Author Topic: Annealing hardened bits using a Rayburn can it be done?  (Read 12655 times)
Offline bry1975
    • http://www.satintime.co.uk
« on: July 29, 2011, 04:51:25 PM »
Chaps,
Would you say it's possible to anneal to small as in 13mm long x 10mm dia hardened bits in the families Rayburn?
TIA
Bry
Offline websterz
Re: Annealing hardened bits using a Rayburn can it be done?
« Reply #1 on: July 29, 2011, 05:29:41 PM »
Best way to anneal is to heat up to cherry red color and allow to cool as slowly as possible. The slow cooling is the key. Burying the hot part in dry wood ash will help.
 :med:
Offline bry1975
« Reply #2 on: July 29, 2011, 05:32:38 PM »
Thanks Webster,
Been some years since I've done annealing probably not done any since college.
