch the head.
Worked very well and it gave me the the full 25mm of length.
« Reply #95 on: August 30, 2011, 12:07:20 PM »
I think you need the spring to keep the slider aligned. I just flattened mine so that it has very little friction.
Offline John-Som
« Reply #96 on: August 30, 2011, 05:51:16 PM »
This is my Mk lll version of the Micro DRO and IMHO the best so far in terms of both ease of construction  and use. As suggested by Aussie Jim I have dispensed with the use of springs to maintain contact with the lathe cross slide (or carriage) and fitted 3mm rare earth magnets to the tip of the probe.
http://i256.photobucket.com/albums/hh200/cormorant2/P1020321.jpgMicro DRO made from tyre tread depth gauge
Many thanks to Rob in Australia for the concept and Corvus Corax for bringing this useful little gizmo to our attention.
John-Som
Offline dickda1
« Reply #97 on: August 30, 2011, 07:36:38 PM »
John-Som,
Your post about using a magnet is simply brilliant!
I have some small cylindrical magnets with a appropriately sized bore that will fit my gauges.  As you say, this will eliminate the need for springs.
 :bow:
Skype: VladTheChemist
Offline ksor
    • Keld's hjemmeside
« Reply #98 on: August 31, 2011, 02:30:59 AM »
> John-Som
Did you drill a hole in the magnet or ... ?
Best regards
KSor, Denmark
Skype name: keldsor
« Reply #99 on: August 31, 2011, 03:18:07 AM »
John.
Love your Mk lll version!  :thumbup:
Such a simple/ clever solution......  :clap: :clap:
